Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 04-08-2014, 08:16 AM   #41 (permalink)
Just make sure you install it with the bearing facing backward - i have heard otherwise doesn't work so well...
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 12:00 AM   #42 (permalink)
Originally Posted by cbrkhan View Post
I also have YGE 160, what threads or resources did you use to program yours? If possible, can you describe steps you took to setup your YGE 160?
I will maiden it with castle 160 (because I only know how to setup castle) but will switch to YGE as soon as I can figure out YGE setup.
I am also interested in low RPM as well. What headspeeds are you using for Normal, I1 and I2? also what pinion?
Hi, I am lucky enough to fly with a few guys that already have the yge160, so they helped me set it up, with the vbar. I would also recommend the link that has been posted!!
I'm using the 11th pinion and HS are 1600, 2050 and 2150, also just put some Rail 696 blades back on and with the higher HS they are my favorite over the Edge. I guess you would say my flight style is "manic" and the Rails feel more responsive and quicker..
Unfortunately I have been having some power loss issues that haven't really been sorted yet. Basically at a random time during the flight, if I really load it up say with a big tail slide and hard stop, the power cuts out for a second and then goes into like a soft start.
I have tried a few things suggested and it hasn't happened for the last 5 flights, but it's in the back of my mind and does hold me back a bit. I thought it was the one way, but after the mod same problem, and I would have expected more of a violent restart once the slip grabbed again rather than a soft spool up.
Anyway I hope your setup goes well and I'm sure you will love the yge.
Gaui NX7,X7, R5, NX5,
Vcontrol, Vbar
Hobbycity New Zealand
flyingkiwi is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 03:35 AM   #43 (permalink)
Did you try changing your PWM? what are you using now?
Calculation says 12 and this has solved similar prob for a friend
Old 04-09-2014, 04:44 PM   #44 (permalink)
Hi,
I am thinking about Gaui X7 Formula (217960) for my winter project. Will a 800MX 520kv fit the X7? I am not clear on bolt pattern and shaft lengths needed for Gaui X7.
I open to other suggestions as well for the motor maybe a scorpion ??...... I have 800mx on my trex 700 and like the balance of power and efficiency. I get 5 minute flight (2200 rpm) on my trex and the motor comes down hot but not too hot ...
My flying style is 3D .... not too hard but getting there slowly.
Other Electronics -- I already have YGE160HV and MKS HV servos that plan to use for X7.
Please turn to 850MX to make a perfect match to this frenzy bird and satisfy its rage.
Gaui X7: Scorpion 4530/130A Opto, OMG H4 Servos, Micro Beast X
Halo blades, OptiPower Ultra 5000mah 6s 50c, Futaba 14SG
Team GAUI OptiPower OMG Servos Halo Blades USA field rep.
Kenny_Fong is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 05:49 PM   #45 (permalink)
Hi, yes I have tried different PWM settings and currently on 12. I did have another "power out" but this time I found the grub screws on the motor pinion were loose and it was spinning on the shaft. I live in hope that this was the cause all along, but it doesn't really match the symptoms (slow spool up) each time. Can it be as simple some red loctite:-) we will see I guess.
Vcontrol, Vbar
Old 04-11-2014, 03:18 PM   #46 (permalink)
yep - the slow spool up points somewhere else... i would try YGE forum
Old 04-15-2014, 10:22 PM   #47 (permalink)
+1+1+1+1+1+1+1..... excellent motor! lots of power! and you don't have to oil it either....
450x- w/ sk3 4300 motor, Yep 100
X7- iKon, 850MX 12s, Yep 180
X7f- iKon, Xnova 4535-460 14s, YGE 320
Gaui x7 14s yge320 072515 (2 min 5 sec)
fastblade is offline        Reply With Quote Quick reply to this message
Old 06-30-2014, 11:52 AM   #48 (permalink)
Default Gaui X7 Formula -- What Motor? 800MX 520kv?
Fitted the Extra Long 4530 scorpion shaft to my 800mx today cut it down and put the flats on for the grub screws, sorted
Love the scorpion shaft because you can easily pop the circlip of and take the motor apart
Gaui X7 Formula
Trex 450L Dominator
Oxy 3 Lynx pilot. 2nd place Sports class, Helifest 2015
DRM Black7 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 05:47 PM   #49 (permalink)
That is genious!
Thanks for the info. Getting long align shafts is pretty hard
GAUI Hurricane 550 (tired but not retired)
GAUI X5 (over 200 flights in one year)
GAUI X7 (sure bet for an adreneline rush)
Navajo31 is offline        Reply With Quote Quick reply to this message
Old 07-06-2014, 04:13 PM   #50 (permalink)
After having a good 30 odd flights with the 800mx 520kv motor, on a 10t pinion at 2100rpm it feels GREAT! Bags of power, doesn't run to hot and I get 5mins with 25% to 30% left in 5000mha 30c Optipowers.
Love Align motors and this ones a Gem
Gaui X7 Formula
Trex 450L Dominator
Old 07-07-2014, 03:30 AM   #51 (permalink)
Thats tons of flight time! Mild 3D or sport?
Old 07-07-2014, 07:24 AM   #52 (permalink)
I would say mild 3d with tic tocs and fast pie dishes. I recon I'm quite good with the pitch tho as I get more flight time on my mates Helis as well.
One thing I have noticed tho is after I've landed the drivetrain spins for ages and AGES! Compared to my old Trex 700.
So I recon it all adds up.
I'm also using the pitch boost (Vbar) which costs me about 20 secs of flight time but not to fussed as I like the feel
Gaui X7 Formula
Trex 450L Dominator
Old 07-07-2014, 02:03 PM   #53 (permalink)
Old 06-17-2017, 04:50 PM   #54 (permalink)
Hate to revive a 3-year-old thread, but I snapped the shaft on my 800MX today, just a fairly tame rainbow.
Lesson learned and Scorpion XL shaft on the way!
hoblium is offline        Reply With Quote Quick reply to this message
Old 06-17-2017, 05:04 PM   #55 (permalink)
And I have built myself a monster :
https://www.helifreak.com/showpost.p...0&postcount=95
Tags
x7 motor
