Go Back   HeliFreak > R/C Helicopter Support > OXY HELI
OXY HELI OXY HELI Factory Support Forum
Like Tree285Likes
Old 04-20-2015, 11:05 AM   #61 (permalink)
The Airetic
Originally Posted by fabu74 View Post
Or you run in 4S, you keep the gear of 14. You will just need a strong esc and reduce the throttle in your radio.
I've this case with a Blade300.
If you were running 4S on the EOX 4100kv motor, and used the 14t pinion, you would be set up for a gov'd head speed of well over 5,200rpm!
You would have to run your throttle percentage waaaaaay down low to keep it at a more reasonable head speed. To run the throttle that low is a serious risk to an ESC that does not have active freewheeling. Even if you did not burn up the ESC, you are running it so inefficiently that the flight times would suffer greatly.
I'm sorry, but I think this is a very bad idea.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 04-20-2015, 11:28 AM   #62 (permalink)
Originally Posted by vtown nick View Post
It's gonna rip on 6s or have torque for days depending on how you gear it. Should be awesome!!!
Torque.
Gearing for same head speeds I am running 3S un gov. at, but with 6S I'll have heard room for gov.
I like the 11T on the 3S set up. Motor and ESC runs cooler for me, but no head room for governor. 11T is my personal sweet spot. Gearing the 3S for less torque but more HS for the room for gov. falls out of my personal sweet spot.
So going 6S, same HS but room for governing.
This is why there is so many combo's of motors and gearing. We all have a personal sweet spot.
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 04-20-2015, 11:39 AM   #63 (permalink)
The Airetic
Originally Posted by RichKnapp View Post
Torque.
With the 11t on 3S, It sounds like your "sweet spot" is in the 3400-3600 range.
3S with the 4100kv motor, and the 13t pinion will give you that same range, but with the benefit of the governor.
You would get a similar range from the 6S, 2500kv motor and an 11t pinion. I suspect however, that you will be getting shorter flight times.
Old 04-20-2015, 01:49 PM   #64 (permalink)
I only do 4 min max flights anyways on all my birds.
Any more and my (physical, not my mental ) nerves are shot and need a brake.
Yes, I am going with the 2500kv and with the DX8 I will be shooting for 3 flat curves between 3200 and 4000.
This will also allow me to play around with 3s super slow HS.
Teach me to rely on good Collective management rather than HS and power with any of my birds.
I love trying new things.
PS. This will also set me up for stretching and 3 blade head when they come out.
Old 04-20-2015, 02:00 PM   #65 (permalink)
The Airetic
I'll be curious to see if it even gets off the ground at 2200-2300rpm!
Old 04-20-2015, 02:07 PM   #66 (permalink)
Play time. lol
Old 04-20-2015, 05:19 PM   #67 (permalink)
Yup I'm in the same boat, my oxy is begging for 3 blade and stretch
Nice lower head speed 3d with some sick sounds of 3 blade awesomeness!
"I fly because it releases my mind from the tyranny of petty things."
JayHelifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 02:01 AM   #68 (permalink)
6s is the way to go for more flight time. The more your voltage is, the less amps it needs. But voltage stays more consistent during flight, so peaks will be less too.
I'm pretty sure it will fly at 2200 rpm, I'm able to piroflip my 473mm bladed heli with no problems.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 02:11 AM   #69 (permalink)
I only provide my experience as I've the case with my Blade 300x.
I fly 6 minutes with this heli compared to 4 minutes with my Oxy3 using the same Lynx 245mm blades and the same lipos 4S 1300mah and same esc. One is at 65% throttle, the other one is running at 80 or 85%.
Oxy3, Trex from 150 to 700, Sab from 380 to 700,
Blade MCPX BL to Blade 550X, Rush750, Forza700, MD7, Protos 700 V2.
fabu74 is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 04:23 AM   #70 (permalink)
Lets talk about "sex"" hahhh. Yesterday Tareq made some fly with his favorite ikon set up and in stretch kit at 5000 rpm we mesured pick power of 800w and 40a.. 6s eox motor 2214 2500 kv pinion 13.. the fastest heli I never saw in my life. 2.5 minutes of amazing adrenalinic feeling! Thanks Tareq!! Soon video°!!
Luca Invernizzi
Lynx Heli Innovations
OXY HELI
ininverno is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 04:29 AM   #71 (permalink)
Yes, it's another world, 5000RPM stretched... waiting for the video, I will put the sound this time...
Old 04-21-2015, 08:55 AM   #72 (permalink)
Got my 6S conversion on the way. Now I watch for the stretch kit and then it's "Take my money, AGAIN" time. You know I love my stretches.
Old 04-21-2015, 09:10 AM   #73 (permalink)
Which motor have you taken Rich? The 2214 or the 2222? Which pinion?
Old 04-21-2015, 09:27 AM   #74 (permalink)
Please please please post this video today!
/#Team BK Servos//#Team Pulse/#Team AMain Hobbies// /Team Canomod//
Greg Jackson 2017 Team USA F3N https://www.youtube.com/channel/UCci..._R4nja0RYeXykg
GJacksonF3N is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 10:46 AM   #75 (permalink)
The 2214-6S-2500KV and 11T
Old 04-21-2015, 11:58 AM   #76 (permalink)
Last sunday I did a demo for the Dutch Red Bull Paperwings final. The Oxy here will be used for a review in the Modelbouw Aktueel. I've got some pics:
Logo 800/Jeti DS16
Old 04-21-2015, 12:09 PM   #77 (permalink)
Cool
Old 04-21-2015, 01:10 PM   #78 (permalink)
Same here, but I'll run the 10T when Luca releases the Stretched Oxy3 Cubed Mod.
Field Rep Team Synergy, Team Scorpion, Team VBar Control USA, Team MKS USA, Team OptiPowerUSA, Lynx Heli Innovations, Oxy
180CFX, Oxy3, Synergy E5-696, Synergy N7, Synergy E7Speed, Synergy 766
chumley is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 03:58 PM   #79 (permalink)
Can't wait to fly with my Oxy 3... But they send me a damaged MSH Brain and I have send it back yesterday I must wait 2 weeks [emoji17] on a new one.... or repair but I think they don't gonna repair it
Team YGE
Team Xnova
Team Pilots lounge
Joeribar is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 09:12 PM   #80 (permalink)
Converted mine to 6S to keep my mind busy. (mother in law was in ER )
