Register | FAQ | PM | Events | Groups | Blogs | Calendar |
06-22-2017, 06:51 PM | #1 (permalink) |
Which governor?
Given the choice of using the hobbying 60A V4 built in governor, or the Microbeast+ governor (taking RPM input from HW), which would be the better option?
Logic would suggest that the FBL has more info than the ESC does (such as knowing when you increase pitch) to properly keep the headspeed constant, but I have no experience with governors, so what do you think?
SAB RAW and Kraken 700 nitro w/MKS X8, OS 105 and Hobbywing, EGODRIFT motors, T-rex 550X combo, Ikon2 all around with Jeti DS-12 (plus Oxy2 with microbrain for the backyard!) |
06-22-2017, 11:22 PM | #2 (permalink) | |
All my heli's use the FBL governor except the one that has a HW V4 ESC.
Mark So many things to fly, so little time.
06-23-2017, 06:52 AM | #3 (permalink) |
I am using govenor for the first time. HW 60v4 on my 470L with a brain2 fbl.
I am using the FBL gov simply because I figure you only need to make changes at one place. Regarding the proactive responce using the fbl gov, with the processing speed of the esc I don't know if you would actualy notice the difference, but electronicly it would be faster and I would guess you are talking milli seconds. But as I said, I don't have any previous experience so what do I know.
Bob1 6s with Spirit Pro. Bob 2 with Spirit Pro. Bob 3 waiting on Spirit Pro. Jeti DS-16. Whovian. |
06-23-2017, 07:22 AM | #4 (permalink) | |
In reality, some ESC's work better than others and some FBL's work better than others. Nothing is perfect.
07-03-2017, 08:11 AM | #5 (permalink) | |
Se so many vids using FBL gov having bogging and then mentioning having to link back up and do more tuning.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4, X5 stretch 220 Flame Emax Bullet Force V2 VTX |
07-03-2017, 12:00 PM | #6 (permalink) | |
I don't really have an issue with tweaking FBL governors because I use FBL's that are integrated with the Jeti so it's actually easier to tweak the FBL than the ESC which usually needs a PC or a box. If you don't use an integrated system, yeah, it's a pain.
07-03-2017, 12:12 PM | #7 (permalink) | |
07-03-2017, 02:09 PM | #8 (permalink) |
I recently switched from the v-bar governor to the stored governor function in the 60A V4 and the model flies just the same.
The electronics are so good that it probably takes no time at all to work out the rpm is dropping in the ESC. |
07-03-2017, 03:17 PM | #9 (permalink) |
Did the same also, had Vbar, it did take some tweaking. Had overshoot once then tail wag, etc. Yup the V4 electronics have a faster CPU etc. and works better than the older versions. Went to all V4s and no more wasted time.
07-03-2017, 05:40 PM | #10 (permalink) |
Running ikon 2 gov, works great with 60A v4. If you have logging makes it a breeze to tune.
Nano CPS, Lynx 160CFX, Oxy 3TE, Align 470LM, DX6, Heli-X, 206b+[Dead in 4 month], FMA GT500. Flying since Feb 6th, 2016. |
07-03-2017, 07:21 PM | #11 (permalink) |
Same here, using Brain 2 gov. Was extremely easy to set up. It even shows you what rpm you are running. No guess work, no need to use a tachometer or a head speed app.
Sent from my SM-G920F using Tapatalk |
