Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 04-24-2016, 09:42 AM   #41 (permalink)
I regularly use the futaba governors, they are very tunable
I've also used Motul 800 2T
I would NOT run the engine without installing the spiral pin clips
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 04-24-2016, 09:44 AM   #42 (permalink)
From discussion here, it seems that the 170/23 (7,39) gear ratio would be better than 170/22 (7,73), is not so?
the longer the blades, the shorter the gear ratio for best results
the engine does not have a great deal of torque to overcome taller gear ratios unless you are reducing the size of the blades
Carey Shurley
Old 04-25-2016, 02:13 AM   #43 (permalink)
Yes, I understand. My target is to fix engine RPM under lets say 15,5k. To be able to do so and achieve suitable head speed, it would be better 7,39 gear ration (with 600 size blades).
Lets calculate - 15,3k on the crank with 7,39 and the result is about 2070 on the rotor.
I think that somebody tested 7,35 gear ration with 620 blades and 15,8k on the crank with Goblin 570. This should be similar.
Or to use standard gear ratio and 620 blades maybe.
Lets calculate - 15,3k with 7,73 on the crank and the result is about 1980 on the rotor.
I do not know whether the 23T pinion fits in the conversion without frame modification, but I already have:
- 600 Align blades
- 623 EDGE blades
- 23T pinion as I mentioned before.
- full kit of 600NFL
I am waiting for the conversion, which should come this week. I am going to test whether the pinion fits there. If so, I would test the combinations and let know the result.
Anyway, I compared fan shround for 700N with placed GFORCE SHO fan with 600N fan shround and the 700N one is little wider - would not be better to little close the hole and add some e.g. epoxi glue inside the 700N fan shround to make it more tight for the 600 size fan? Would not be the fan more effective in this case?
I can not upload attachment here, well, the photos are here:
600N
https://www.dropbox.com/s/btsuwvqnn8...20fan.jpg?dl=0
700N
https://www.dropbox.com/s/xehatbvkzv...20fan.jpg?dl=0
How do you think Carey?
Gasserheli Morphis, Hanson 300, Spirit FBL;
Logo 600SX, HC-3sX; T-Rex 470LP;
Miniprotos, Helibug 600, HWC700PUH, HWC 600, T-Rex 600 GT15HZ600 conversion, T-Rex 600 GoEngine 56, T-Tex 600N;
SlezY83 is offline        Reply With Quote Quick reply to this message
