Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 11-28-2008, 06:33 AM   #1 (permalink)
Default MA Furion - Build Videos
Build videos on MA Furion can be found here - plan to use Scorpiom 2221-8 with a JAzz controller and Futaba 3156 on cyclic - not sure on gyro - may start off with 401 and 9257
John
Old 12-26-2008, 11:30 PM   #2 (permalink)
Default Futaba arms
Figured out a fix to the problem of the servo arms on the Futaba servos - notably the 3156. Some have shied away from the Futaba servos and gone Hitec because of the flimsy cross arms needed to make the 11mm radius required - there seem to be NO 3rd part Futaba mini servo arms available.
Thought I'd make up some CF arms and came across a packet of Custom Heli Products CF arms for the TREX 600 - these are pre-drilled for 15mm but it's easy to bolt the three together and drill a hole at 11mm - then you can take the standard wheel which is a nice snug fit inside and use it to mount to the servo output shaft.
The beauty of these is that you can adjust to get zero-subtrim then tighten up the locating M2 bolts (even drill a 3rd if your like) - I can't imagine a lighter yet more rigid fix !! You can mount the balls under/over to best line up with the swash
PS - you do have to trim down the opposite CFarm to stop if fouling the canopy
ID:	83642   Click image for larger version
ID:	83643   Click image for larger version
John
Old 03-01-2009, 10:33 AM   #3 (permalink)
thanks for the vids. BTW, do JR servo arms fit on futabas? I know they have a 10 mm hole in one of there arms.
xcraftllc is offline        Reply With Quote Quick reply to this message
Old 03-01-2009, 10:53 AM   #4 (permalink)
The big ones don't fit, so I bet the small servo arms won't fit either.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 03:15 AM   #5 (permalink)
<object width="640" height="505"><param name="movie" value="
ready heli insane crash contest (DIXONS CRASH) (2 min 22 sec)
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
how about a repair video...
razeyoshi is offline        Reply With Quote Quick reply to this message
Old 06-06-2009, 07:00 AM   #6 (permalink)
Why not just use the Futaba heavy duty arms for the 3156?
http://www3.towerhobbies.com/cgi-bin...?&I=LXWDH3&P=7
hokie_steve is offline        Reply With Quote Quick reply to this message
Old 06-20-2009, 08:44 AM   #7 (permalink)
My manual says 13mm for the servo radius. Should it be 11mm as stated above?
clever is offline        Reply With Quote Quick reply to this message
