Old 05-21-2009, 12:58 PM   #101 (permalink)
I got theDX 7 and doing that "funky"CPII & gyro shared channel crap...lol..works like a charm haven't had any issues using it AND get to install lighting with the freed up channel too
JR9303 / JR9503 / Futaba10CHP
nightflyr is offline        Quick reply to this message
Old 05-29-2009, 08:03 AM   #102 (permalink)
Hello all. Just wanted to let you know I hadn't forgotten the review. I have just returned from a training seminar. Work continues. I did get out with the system this afternoon though. I tried flying with the system disabled while doing loops and inverted hovering. I then put it in an inverted hover (at least my version) and hit the switch to turn the CPII on). It did the roll just like it is supposed to and with only about 10 - 15 feet of altitude drop. I have to admit that even with my prior testing of the unit I was a little worried about abandoning control while the heli was inverted. I mean, a lot more can go wrong with the heli when it could roll/flip over in any direction.
Recovery was absolutely perfect though. It rolled just like it is supposed to do (I have the vertical sensor installed). The CPII engaged just as quickly as when I used the switch as a bailout during normal attitude testing. The primary altitude loss, as far as I could tell, was simply from my control of the blade pitch during recovery.
More to come.
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons
--T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons
-- DX7, Hyperion Duo, flight leader case
rockjock3 is offline        Quick reply to this message
Old 05-29-2009, 08:11 AM   #103 (permalink)
nice going..I'm grounded till my replacement parts arrive...
Old 05-29-2009, 09:23 AM   #104 (permalink)
Originally Posted by nightflyr View Post
Hmmmm Interesting...should be pulling a bit more from your packs, due to the fact something esle is operating your servos....
The draw of the system (per the specs) is < 10 milliamps. The only real draw difference might be that you servos operate more, especially in wind or if you have your stick priority really low (CPII has more control of heli). Under these conditions your servos are what might draw your system down faster. The unit is simply telling the servos what to do. It isn't the fact that something else is controlling your servos that draws the extra power (if the draw is significant) it is the fact that your servos might be moving more than if you where controlling the heli. This will be based on the amount of the control you give the system as well as the conditions you fly it in and how much you use it; i.e. high winds versus low winds, always on or switched only when you need it, high level of control versus low level of control.
Old 05-29-2009, 09:48 AM   #105 (permalink)
I understand that I only switch it on in high winds ( which seems to be every day lately) other than that I pretty much have it off, been thinking about removing it off the 450 and moving onto the new 600
Old 05-31-2009, 06:14 PM   #106 (permalink)
Looks good, But I do believe you just voided your warranty hope it works well for you
Warrantys are for whimps
I even got me a multi-tool with "Warranty Voider" silk screened on the side.
Kevo450 is offline        Quick reply to this message
Old 06-04-2009, 12:41 PM   #107 (permalink)
They are working on the second production run as we speak and expect to start shipping by Friday. They have the components and are simply testing and assembling them. They advised if you ordered prior to May 28th then your order should ship NLT June 12th.
Old 06-04-2009, 01:57 PM   #108 (permalink)
t2o
Thanks for the update. I better get busy. As if flybarless, CP-too'd isn't enough, I ordered a Davis Deisel head for it. This should prove to be very exciting! Hope it will fly for 30 minutes on one tank. If I have a Tx failure it will go miles and miles before running out of diesel.
t2o is offline        Quick reply to this message
Old 06-10-2009, 09:29 PM   #109 (permalink)
Default angle trim vs. tx trim
It seems most people are recommending using the TX trim with the CPII off then ON and leaving the ANGLE ADJ alone.
Is there a reason for this? When I first used the CPII, it had a slight left and foward drift. I used angle adj and gave it (not super sure) D-9 and L-9 and it seemed for fix it.
Just wondering if the angle adj should be avoided.
Thanks.. Geo
SDGeo is offline        Quick reply to this message
Old 06-10-2009, 10:14 PM   #110 (permalink)
Thanks.. Geo
Not at all, if it works for you so much the better, most are finding that a couple of ticks of trim is all that's needed to get there heli's as drift free as possible, or they tilt the sensor to compensate
Old 06-17-2009, 08:35 PM   #111 (permalink)
Here is my final review, after working with the CoPilot II this last few weeks. Hope you all enjoy.
Old 06-17-2009, 09:29 PM   #112 (permalink)
Nicely done!!!!
Old 06-18-2009, 08:28 AM   #113 (permalink)
Just bought mine yesterday, can't wait for it to arrive here in Malaysia
Trex 450 SE V2 - Futaba T7C 2.4ghz, HS65MG, GY401+S9257, CF blades, Bell 222 fuselage
HBK2 - CNC parts upgrade, SG90, Esky HH gyro, Extreme Blades, Bell 222 fuselage
Esky Robins 22 - CNC parts upgrade
Borneo RC remote control forum
CorollaGT is offline        Quick reply to this message
Old 06-18-2009, 08:53 AM   #114 (permalink)
Mine arrived yesterday. Won't have time to mess with it until this weekend.. looking forward to seeing it work for myself! These reviews and "how to's" are a big help. Thanks everyone.
wparmer is offline        Quick reply to this message
Old 06-18-2009, 10:40 AM   #115 (permalink)
Hey CorollaGT,
Paid for mine last week. Can't wait for it to arrive in KL!
Don't know how much it'll cost when the LHS get it here. Have you seen the price for the CPD4 CoPilot in Malaysia? Very expensive compared to ordering it direct.!
Steve.
KL, Malaysia.
volvoc304 is offline        Quick reply to this message
Old 06-18-2009, 07:50 PM   #116 (permalink)
Great write up.Very informative.
boomer6 is offline        Quick reply to this message
Old 06-18-2009, 10:06 PM   #117 (permalink)
Agreed, It was based on this review that I ordered the CoPilot2. I'm sure it'll work as expected.
rockjock3, thanks!
Old 06-19-2009, 03:38 AM   #118 (permalink)
Thanks for all the compliments everybody. It was truly a pleasure doing this. I am absolutely sure you will all have a blast with the product when you get it.
Old 06-19-2009, 08:05 AM   #119 (permalink)
Talking
Originally Posted by volvoc304 View Post
Hey CorollaGT,
Steve.
KL, Malaysia.
Ya loh, can't wait for mine too hehehe
Not sure, but gotta test this bugger first. If it's any good, then I think I'll grab a few pieces to sell here, sure worth it I guess
Old 06-19-2009, 08:40 AM   #120 (permalink)
Owh, anybody managed to "hack" it in a heli fuselage yet? Maybe some "itchy" handed guys out there, hmmmm no? Hehehe
I know manual says no but yeah, like I said itchy ...
