Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 11-18-2008, 06:59 PM   #1 (permalink)
Default Power systems that work !
Following on from very successful stickies in the Tex and Logo forums on good power system comobos would be good for peeps to share their experiences here - make it tight and we can make another sticky for discussion:
Suggest:
Model:
Motor:
Pinion:
ESC:
Lipos:
Blades:
HS at defined throttle settings eg
Optional:
Servos (cyclic/tail):
Gyro:
Tail blades:
Comment:
John
Old 12-06-2008, 07:56 PM   #2 (permalink)
The Capi
Model: Furion 450
Motor: Scorpion HK-2221-6
Pinion: 11T
ESC: 55A V2
Lipos: The working kind
Blades: HDX 325mm
HS at defined throttle settings eg 3600-3700 with 100% flat
Optional: Using the Scorpion 55A V2
Servos (cyclic/tail): 65MG
Gyro: Spartan
Tail blades: Stock tail blades
Comment: Who needs collective management. I'm running +-13 collective, and +-10 cyclic with the fastest head setting. I need 20% expo before it starts to fly right.
Old 03-30-2009, 10:44 PM   #3 (permalink)
Team Taco Member
Model: Furion 450
Motor: Ma/Scorpion (2221-6) 4400kv
Pinion: 11T
ESC: Ma/Scorpion 60a
Lipos: FP EVO25 2170
Blades: RT 350mm's (yes, 350mm)
HS at defined throttle settings eg: Not sure.. Idle-up1 80% flat, Idle-up 85% flat
Optional:
Servos (cyclic/tail): Hitec HS-5065MG
Gyro: HG5000 / 5083 servo combo
Tail blades: Stock
Comment: SWEEEEET.. Flies like a 500 size.. very smooth and strong..
bpd964 is offline        Reply With Quote Quick reply to this message
Old 04-06-2009, 08:47 AM   #4 (permalink)
Model: Furion 450
Motor: Scorpion 2221-8
Pinion: 13t
ESC: Scorpion 60A
Lipos: Polyquest 2220ma
Blades: Rotortech 325/Align Pro Wood 325
HS at defined throttle settings eg100% @ 3000
Optional:
Servos (cyclic/tail): HS65/9650
Gyro: GY401
Tail blades: Stock
Comment: Flies great, the tail is especially impressive, compared to other 450 machines I have owned.
Fury Tempest/YS91/Hatori/Futaba
Thunder Chicken 50/TT53/Futaba
If your not crashing, your not flying enough!
r2160 is offline        Reply With Quote Quick reply to this message
Old 05-14-2009, 06:52 PM   #5 (permalink)
Model:Furion 450
Motor:MA -6 4400kv
Pinion:11t
ESC:MA 60amp
Lipos:SMC 40c
Blades:Thunderpower 325 and Hyperion 325
HS at defined throttle settings eg- 3600-3700RPM
Optional:
Servos (cyclic/tail): Hs5065mg and 9257
Gyro:Spartan
Tail blades:Stock and Radix
heli21 is offline        Reply With Quote Quick reply to this message
Old 05-21-2009, 11:24 AM   #6 (permalink)
Red face
Model: Furion 450
Pinion: 13t
ESC: Scorpion 60A
Lipos: Flightpower EV0 Light 2500Ma 20C
Blades: HDX-325
HS at defined throttle settings eg100% @ 3100 approx.
Optional:
Servos (cyclic/tail): HS65MG/Futaba-9650
Gyro: GY401
Tail blades: Stock
The Furion sure flies nicer than my HDX-450... Very nice machine
jaymanjibe
Trex 250, HDX 450, Furion 450, Trex 500, Outrage 550, Radikal G20, Fusion 50
jaymanjibe is offline        Reply With Quote Quick reply to this message
Old 05-22-2009, 06:32 AM   #7 (permalink)
Model: Furion 450
Motor: Hacker A20-6XL
Pinion: 17t from Revco, sold by Readyheli.
ESC: Jazz 40 LV
Lipos: Flightpower EonX 2200 30C
Blades: Edge 325
HS: About 3000
Optional:
Servos (cyclic/tail): Savox 0253/ Hitec 5083MG
Gyro: Spartan 760
Tail blades: Radix
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote Quick reply to this message
Old 06-03-2009, 12:19 PM   #8 (permalink)
Default Are any of these 4S
I just ordered one and need to buy the guts. I am thinking 4s. Any suggestions?
ksechler is offline        Reply With Quote Quick reply to this message
Old 06-03-2009, 10:15 PM   #9 (permalink)
Model:Furion 450
Motor:MA -8
Pinion:13T
ESC:Hyperion 50 titan V3.1W
Lipos:Outrage 2200 30C
Blades:Hyperion 325mm
HS at defined throttle settings eg 3050
Optional:AR6100 3 3"servo extensions
Servos (cyclic/tail):5065/9257
Gyro:Mini G
Tail blades:Stock
oooo baby that's a what i liiiike!
