ELY.Q - Vision 50 ELY.Q Vision 50 Helicopter Support |
02-07-2013, 03:39 AM | #1 (permalink) |
ElyQ 50 CXE
Hi All
How do you attach the tail gear (TT) to the tail rotor shaft? The gear assembly has a 2mm hole through it so I assume the small shaft ~2mm diameter x ~10mm length that came with the kit is used to secure it. Should I loctite (blue/green) the shaft in place or is there a better way (flat head screw and bolt)? Im just a bit concerned that if the gear gets stripped during a bad landing/crash then that more money flying out my wallet buying a new tail rotor shaft. I appreciate any advice you guys can provide. Dean |
02-07-2013, 05:25 PM | #2 (permalink) |
Once the shaft is in place, you use a grub screw to secure it. The inner hole of the tail shaft is threaded. I would thread lock everything.
Cheers, Simon |
02-11-2013, 12:04 PM | #3 (permalink) | |
Harry Thunder Tiger Raptor E720 CGY750 | Mikado Logo 700 CGY760R |SAB Kraken 580 CGY760R| Powered by Futaba 18SZ |
03-03-2013, 09:28 AM | #4 (permalink) |
Hazza is correct please use some heatshrink to insure pin stays in place. Also do not overtighten the grub screw or u risk breaking the pin.
Team Grandrc.com Team Novarossi Motors U.S.A PlanetHobby.com "PushGlo" "SwitchGlo" Byron Fuels 2018 |
03-11-2013, 08:28 AM | #5 (permalink) |
Thanks for the help guys.
03-11-2013, 07:54 PM | #6 (permalink) |
Deanen, I don't suppose you want a spare Comp XE airframe going cheap? Selling mine to fund another project.
