Go Back   HeliFreak > R/C Helicopter Support > OXY HELI
OXY HELI OXY HELI Factory Support Forum
Old 04-09-2017, 07:51 PM   #1 (permalink)
Default Loose dampers
Has anyone experienced loose (sloppy) dampers on the spindle shaft? I've had my oxy for a year, several spindles and damper sets. Never a problem before, tried new dampers and spindle shaft. Same problem? Dampers tight in main hub, translates to a lot at blade tips as you can imagine. New dampers on order. These are the white dampers. Probably .002 slop, seems strange
canopycracker is offline        Reply With Quote Quick reply to this message
Old 04-12-2017, 02:33 PM   #2 (permalink)
Hi,
Did you add shims?
Adding shims will take away the slop.
Cheers!
|Michalis|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 04-12-2017, 03:34 PM   #3 (permalink)
Originally Posted by acidla View Post
Did you add shims?
+1
I think Lynx actually recommends checking the head play after 100 or so flights of "break in" and adding an extra shim each side if needed.
Compass Atom 5.5; Oxy 2/3/4
XK K110 K120
Wargamer is offline        Reply With Quote Quick reply to this message
Old 04-12-2017, 03:52 PM   #4 (permalink)
It's also 2-piece dampers. Make sure you have the black piece that goes in first. these are some of the toughest dampers I have ever used.
-Ben
Old 04-12-2017, 05:41 PM   #5 (permalink)
Originally Posted by Wargamer View Post
+1
+1
50 - hard 3D flights, check for play and add shims until head it tight with no play.
RichKnapp is offline        Reply With Quote Quick reply to this message
Old 04-12-2017, 06:50 PM   #6 (permalink)
Who gets 50 flights without crashing and replacing spindle?
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird, Oxy 2, OXY 3, Oxy 4 All on Dx8G2
AMA 732104
MiataJohn is offline        Reply With Quote Quick reply to this message
Old 04-12-2017, 08:21 PM   #7 (permalink)
Default Added shims
I added a shim to each side, seems to have tightened it up good. I had a mild motor on 3S on it last year and put on an Xnova 4S this year, the head sure broke in more than I expected. Thanks for the info guys. I love this little machine!
Old 04-13-2017, 01:01 AM   #8 (permalink)
I managed 366 flights crash free and still counting
I replaced nothing on the O3. I do have a belt coming over though.
|Michalis|
Old 04-13-2017, 03:33 AM   #9 (permalink)
Wow, great! I believe it will be a new record: 366 flights without crashing and replacing anything.
betty is offline        Reply With Quote Quick reply to this message
Old 04-13-2017, 03:40 AM   #10 (permalink)
Some are that good...
Sent from my SM-N910T3 using Tapatalk
Old 04-13-2017, 04:41 AM   #11 (permalink)
Thanks.
I am practicing almost everyday to improve my skills and will eventually crash at some point
|Michalis|
Old 04-14-2017, 08:52 AM   #12 (permalink)
Made it to almost 800 before selling mine. It's called babying your baby by flying within your limits..lol
If it had a touch less power I would have crashed it at least 4 times. Always had just enough to pull out of trouble at the last second.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 04-22-2017, 11:36 AM   #13 (permalink)
Another area to check for is the DFC arm. I just reloctited mine when I noticed a screw was a little loose. But the symptom was the same
Sent from my Pixel using Tapatalk
mattbeau is offline        Reply With Quote Quick reply to this message
