Master CP Walkera Master CP Helicopter Support |
04-18-2015, 08:06 AM | #1 (permalink) |
Which servo is which PLEASE HELP!
I just received metal geared servos in the mail and installed them. Now, the heli just flips to the right. When checking the Deviation settings that I downloaded, it has the servos listed as #s 1,2, and 3.
Can anyone please tell me which servo is the aileron servo, the elevation servo and the pitch servo? It really sucks that there is no support whatsoever for these helis, if I could ever figure mine out, I would make videos for support, but I ordered a pack of connectors, all of them are different lengths, and I don't think two of them are the same length, assuming you want the same length for each servo, etc. |
04-18-2015, 04:32 PM | #2 (permalink) |
Hi Keithgordon
On the CP with the AX2367 H-D ( fittings to the rear) Looking from the back of the heli RH side Eli next across Ali ( Ali is the LHS servo from the back) third servo connection is the pit ( which is back RH side) Hope this helps Cheers watho
Master CP devo 7E Walkera 450 DO3 Blade 4503D conv to FBL Spectrum DX6i Building 550x and a phoenix sim fly,crash,order parts,repair and repeat |
04-22-2015, 10:44 AM | #3 (permalink) |
Thanks for the replies, I searched endlessly to no avail. I hate that there is no support for the walkeras, and the manual is a joke....
I appreciate the replies, I would not have found it any other way, now if I could just get this thing adjusted properly, I might be able to fly it. I've had it for a month now, and using the factory defaults, it stripped all the servos on the first flight. That isn't very encouraging |
04-25-2015, 03:58 PM | #4 (permalink) | |
I feel your pain My first cp heli was the Master CP and I did have a lot of crashes There is a lot on YouTube just keep searching ,even look at the way any of the heli's are setup (remove blades for safety ) OR UNPLUG THE MOTOR mid stick (throttle) servo arms at 90* ,level swash plate and then adjust so you have zero pitch So what I'm saying is work from your servo arms up to your blade grips ( bottom to top) You could also help your self with softer pitch and throttle curves Pitch curves 30% 40% 50% 75% 100% Throttle curves 0% 25% 50% 75% 100% or as close to linear 0 to 100 Hope this helps , just keep posting I get here from time to time and will be more than happy to help where I can I'm no expert but have taut myself lots in the past 3 years in this hobby A lot of it has come from the folks here on HF cheers watho
