Old 05-19-2013, 11:35 PM   #1 (permalink)
Default Uh oh. Did I break it?
I picked up a Nano CP X today and had some problems. I used Blade's recommended settings for the DX6i but it kept changing parameters and I had to re bind it a few times.
Once things got sorted it flew pretty well but I did crash it a couple of times in the yard.
Now it's picked up a nasty shudder when I raise the collective. All the moving parts look OK but something isn't right. Here's a YouTube clip to demonstrate:
[ame]http://youtu.be/rv2qohIG91Q[/ame]
Any idea what may be wrong?
Otto Rotation is offline        Reply With Quote Quick reply to this message
Old 05-20-2013, 08:45 AM   #2 (permalink)
Main gear has slipped down the shaft, allowing the pitch to go way more negative than it's supposed to be. Grab the head and see if it has a lot of up-and-down play. If so push up the main gear until it's snug, and put some temporary glue on it to hold. Like liquid electrical tape, hot melt, or white glue. You don't want to use CA since you will probably need to get it off someday.
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote Quick reply to this message
Old 05-20-2013, 11:17 AM   #3 (permalink)
+1
Yep sounds like main gear slipped to me. I uses Elmer's glue on mine so it is easy to remove. Just put a coat of glue in with a tooth pick and let it dry then do one more coat and your ready to go!
Empire Hobby- Gaui USA- Halo Blades- DC Canopy- Lynx-Cookeville Hobby
hadiclownsalty is offline        Reply With Quote Quick reply to this message
Old 05-20-2013, 02:10 PM   #4 (permalink)
Thanks guys, I looked up 'slipped main gear' and it sounds exactly like my problem.
The blue LED went out a couple of times when I was spinning up the motor. Hopefully I didn't damage the board, too. It wasn't even that hard of a crash.
Old 05-20-2013, 02:24 PM   #5 (permalink)
i just use a little bit of permatex ultra grey. pops right off when you need it to. one other thing you mayu check (i have this problem daily) is make sure your shaft collar is pushed down all the way, after your main gear is secure anyway. to do this just hold the heli applying pressure to the shaft pushing upward, and take some kind of stick, i use an ice pick, and push the collar down. i have to do this every 5-10 crashes
DX7s - Blade 450 3D - Blade Nano CPX - Blade SR, Belt, GP780, DS520 - Blade 120SR - Blade CX2, Aluminum Head - Blade ScoutCX - Walkera V200D02 HK ECO6
--INVERT EVERY BATTERY--
Bo0t3r is offline        Reply With Quote Quick reply to this message
Old 05-21-2013, 04:43 PM   #6 (permalink)
You guys were right. Re-seating the main gear on the shaft fixed the shudders.
But, it also appears the 3-in-1 is broken. It will no longer bind unless I literally touch the tip of my finger to the front side of the board. Then it lights up and binds. And goes dark again when I let go. Probably a broken trace.
Old 05-21-2013, 06:14 PM   #7 (permalink)
Yup. That big chip in the lower right is the receiver chip. A small jolt in just the right direction will crack a solder joint. Megas Micros is your friend, he'll fix it up for $25.
When you get it back, put foam tape on the canopy where the corner of the board contacts it. Or stretch a piece of fuel tube over the bottom.
