Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 02-03-2016, 08:22 AM   #1 (permalink)
Default DX9 and 3GX HELP !!
Just a few days ago i became the lucky owner of a DX9 and i like it.
BUT .. i simply cant understand how to set up a helicopter on it,
I somehow managed to set my 450L up on the DX9 with a 3GX but now i cant make it work.
Can someone please tell me what i do to get the swash to move correctly when using a DX9 and 3GX.
I dont understand the Channel Assignment menu .. do i make changes in there?
My servos are set up according to the 3GX manual .. Pit = Left servo and AIL = Right servo and ELE = to the elevator.
So what am i doing wrong .. !?
Yeah .. there is some gettin' used to with this new radio.
thanks in advance
VARIO Robinson R22, Savöx, Bavarian Demon Axon, Spektrum AR 9110
Align Trex 600E Pro DFC, 600MX Motor, iKON
GAUI Hurricane EP550, Z20, Bavarian Demon 3X + S9254 Tailservo, Radiomaster TX16S
Align Trex 450L DFC Head, 3GX
Sweetfrost is offline        Reply With Quote Quick reply to this message
Old 02-03-2016, 01:01 PM   #2 (permalink)
Never mind - i figured it out somehow.
First of all i had (in mental desperation) switched 2 wires on the 3GX that made it difficult to have the servo move correct.
So everything went ok until the gyro setting. But AUX2 was the magic word and also that problem was solved. So my old Gaui 550 is prepped for flight now.
Testflying the darn thing as soon ad the weather calms down. My 450L did its maiden today with the DX9 and after a few landings to tweak the gyro gain the bird was solid. But after 10 minutes my fingers was so shaky that i din't want to use the second pack and "Hurry'ed" inside again. Quite clever that houses are hollow.
Old 02-07-2016, 11:02 AM   #3 (permalink)
Default Please help me Sweetfrost
Sweetfrost,
I have an Align T-Rex 600E Pro DFC with an Align 3GX and a Turnigy 9XR that I can't get figured out.
On the 3GX, the ESC, and all servos are plugged in in the order of: TRPEA, so as to physically match the description on the 3GX.
Considering, should my radio be set up reflecting THR - ch.1, RUD -ch.2, PIT - ch.3, ELE - ch.4 etc?
And what about the channel order in the Radio Setup screen?
In any case, if you could provide me with what you have in your "mixer," or better yet, send me photos, I would be in debt to you
Thank You so very much in advance for your help with this.
- Josh
Santa Cruz, CA
USA
joshair is offline        Reply With Quote Quick reply to this message
Old 02-11-2016, 01:52 PM   #4 (permalink)
hang on .. working on it.
Old 02-11-2016, 02:21 PM   #5 (permalink)
Well i'm not familiar with the Turnigy Tx nor am i saying that my settings are 100% correct but it works for me on both my 550 and 450L. So here's the port assignment on my DX9:
1 THRO: Throttle
2 AILE: Aileron
3 ELEV: Elevator
4 RUDD: Rudder
5 GEAR: Inhibit
6 AUX1: Pitch
7 AUX2: Gyro
Important: When using sats directly on the 3GX and not a Rx the gyro needs to be on AUX2 on the transmitter. And again this is when using Spektrum.
And i am not using any "mixing" other than the swash-mix.
You can also try watching the FreddyCanFly videos on Youtube - maybe you find his explanations easier to follow.
hope this can clarify things a little and it works out for you.
regards
Old 09-18-2016, 02:42 PM   #6 (permalink)
Smile
1 THRO: Throttle
2 AILE: Aileron
3 ELEV: Elevator
4 RUDD: Rudder
5 GEAR: Inhibit
6 AUX1: Pitch
7 AUX2: Gyro
Ok that takes care of the rx port assignments, but what do you set for the Channel Input Config?
Help would be appreciated as I have not used a 3gx before. Thanks in advance.
wtowns is offline        Reply With Quote Quick reply to this message
Old 09-21-2016, 06:31 AM   #7 (permalink)
Originally Posted by joshair View Post
Sweetfrost,
- Josh
Santa Cruz, CA
USA
You match channel assignment as per TX assignment. 3GX assignment in manual is for example, if your TX differs like yours match them.
Pick helli mode, ccpm standard 120. channel 4 for pitch servo. With sats channel 7 is rudder gain. If you use a separate receiver and patch cables to the 3GX rudder gain is what ever port you plug the yellow wire into. 6 or 7 and make sure those switches are assigned
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