TheBigBopper is offline        Reply With Quote Quick reply to this message
Old 12-23-2009, 03:52 PM   #10 (permalink)
Model: Furion 450
Motor: Scorpion 2221-6
Pinion: 11t
ESC: CC Phoenix ice lite 50
Lipos: ?????????
Blades: C/Y
HS: About 3200-3750
Optional:
Servos (cyclic/tail): Futaba 3157/Futaba 9257
Gyro: Futaba 520
Tail blades: C/Y or stock
not all purchased yet but it is getting there
elane17 is offline        Reply With Quote Quick reply to this message
Old 01-03-2010, 02:30 PM   #11 (permalink)
Thumbs up POWER SYSTEM
FURION 450
Motor -----------------Scorpion HK-2221-8 V2
Servos----------------Hitec HS-5065MG Digital Micro X3
Rudder---------------Jr 3400 Mini
Gyro-------------------Futaba GY 520
Esc--------------------Kontronik Jazz 40-6-18
Receiver-------------Spektrum 6100
Thunder power---- 2250 4s 45c X3
Radix Blades
Radix Tail blades
Radix Paddles
Awesome Setup
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 02-04-2010, 08:27 PM   #12 (permalink)
Model: Furion 450
Motor: 2221-8
Pinion: 11T
ESC: Align 35a
Lipos: 2200 Zippys
Blades: YB carbon 325
Optional:
Servos (cyclic/tail): cy,jr 285 3400 on tail
Gyro: Fut 401
Tail blades: KB tails
Comment Mild setup very locked in feel, and this heli has some pop!!
Just Love that Wop Wop Wop sound!
Trex 500 Pro DFC, Trex 450L, Trex 500 Pro V2, Blade 230S, Blade 130S
Heli24 is offline        Reply With Quote Quick reply to this message
Old 05-25-2010, 12:33 PM   #13 (permalink)
Just reworked power system on my Furion 450. Stretched for 350 mm blades. 6S power.
Motor: Outrage 1700 KV
ESC: Castle Ice 50
Pinion: 13T
Lipos: Outrage NRG 1300 6S
Mains: Radix 350mm
Tail blades: Radix
Paddles: stock
Gyro: Spartan DS 760
Tail Serrvo: Fut 9257
Cyclic Servos Fut 3157
HS: goverened 2600, and 2750 (about max for gov setting on Ice with 13t)
All Up Weight: 950 grams.
Comments: At 2750 HS it is about equivalent, or slightly stronger than a full throttle 3S Scorpion -8 setup with good batts. Significantly longer flight times than 3S.
Jay
Knight Flight is offline        Reply With Quote Quick reply to this message
Old 05-26-2010, 10:05 AM   #14 (permalink)
Setup on my stretched, FBL Furion:
Motor: Scorpion 2221-10 3000KV
ESC: Jazz 40LV
BEC: CC BEC
Pinion: 12T
Lipos: Flightmax 4S 2200mAh 40C
Mainblades: Funkey/Rotortech 350mm
Tailblades: KBBD T-Rex 450pro Tailblades
FBL-System: Stefan Plöchinger AC3X
Tail Servo: Futaba BLS 257
Cyclic Servos: Hitec HS-5065MG
Canopy: Canomod Hybrid TattooColor
HS: 3000 and 3300rpm
All Up Weight: 940 grams.
Great Setup. Long flighttimes, great power and easy on the Batteries, ESC and Motor.
And off it goes
X-traquick is offline        Reply With Quote Quick reply to this message
Old 06-28-2010, 08:10 PM   #15 (permalink)
motor 2221-6
esc phoenix 60a
13t pinion
gyro jr 370
tail servo jr 3500g
super sweet and rocket speed
frito169 is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 10:02 AM   #16 (permalink)
Model: Furion 450
Motor: Hyperion 2221-10
Pinion: 12T
ESC: Kontronik Jazz 40-6-18
Lipos: Thunder Power ProLite 4s2100
Blades: Thunder Power 325mm
HS ~3100
Optional:
Servos (cyclic/tail): Futaba s3156 / JR 3500G
Gyro: Spartan DS760
Tail blades: Stock MA (the best AND least expensive that I've tried)
Comment: VERY powerful and cool running. Flight times are a bit shorter than that of a 3s2600 2221-8 setup if you push the heli hard. ~4-5 minutes. If you want an efficient and powerful setup, this is it. There are better servos than what I'm using out now but these fit and work well.
prototype3a is offline        Reply With Quote Quick reply to this message
