Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Electronics
Electronics Electronics Discussion
Old 12-02-2014, 05:36 PM   #1 (permalink)
Default Model Sound Inc system with Th Gov settings?
Hi guys,
I am quite interested in the sound system from Model Sounds Inc. As I understand it is that there are 3 separate sounds - start up, shut down, and normal flight sound. The first two are activated by the clicker Trainer switch, and the flight sound is proportional to the Th stick movements.
I am curently flying my Tr550 AS350 in Gov mode on my Talon 90. I will soon be replacing my 3gx with a Sk720 and also using Gov settings.
My Q is - does this system work whilst using Gov settings, or does it require fixed endpoints to operate?
Joe
Farmer Joe is offline        Reply With Quote Quick reply to this message
Old 12-02-2014, 06:35 PM   #2 (permalink)
I have re posted this into the general discussion section.
Old 12-03-2014, 10:47 AM   #3 (permalink)
HF Scale Support
I'm just taking a stab at that your are using the GOV setting on the ESC so this will only apply there. When you set your curve for the Talon, you will still have a Zero position on the stick in Normal mode and depending on your individual setting, will have either two or three speeds there. I think that the throttle moving (you did say that another switch gives the start-up and shutdown portion, right?) from low to any spot higher than around 25% will then give you the sounds of the engine and rotor (rotor sounds too?) in flight. I hope this helps you get it set.
Don
Old 12-03-2014, 03:43 PM   #4 (permalink)
Thanks Keyrigger, with the info from you and mbutler I think I've got it. All I have to do now is give my heli a run with a bit more weight to see what affect it has on flight time.
