Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy2
Old 06-11-2017, 01:41 PM   #41 (permalink)
When I have a blowout I check the flight log. If the rudder limit is reached, then it is an issue with Tail RPM/Tail Throw/Tail Blade Area. Otherwise it is the other stuff; Rudder Gyro Gain/Servo Speed, Driving Hz, Voltage, Torque.
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 06-11-2017, 03:12 PM   #42 (permalink)
Very good one, ic-racer, I'll try that next time I fly.
hookedonflying, first time I had the tail blow out I DID crash, but I was fast with Hold and on high wheat, zero damage. Other times I tested, I was more ready with Rescue
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 06-11-2017, 03:47 PM   #43 (permalink)
You said, removing the clamp removed the blow-out but caused vibrations.
Try to sand the clamp inside - I did. So that the tail pushrod only touches the clamp slightly when in nearest position (what is 90° servo arm). This highly increased my tail-behaviour.
But I did not have any vibrations when doing a test flight without clamp.
Walter
donaldsneffe is offline        Reply With Quote Quick reply to this message
Old 06-11-2017, 11:50 PM   #44 (permalink)
If you had a blowout in fast backwards flight it could be that you didn't have enough tail authority. What headspeed are you running?
Old 06-12-2017, 12:58 PM   #45 (permalink)
Well, actually I don't know. According to my calculations I should be running around 4000, 4500 and 5000, and experiencing blowout with the first two at least. I run an 11T pinion on a 5500kV motor, with three TCs of 71%, 82%, 91%.
But... my Magic Mirror only goes up to 4200, two Android apps I tried, which served me well in the past, give strange inconsitent results (could be the plastic blades?), and an Hyperion sensor I tried with Spirit gives "jumping" results. Ordered and HW sensor, let's see.
Old 06-13-2017, 03:13 AM   #46 (permalink)
Originally Posted by Coco66 View Post
(could be the plastic blades?),.
No.
Frequency is independent from blade material
Walter
Old 06-13-2017, 07:37 AM   #47 (permalink)
I use Headspeed Tachometer and it works great. Consistent with small or larger helicopters.
Oxy 2, Blade Nano CPx, nCPx wild, nCPx HH brushless, (2)180 CFX, Tarot 450 Pro FBL DFC, Align 450L Dominator, Align 450 stretched.
hookedonflying is offline        Reply With Quote Quick reply to this message
Old 06-13-2017, 09:30 PM   #48 (permalink)
I am using the HW sensor, and rpm are spot on in comparison with rpm telemetry....
Oxy2 - Oxy 3 -Oxy 4 - Oxy 4MAX - Oxy 5 MEG - Oxy 5HF - Nitroxy -Flash700
scoio is offline        Reply With Quote Quick reply to this message
Old 06-14-2017, 04:24 AM   #49 (permalink)
I am surprised of my Hyperion sensor giving strange results since it always worked well for Spektrum telemetry. Never really seriously tried it with Spirit Governor though.
Old 06-22-2017, 03:37 AM   #50 (permalink)
Just as a note, now my tail works perfectly with the DS95i and headspeeds of 5000+
Old 06-22-2017, 12:28 PM   #51 (permalink)
My tail also worked good with DS95i. But I could totally feel the extra weight. The heli felt like a big in the air.
So eventually I went back to DS76t - which required I fix my tail issue (bad pitch slider, in my case).
mba83 is offline        Reply With Quote Quick reply to this message
Old 06-22-2017, 01:27 PM   #52 (permalink)
Possibly the extra torque from the new servo masks a problem you may have.
-Ben
Old 06-24-2017, 07:09 AM   #53 (permalink)
I noticed I was starting to get a little tail blowout on one of mine. After looking it over I found that my belt had loosened up. Not sure how. I generally run a loose belt.
-Ben
Old 06-24-2017, 11:53 AM   #54 (permalink)
Great info here for future trouble shooting and solving issues with blow out.
I love HF!
DX9 BE • OXY3~285/Brain/BT Oxy2FE/µBrain2DX6•Phoenix •
• 500 3D •180CFX x 3 • Splendor •
Not_Here is offline        Reply With Quote Quick reply to this message
