Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 06-13-2012, 11:45 AM   #81 (permalink)
Cool, can't wait to see the build.
Velosity 50 Nitro, 5.3 Fullsize vbar, Rails
X5 FES 5.3 Fullsize vbar, Edge
Futaba T8FG Super
Team Helidirect
Colonel Sanders is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 11:55 AM   #82 (permalink)
AndrewAZ Clone Account
Leave the inner race of the thrust bearings in both the main and tails in, trust me.. They are a PITA to get out and not needed. When you want to get the tail bearings out, heat up the grip a bit and smack it against a rubberized hard surfaced and they will fall out. If you still something in there to try and knock them out, the thust bearings are kind of soft and get deformed easily.
Otherwise, everything else has been documented and is fairly straight forward. Make sure to use red loctite on pretty much anything from the main shaft back..they WILL come loose with blue..
Heliman419 is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 04:47 PM   #83 (permalink)
Default Assembly Phase I
All artists need a blank canvas!
IndividualWon is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 04:59 PM   #84 (permalink)
Default Update 1
Alright guys.. I'm on Page 13 of the manual and I've only had one minor hang up, but NOTHING that diminishes the fact that this thing is SWEET! Here's the deal so far:
- Found an error on page 11 of the manual. Page 8 has two 10mm bolts and one 8mm bolt going through the back brace set. Then when you're doing the right side of the assembly on page 11.. The illistration has you using three 10mm bolts vice two 10mm and one 8mm like on Page 8. Nothing serious, but I was looking for a left over 10mm bolt and there wasn't any! But there was an 8mm! Then I went back to page 8 and poof! Found the mistake.
Overall nothing to really report and I'm 1/3 through the build. This of course is the easiest part of the assembly. Moving on...
Old 06-13-2012, 06:27 PM   #85 (permalink)
the build actually goes very smooth. I only had to reference this thread a couple times.
Trex- 250, 450~Oxy4~Gaui X7
Magooch is offline        Reply With Quote Quick reply to this message
Old 06-20-2012, 12:15 PM   #86 (permalink)
Default Temporary FIX for pitch link binding on the Gaui X7
To those concerned about possible binding of the main grip pitch links and the swash driver, here is a solution that works well and is easy to install. Until Gaui comes back with a permanent solution, this eliminates the binding.
All you need is a cutting wheel (or Xacto), two extra plastic main grip pitch links, and 10 minutes of free time.
https://www.helifreak.com/showpost.p...6&postcount=48
https://www.helifreak.com/showpost.p...6&postcount=35
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 06-23-2012, 03:40 AM   #87 (permalink)
Originally Posted by Matt Nasca View Post
T Until Gaui comes back with a permanent solution, this eliminates the binding.
So Gaui are working on a permanent solution or are we hoping they are? I really hope they are as i had an opportunity to see X7 in person and was extreme impressed... Its one solid machine but appears to have a bit of an Achilles heel i.e. swash driver..
360Wings is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 06:29 PM   #88 (permalink)
Default 99.9%
Very close to the maiden!
i1
Old 07-25-2012, 02:45 PM   #89 (permalink)
Default MAIDENED
FLEW IT! LOVE IT! X7 is the BOMB!
Name:	X7 Maiden.JPG
i1
Old 07-26-2012, 06:37 AM   #90 (permalink)
Nice man, CONGRATS!
Old 08-07-2012, 11:48 AM   #91 (permalink)
This thread has helped alot, Thanks
motrinwarrior is offline        Reply With Quote Quick reply to this message
Old 08-07-2012, 05:52 PM   #92 (permalink)
ya, it did for me as well.
Helico-pteron is offline        Reply With Quote Quick reply to this message
Old 08-27-2012, 03:13 AM   #93 (permalink)
Default Transmission backlash
Hello guys.
I am already a lucky owner of X5 fbl + Robbe HC3 and now I tried for the first time the X7 + HeliJive Kontronik 120 HV + HC3 SX.
What I would like to ask you now is how to evaluate and how to adjust transmission backlash:
a) pinion engine - 100T main gear
b) 66T crown gear - 14T front bevel gear
c) "coupling" between bevel gears (14T front and 20T tail) and transmission torque tube . heads.
d) 20T tail bevel gear - 20T tail driven bevel gear
How you adjust all these?
After the first flight I noticed that the main crown white appeared as a "filing / fuzz" at the root of the helical teeth, just where the pinion works at the stage of "meshing tooth" ... is that normal?
The 'coupling" c) that actually is not adjustable...."cross-joint" between torque tube head and bevel gears seems to me too exaggerated!
We are sure that there is nothing to be glued with epoxy there?
Thanks so much, I hope to collect useful information !
Diego
P.S. excuse me for my bad writing!
rcshot is offline        Reply With Quote Quick reply to this message
Old 09-08-2012, 08:21 PM   #94 (permalink)
To retain canopy pins. Dubro Body Klip Retainers
http://shop.dubro.com/products/produ...2245/101.0.1.1
Old 09-08-2012, 08:55 PM   #95 (permalink)
Nice, ordering a set for the TDR too!
Thanks Matt!
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 09-09-2012, 04:43 PM   #96 (permalink)
I make it with nylon wire. strong and cheap
but i will use tenax for the future. i think tenax will be the best one for use.
Olli
ID:	347790   Click image for larger version
neotask is offline        Reply With Quote Quick reply to this message
Old 01-24-2013, 08:28 PM   #97 (permalink)
Hey Matt,
I just graduated to a X7... great machine... Did I see that right and you are not using a battery tray?
jakozzz is offline        Reply With Quote Quick reply to this message
Old 01-24-2013, 08:49 PM   #98 (permalink)
Originally Posted by jakozzz View Post
Hey Matt,
Congrats man!! You got it, no battery tray. I just velcro the packs to the middle divider and then use the included velcro straps to hold them in. Never had an issue and it's easy!
Old 01-25-2013, 05:39 AM   #99 (permalink)
mee too, works great without the trays
Olli
Old 02-01-2013, 06:52 PM   #100 (permalink)
Default Official Gaui X7 Build Thread
Check out the new black X7 skids. Available now!
