Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 04-15-2017, 10:17 AM   #1 (permalink)
Default Servo elevator hitting
Hi
Are you having servo elevator hitting the Main Shaft Bearing Block ??
I had to dremel in the Main Shaft Bearing Block
hirobo is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 10:24 AM   #2 (permalink)
Did you do microbeast setting "L?"
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 11:01 AM   #3 (permalink)
DPW
Default Align Turnbuckles
Originally Posted by hirobo View Post
Hi
I had to dremel in the Main Shaft Bearing Blockl]
Mine are close
but
Looks like your rework is good and will never cause you any problems..
Mine
I would not think this would make any difference but both my 470s have the optional Align turnbuckles.
470L Counter Thread Main Linkage Rod Set H47H004AX $5.99
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Old 04-15-2017, 11:14 AM   #4 (permalink)
I'm using Vbar neo cyclic ring 85
Old 04-18-2017, 10:06 AM   #5 (permalink)
mine hits the top of the anti-rotation bracket before the bearing holder
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 05-01-2017, 11:03 AM   #6 (permalink)
When I went up full collective and cyclic forward, I had the same issue. I tried break away servo horns and normal servo horns. I wound up using a Dremel to get the clearance I needed. I adjusted my vbar cyclic ring down to 80 and now I have no issues. All other mechanical parameters in the FBL were good. Everything mechanically level.
My other experienced heli friends were ok with my decision. It may never have issues moving the servo that far in the air but I have peace of mind now.
Unihiron is offline        Reply With Quote Quick reply to this message
Old 05-01-2017, 02:59 PM   #7 (permalink)
Wouldn't that modification weaken the top bearing block especially the plastic bearing block?
Sent from my SM-G920F using Tapatalk
denis747 is offline        Reply With Quote Quick reply to this message
Old 05-01-2017, 06:06 PM   #8 (permalink)
Default Top bearing block
Nice smooth blend out.external stiffeners not affected.
but
It would be nice if Align came out with a new top plastic and metal bearing block with a little more give and maybe a solid cross section aft of the bearing.holder
Memphis3 is offline        Reply With Quote Quick reply to this message
Old 05-02-2017, 12:26 PM   #9 (permalink)
It's still pretty solid. If anything, I think the plastic is better to mod because you don't need to subject the plastic to a lot of vibration and stress while grinding.
G700 Comp, Oxy 5, XL P380, Vcontrol; Kraken on the bench.
Helicopters are my fidget spinners.
Old 05-03-2017, 07:16 AM   #10 (permalink)
Just wanted to give everyone an update. I took my heli up for a maiden yesterday. It didn't hit the cyclic ring once during flight, in the vbar logs. So technically you should be ok even if you do not change the vbar settings. I just didn't want my servos to bind up. However, I don't see any harm in grinding down the bearing block to get the travel you need.
Old 05-03-2017, 12:11 PM   #11 (permalink)
Needed travel?
Why would you ever need to go full collective and full forward cyclic?
BigEdge is offline        Reply With Quote Quick reply to this message
Old 05-03-2017, 01:59 PM   #12 (permalink)
Originally Posted by BigEdge View Post
Needed travel?
Probably never. I think I mentioned that in my posts up there. But it gave me peace of mind knowing I have full travel that is all. None of my other helis had that problem. Now the FLB knows what it's full limits are and does not bind the servos in any way.
