180CFX Blade 180CFX Helicopters Information and Help |
06-15-2017, 11:32 PM | #1 (permalink) |
Head wobble, how do you get it out?
Hello there,
I got my newest 180 flying but it has a head wobble when at fast cyclic controls or when i descend and the heli gets into its blade wash. I can still fly the heli but I can't do anything hard without it wobbling. What should I do to fix that? Just do you know, everything in the head including swash plate is in perfect condition. Nothing bent. I also have the o ring dampers and actually doubled them up. Didn't help. I think it's a gain thing but don't know.
The Brightest Way in the Darkest Days. Blade 300X, Align T-Rex 600N ,MCPX,Oxy 2,Goblin Fireball,Logo 600SX,Synergy E7SE F3C, Gaui NX4, Gaui R5, RCHN #815Team Xpert Servos USA Tellarotor RC Podcast |
06-16-2017, 01:01 AM | #2 (permalink) |
If (as you say) all the head components are in perfect shape...
I would check servos for a missing gear tooth... The easy way to do that is to fold the blades over the boom with TH on...and move the collective stick at varying speeds from 0-100 and watch each servo for jumpy activity... Found that issue on one of Mine tonight and a servo swap fixed it |
06-16-2017, 06:53 AM | #3 (permalink) |
I have seen this behaviour a few times. If the head wobble was accompanied by slight circling in a hover, then it was feathering shaft. If hover was solid then it was servo issue. As jonjet mentioned it could be a missing tooth. I've had sticky servo's cause this and fixed with a maintenance rebuild.
The other quick check I would make are to ensure all links between servo and head move freely, no sticky points.
Goblin 420 | Goblin 280 Fireball | Gaui X3 | KDS Chase 360 | 360CFX - 6S | 230S | 180CFX x3 | 130S | Nano CPS | V977 | XK K110 | Skookum Spartan V-Bar uBrain BeastX | DX6 Gen3 |
06-16-2017, 01:19 PM | #4 (permalink) | |
Thanks for the help. I did check the servos and it does seem like two are jumpy. One is far more jumpy than the other. I have in this Heli the lynx servos. I opened the worse of the two and found it to have a very bad bearing. They use the same 4x7x2mm bearings as the main shaft. I didn't have any new ones so I put a used one in that's not in the best shape but far better than the one that was in there. The heli still wobbles but not as bad. I will replace all of the bearings once a new set comes in. But is there anything else I could do to get the servos to completely stop jumping?
