Old 05-26-2012, 02:00 PM   #21 (permalink)
Test flight went fine. I'll leave it the way it is now. Long balls on outer swash and short balls on inner. I used 2 main shaft washers on the AR pin, turned out to be the perfect thickness.
Couple pics and test video attached.
[ame]http://youtu.be/mn3OLRgOlkI[/ame]
ID:	319732   Click image for larger version
khoysagk is offline        Reply With Quote Quick reply to this message
Old 05-26-2012, 02:32 PM   #22 (permalink)
Others have used the long servo balls on the outer swash arms and then used a Gaui ball with through hole to make a AR pin with ball to match. I have some spare Gaui balls with through hole if your interested in a couple PM me and we can work it out. It would be nice to have a simple good solution to reduce the mechanical gain.
Don
dbennettya is offline        Reply With Quote Quick reply to this message
Old 05-26-2012, 06:45 PM   #23 (permalink)
Don
Thanks Don, I appreciate the offer. But I'd still have to find a long enough screw and spacer to make the pin.
Old 06-07-2012, 10:51 PM   #24 (permalink)
Did anyone else have to lower their dial one on their beastx? Im sitting at start of red at 6 degrees now, which is what i was on with the old head. But i've had to lower dial 1 from 8:30 to about 7:00 to get rid of the shakes.
youturnjason is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 11:41 PM   #25 (permalink)
I set mine up per the instructions. on the DFC head I tightened the links all the way in and backed them out one full turn. Made sure the swashplate was level and set up on the 7200bx went fine. No problem with 6 degrees.
Alees Rush 700 x3, Alees Rush 750, XLPower 520, NX4, 250 quad racers, Tesla Power servos, Force batteries
cajkat1073 is offline        Reply With Quote Quick reply to this message
Old 06-08-2012, 06:50 AM   #26 (permalink)
I did. Don't remember how much though.
Old 06-09-2012, 01:58 AM   #27 (permalink)
Actually turns out it wasnt the dfc head. I made a silly mistake. I replaced 2 of the inner swash balls with shorter ones for more resolution, but installed the DFC head on the 2 longer ones I didn't replace. I've taken the longer ones out to avoid that mistake in the future.
