Old 03-02-2016, 08:52 AM   #1 (permalink)
Default Cpx issue
Hi guys my first post. I have a nano cpx when I give her throttle the swash wants to dip down to the right if ur in front of the heli. I have my force rc helis and my blade 400. I don't think its my dx6i. All my mixes are turned off my monitor on the transmitter doesn't show anything moving besides throttle. Hoping for some ideas to try thank you guys iv already learned a lot from this site.
Shortdude135 is offline        Reply With Quote Quick reply to this message
Old 03-02-2016, 12:16 PM   #2 (permalink)
Try cleaning the servos first, I think there is a link in the new to cpx tips and tricks section. If that doesn't work you will probably have to replace it. I had one that just go up and stay there with out responding to stick commands and had to replace it.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 600N, 700N
HeliLust is offline        Reply With Quote Quick reply to this message
Old 03-02-2016, 02:51 PM   #3 (permalink)
When u apply pitch do all your Servos move ?
A) Is one of them moving in the wrong direction ?
Is your setup under menue REVERSE correct ?
B) Or is one of the servos not moving while the other two do ?
Then check the cable connection on the board.
Two see, if the servo is dead, connect another one into the port of the bad one.
Besides, when I apply pitch my dx6i shows channel THR AND AUX moving, when throttle hold is off.
Greetz, Frank
geofred is offline        Reply With Quote Quick reply to this message
Old 03-05-2016, 03:46 PM   #4 (permalink)
Are you in 3D mode? Try setting trim controls exactly to middle. That was it for me.
rollo.martins is offline        Reply With Quote Quick reply to this message
Old 03-05-2016, 06:16 PM   #5 (permalink)
Shortdude,
Welcome to HeliFreaks from a fellow short guy.
I always noticed that I had to give the aileron a little nudge to the left before I got her in the air. If I sat on the ground, the right swash link would just keep going lower and lower.
Check the things that have been suggested before to make sure there are no programming errors. If you don't find any of these, try the left aileron trick and get the heli in the air as soon as possible.
Best of luck and happy flying.
I have to turn the music down while driving so I can see better.
MariaFan is offline        Reply With Quote Quick reply to this message
Old 08-02-2016, 12:51 PM   #6 (permalink)
Default swash tilting
Make sure you have servos plugged into the correct spot.I once had servos set in the wrong spot and swash would do strange things when throttle applied.
Blade 300 CFX, nano cpx , mcpx bl, dx6,
turko is offline        Reply With Quote Quick reply to this message
Old 08-02-2016, 10:27 PM   #7 (permalink)
Default Cpx issue
Also try new battery ! I found it for me a lot of times the batteries would drain because I would use them back to back and those brushed motors would go through the batteries so then an old battery even though fully charged wouldn't give me the right Aileron response.
NJF3 is offline        Reply With Quote Quick reply to this message
Old 08-30-2016, 02:17 PM   #8 (permalink)
I second the battery issue, use a new battery and test again
Nano CPX, MCPX, Raptor Titan & DX7
hellyflyer1 is offline        Reply With Quote Quick reply to this message
