Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Electronics
Electronics Electronics Discussion
Old 08-15-2014, 05:28 PM   #21 (permalink)
I was thinking of using this PowerBox Evolution to supply my Rx and servos via 2 x 7,4 volt LiPo (one LiPo is backup).
link to Powerbox = https://www.powerbox-systems.com/pro...evolution.html
You can feed your servos with 7,4 volts if you desire to run HV servos (i do).
This system with and iKON and 2 DSMX sats. This is what i am aiming at. I run an iKON on my 600E Pro DFC and havent had any issues and i find setting the thing up easy.
I think it is doable.
VARIO Robinson R22, Savöx, Bavarian Demon Axon, Spektrum AR 9110
Align Trex 600E Pro DFC, 600MX Motor, iKON
GAUI Hurricane EP550, Z20, Bavarian Demon 3X + S9254 Tailservo, Radiomaster TX16S
Align Trex 450L DFC Head, 3GX
Sweetfrost is offline        Reply With Quote Quick reply to this message
Old 08-15-2014, 05:33 PM   #22 (permalink)
HF Scale Support
That is a sound solution that will make sure your servos get the power they need without putting undue stress on the unit. I know that the AR7200BX has an internal track system capable of handling up to 10A thought it and I think even the Skookum can handle similar loads but when you have a very expensive model depending on constant power without brown-outs, the external power bus is the way to go. Have a good time with your heli. Take care.
Don
Old 10-27-2014, 04:23 AM   #23 (permalink)
I have a correction for my previous post. Im not going to use the iKON or a powerbox.
Bin doing some research and found out that the iKON does not support 4 servo swash setup.
And to keep things a little simple the AR9110 is the Rx im going for. It has dual battery input and up to four satellite antennas.
As for flybarless controller there are 2 brands im considering. Spartan Vortex VX1 or the Bavarian Demon 3SX. Both supports 4 servo swash.
A few days ago i finally got the Vario R22 fuse .. The quality of the kit is very nice.
Now im saving up for mechanics and all the electric stuff. And the best part... i am now near finished building a new "shop" so i have a good environment to build. Took a good chunk out of the living room and put up a new interior wall with a door.
Heres a few pics ..
Old 11-12-2014, 07:56 PM   #24 (permalink)
Hi Keong
Tried to PM you but didn't work LOL
I got to maiden my 429 mechs WITHOUT a stab system and she was smooth and very predictable even for this old guy LOL
There are two videos of it in the large scale section under scale electrics. Check it out and tell me what you think.
Now back to our regularly scheduled program....
Roy Mayoral
heli143 is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 07:13 PM   #25 (permalink)
Originally Posted by Keyrigger View Post
A power bus is not a BEC. You supply the power bus with electricity from a BEC, first, which in turn, then powers the receiver. The idea is that you let the bus directly supply power to the servos and only use the receiver for signals, taking the load off the internal tracks of the receiver. You can and will burn out a track in a receiver if you have a servo go into a stall condition along with having a heavy draw from any of the other servos UNLESS the manufacturer of the receiver guarantees that it can supply a stalled servo with power from the onboard circuitry while also supplying the rest of the servos with power to run them. All it takes is one at stall and your power consumption goes through the roof. Take care.
Don.
hi don, might you be able to put up a simple schematic ?
best,
mike d.
__________________________
Always slowly .. Always surely
SA315B Lama (4FM200L), RX2618V-D, Devo8s;
AS350 Écureuil (Roban Superscale 700), AR7200BX, DX8
MAAC#88108
Love the Lama is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 11:57 AM   #26 (permalink)
HF Scale Support
Love the Lama:
This is how most of my large helicopters are wired. Be very careful to disconnect the red wire from the ESC to any receiver or power bus if the ESC has a built-in BEC. You can set your BEC voltage for what ever your servos and electronics can handle. If in doubt, 6V is pretty much safe but be careful if your tail servo requires 4.8v. You will then need a step-down just for that servo line but those servos are few and far between. Hope this helps.
Don
Name:	Illustration for Power Bus.jpg
Old 11-20-2014, 12:45 PM   #27 (permalink)
mighty big thanks, don.
as always ...
mike d.
SA315B Lama (Walkera4FM200L) RX2618V-D DEVO8s
AS350 Écureuil (RCASuperscale 700) AR7200BX DX9
MAAC#88108
