Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-29-2017, 06:29 PM   #1 (permalink)
Default Is this play normal in the flange bearing retainer thingy?
Working on a friends TDR 2. I discovered this part flipping a bit. Manual says it will have some play but this seems excessive. I would expect this to cause some vibes or something.
[ame="https://m.youtube.com/watch?v=c0pDqG27JIg"]Belt support flange play - YouTube[/ame]
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 03-29-2017, 11:12 PM   #2 (permalink)
I added washers to make them snug and reducethe movement.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2
taoY is offline        Reply With Quote Quick reply to this message
Old 03-30-2017, 01:22 AM   #3 (permalink)
Mine was similar, albeit a little less.
It didn't really have an impact on vibes nor on the functionality.
Some people even fly without it.
Belgo
belgoheli is offline        Reply With Quote Quick reply to this message
Old 03-30-2017, 06:07 AM   #4 (permalink)
Hmmm.....not my heli so I will leave it there. I will shim it. I am still trying to understand what it actually does.
Old 03-30-2017, 11:40 AM   #5 (permalink)
Great way to ensure belt wont slip
xioxia is offline        Reply With Quote Quick reply to this message
Old 03-30-2017, 06:55 PM   #6 (permalink)
Oh yes. I did see that part, but a really strange way to implement it. It they call it a flange bearing retainer or something. The two sides that hook the shaft and tail pulley.
Old 03-31-2017, 05:18 AM   #7 (permalink)
It only supports the belt guide pulleys, has nothing to do with bearing retention. Designed to be loose.
VControl
Old hand at Planks
Peter
Old 03-31-2017, 09:41 AM   #8 (permalink)
it's not a problem as it is.
shim it if you like but allow some movement don't make it tight.
2 x TDRII, 3 x TDR's, 2 X Logo's
OptiPower www.optipower.ch
Team pilot: Optipower, Bavarian Demon, Kontronik , Xblades, DryFluid
Paulice is offline        Reply With Quote Quick reply to this message
Old 03-31-2017, 01:27 PM   #9 (permalink)
The point of the design is that the belt should barely touch the bearings at low to medium speed (or even not at all cause at those revs there is no need for them to prevent the belt from slipping)
Only at high revs where the belt on the top side gets under high tension and the bottom side comes looser and wants to drift away from the pulley the bearings get into action to prevent the belt from slipping
Shimming won't take out the for/aft movement of the two hooks holding the bearings.
No need to worry, just fly the machine and you' ll see for yourself
Best
Belgo
Old 03-31-2017, 01:38 PM   #10 (permalink)
I've got play too, but I can't hear anything in the air and it hasn't been an issue. Jan has a note about this that says it is fine.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 03-31-2017, 05:52 PM   #11 (permalink)
Thanks guys. Like I said not my machine so I am going through it with a fine tooth comb. I see in the manual Jan says a bit of play is normal. I just wasn't sure how much. If you guys say what I posted in the video is fine then I am ok with that.
