Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 02-20-2017, 09:30 AM   #1 (permalink)
Default Tight mesh with XL clutch
Not finding much out there an still fairly new to Synergy. I have an n7 that I just installed the new XL Clutch in. It came with a new pinion as well. After I get everything together, I noticed the mesh between the pinion and the main gear to be real tight.
I am not seeing where I can adjust the motor to move forward. Before I start adding shims I just want to make sure that the stock main gear will work with the new pinion in the XL Clutch. Or is there a better way to go about this?
T-Rex 550 ikon, T-Rex 700E v2 brain2
Goblin 500 brain, goblin blk nitro braid2,Goblin 770 ikon
RCHN 761
jflowers84 is offline        Reply With Quote Quick reply to this message
Old 02-20-2017, 11:29 AM   #2 (permalink)
Stock gear is fine, I've had to add shims to both my n7s to get proper gear mesh with the XL and normal clutch, didn't make a difference.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 02-20-2017, 06:25 PM   #3 (permalink)
Sounds good what did you use for shims?
RCHN 761
Old 02-20-2017, 08:56 PM   #4 (permalink)
Nevermind forgot some were included with the kit
RCHN 761
Old 02-20-2017, 09:55 PM   #5 (permalink)
I forget if it was the n7 or the n5, but one of them the shims on the kit were too loose (stripped a main gear) and without them it was too tight, and I ended up cutting up a soda can to get the right shim size. You don't want a huge amount of play, just a slight tick back and forth is what you're looking for.
Old 03-04-2017, 02:39 AM   #6 (permalink)
I got the XL clutch awhile back but I can't remember if I got the right pinion that goes with it. Is there anyway I can tell if I have the right one?
Goblin 380, Goblin 500, Goblin 570, Goblin 700c, Goblin nitro, Synergy N7, Blade 180cfx,
DX9,icharger 4010 Duo
Sponsored by Visa
Matt Sherman is offline        Reply With Quote Quick reply to this message
Old 03-04-2017, 09:15 AM   #7 (permalink)
They all come with the right pinion. It has the same pinion as the stock clutch.
dbcaster is offline        Reply With Quote Quick reply to this message
Old 03-04-2017, 09:36 PM   #8 (permalink)
Also, what is the right gear ratio for the gov when using the XL clutch?
Sponsored by Visa
Old 03-04-2017, 10:23 PM   #9 (permalink)
Old 03-12-2017, 09:41 AM   #10 (permalink)
I had to use 2 motor shims on my motor or else the pinion put too much pressure on the main gear and inhibited the main shaft from turning freely.
Sponsored by Visa
