Old 02-15-2009, 11:17 AM   #21 (permalink)
Default Got it!
Found the problem. Got it all set close. +11/0/-10. Any way I notice one of the blades had a slight bow in the middle of it. So i gotta new set of blades and went outside and it hovered perfect.. Never would have thought a slighly bowed blade would have kept it from lifting off but it did..Now I have New problems.. I will make a new post about the dx6i acting up.. Keeping the elevator servo from working right.. Thanks for all the help guys..
Helihangover is offline        Reply With Quote Quick reply to this message
Old 02-15-2009, 11:46 AM   #22 (permalink)
https://www.helifreak.com/showthread.php?t=119019
Compass 7HVU HBL980/950 Ar7200bx Edge160-- Compass 6HV, 610/650
TRex 700LE , Beastx 610/650, Warp360 TracX 92A+
1BADAIR is offline        Reply With Quote Quick reply to this message
Old 02-15-2009, 12:05 PM   #23 (permalink)
Default Wish it wasn't mine..
Thanks 1badair. I checked my code on the back of the radio. It is 807E so if I am right that is the one that qualifies. I noticed when it acts up I can go into monitor menu and hold the right stick for acouple seconds in any position but neutral. And the sliders will catch and hold then jump around...When it acts up it kicks the front of the swash up.and limits the movement of my elevator servo. But it works with throttle collective just fine.
Does anyone know how long I will have to go without my Radio if I send it in for repair? Do I have to pay for shipping also??
This sucks I first noticed it on about my 3rd flight back in january. It got worse over time. It would do it more frequently and for a longer duration.. Oh well
Crash Test Dummy
Old 02-15-2009, 12:27 PM   #24 (permalink)
My DX6i was bad out of the box. Same date code and issue as you with ELE. I also have THR issues too. I can play with the left stick and have ELE jump around!!
I called Horizon about that issue and all the issues with my CX3 and the told me to send it all back. I complained about having to pay for shipping and they said they would send a call tag. I have been waiting a week now for the call tag.
Ivan
9sec240 is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 07:31 AM   #25 (permalink)
Default More Help for a newbie
I've gone throught the head set-up ( a couple of times). I now have the same pitch positive and negative. The problem is that one blade has greater travel that the other.
Blade one is -11/0/+11
Blade two is -14/0/+14
What do I need to adjust to get them equal?
On a side note, I have a heck of a time hovering. The heli tends to want to dart around. It is likely just me, since I am new, and hovering pretty close to the floor and ground effects.
If you have any ideas on either question, let me know.
Thanks!
Woody_99 is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 07:42 AM   #26 (permalink)
Thanks!
You need to set up the heli per Sokal's videos. There is no way tracking could be close with that big of a pitch delta! I wouldn't fly it any more till it was set up correctly.
http://www.slyster.com/heli/b400bible.html#videos
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0
Penguin is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 08:00 AM   #27 (permalink)
I went through those videos, a couple of times, so I am missing something in the process.
First time through the + to - was not equal, and the blades where different too.
Second time through, the + and - pitch are equal, but the blades are different, and I'm not sure where to look next.
Old 02-17-2009, 08:21 AM   #28 (permalink)
Check the mixing arms on your blade grips. You most likely have one flipped around. One ball is further from the pivot than the other and if reversed will change your mixing ratio. Hope this helps
Hirobo Lepton EX, Kyosho Caliber4, JR Vibe 50, JR Vibe 90SG
Foamy Corsair and Habu, MCX, MCX2, all on JR 11X
nargargle is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 08:41 AM   #29 (permalink)
Old 02-17-2009, 08:42 AM   #30 (permalink)
WOW, you're absolutely correct, I do have one of them flipped around!!
Now, which one is the right way? Looking at pictures in the on-line manual, I can't tell which side goes to the swashplate, the long or the short.
Edit, I found this picture, is it correct?
Old 02-17-2009, 08:47 AM   #31 (permalink)
Use the pic above for stock config and flip the mixer arm around if you want more responsiveness. You should read through all the mixer arm flip threads before you do that though.
Old 02-17-2009, 08:56 AM   #32 (permalink)
That's not stock, that's the mixer arm flip config.
Old 02-17-2009, 09:24 AM   #33 (permalink)
the first pic is correct
Old 02-17-2009, 09:58 AM   #34 (permalink)
So for stock, I want short side to the short link, right?
Old 02-17-2009, 10:00 AM   #35 (permalink)
Go back to post 29 and look at the pic. Can't be any clearer than that.
Old 02-17-2009, 10:07 AM   #36 (permalink)
OK, I just wanted to make sure. I think a couple of post happened about the same time, and I wanted to be clear on stock config.
Thanks!
Old 02-17-2009, 10:11 AM   #37 (permalink)
Thanks!
Old 02-17-2009, 12:45 PM   #38 (permalink)
your best bet is the the zeesaw rod. check whether its not moving up and down, it should only wip not going horizontally up or down.
if this is o.k. make sure your grips are not flipped i.e. the nut must be on the lower side.
if all this is o.k. check your pitch curve in the dx6 i make sure you get something in Normal like 40 45 50 75 100
make sure throttle curve is going up to about somewhere like 0 30 50 70 90
than if you adjusted pitch correctly and your training gear is not too oversized, heavy
you should lift of at about 50 to 60 %.
did you put the blades the right way ? clockwise rotation ?
best of luck
PS: if it doesn't feel right it is most propably not right don't try to force...... you ll only
crash and force your pocket......
macel is offline        Reply With Quote Quick reply to this message
Old 02-17-2009, 09:14 PM   #39 (permalink)
Thanks for everyones help. I got it set up correctly now, and actually was able to do some hovering, and actually had some control.
Much better. Now the real practice can begin!
