Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
08-25-2016, 04:54 PM | #1 (permalink) |
5.3 software to 6.0 mini vbar im stuck
so i updated from 5.3 to 6.0 in my mini vbar but yet the vbar doesnt work on the 6.2 program or 5.3 and i cant find a download for the 6.0 ??
08-25-2016, 05:47 PM | #2 (permalink) |
"Old" vbar (mini, Silverline) will only work with VBC, not with pc-software.
Stephan |
08-25-2016, 05:48 PM | #3 (permalink) |
thats what i was thinking i was just trying to go through the setup but im still waiting for my vcontrol rx to show up so i guess i have to wait !! i was just trying to check it out and go through the motions but guess i have to wait
08-25-2016, 06:47 PM | #4 (permalink) |
Edit: (thanks vin)usb is disabled on older vbars. Switch back to 5.3 or wait .. you won't need it when you get the vbar control. Just wait till you get everything than go from there.
logo 600sx, 480, vcontrol ..mcpsbl Last edited by Dsss; 08-26-2016 at 04:40 AM.. |
08-26-2016, 12:54 AM | #5 (permalink) |
Ver6 disables the USB port on older VBars. It can only be used with VBC and VLink RX.
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
05-23-2017, 04:32 AM | #6 (permalink) |
im trying to roll back a mini vbar to 5.3 that right now has 6.0. I understand that I have to load the recovery file but which PC software do I use to do this if the USB is disabled?
Trex 700L NEO / Mikado Logo 600SX Vbar 6.0/ Trex 470LM NEO, Oxy 2 CC Talon 25 NEO, 450 pro vbar 6.0pro/ Trex 700n DFC OS105HZR, Velocity50 Vbar 6.0pro -Oxy 5 NEO-/Trex 600efl PRO (Night Flyer) vbar/CC HV80 ......ALL VBAR CONTROL |
05-23-2017, 05:48 AM | #7 (permalink) |
You use the pc software 5.3.4 to load recovery software.
Sent from my iPhone using Tapatalk |
05-23-2017, 06:40 AM | #8 (permalink) |
Ty it worked!
Now the light on the mini Vbar doesn't come on but it does show it's connected. Is this normal? It now shows 5.3.4 but when alooking at my firmware options non of them are checked and I don't have the option to do so Sent from my iPhone using Tapatalk |
05-23-2017, 10:00 AM | #9 (permalink) |
After recovery software you need to update to the newest version 5.3.4. You will need to ask for the update through vstabi.info under devices
05-23-2017, 02:35 PM | #10 (permalink) |
Is the light not coming on normal behavior?
05-23-2017, 03:57 PM | #11 (permalink) |
Not sure on the light. If I remember the light blinks till it it initialized. May need bound to radio or something. May also be something with recovery firmware as it's not intended to fly with.
