Old 03-10-2017, 12:54 PM   #201
Thoemse
Tested the 23t and new boom mount today after rebuilding it because of a servowire mishap. At 1950 RPM the tail is solid. 22t was ok for me but so is 23t. I just increased the tailgain a bit.
The heli kicks ass!
T-rex 700X, Protos 500, Hughes 500E (450 Pro), T-rex 450 V2 pro
Thoemse is offline        Reply With Quote
Old 03-10-2017, 12:57 PM   #202
Grumpy_Old_Man
That's good to hear.. I guess the acid test would be something that really puts the tail hold under a severe test, like maybe sideways or backward loops or similar.
Gob 700 Speed | Gob 770 Carb. Comp | Gob 630 Comp | Trex 700X | KDS Agile 7.2 | Compass 7HV U | Trex 600Pro (626 stretch) | Kasama Dune 600 | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 03-10-2017, 01:43 PM   #203
cbrkhan
Can 700x have 115 tails in stock configuration ?
cbrkhan is online now        Reply With Quote
Old 03-10-2017, 02:45 PM   #204
Grumpy_Old_Man
Not with total safety no. There is about 8mm clearance between the main and tail blades with the stock 106mm blades, so 115mm would risk blades touching. You would probably be ok 99.9% of the time but in theory at least it's a risk.
Old 03-10-2017, 03:24 PM   #205
dchekas
Further, the stock gearing is ~4.73:1 on the tail rotor. I do not believe the 23T front TT gear is in the stock kit presently.
The 4.73 ratio should be plenty of tail authority across the vast majority of headspeeds being used, I don't think there would be a need or benefit to running the longer tail blades.
Are you planning to run some ultra low headspeed? There certainly are ways to improve the blade clearance to accommodate longer tail blades if you truly need to.
dchekas is offline        Reply With Quote
Old 03-10-2017, 04:08 PM   #206
Thoemse
I am still new to helis. I only do regular loops and some inverted flying so far. I could test it but I'd probably crash it. :p
Old 03-10-2017, 05:07 PM   #207
Grumpy_Old_Man
me too
Old 03-24-2017, 01:45 PM   #208
maanz641
Add another statistic to the list , 4th flight of my stock 700x with a vbar neo running 2200 today ,and I started doing some tailslides, death spirals flips and rolls , just pulled out of a tail slide into flip and lost the tail , sure enough, stripped the tyre drive gear , got it down safely thou ,have ordered the 23t replacement
FLY IT LIKE YOU HATE IT
maanz641 is offline        Reply With Quote
Old 03-24-2017, 02:41 PM   #209
Grumpy_Old_Man
Was it the red or the black gear that you stripped?
Old 03-24-2017, 03:18 PM   #210
dbirds2
After all this talk bout gears stripping i pulled my gears last night. They had too much backlash and a white powdery look to them. I have 50 flights on this heli with no problems. I replaced all gears, front ones w new black 22tooth and red rear ones. I also lubed them up a little. I havent had any issues so far mostly running 2225 rpms. Im starting to think this problem is due to some gears not being made well or off a little. The new tail case is a good idea but does anyone know yet if the new 22 tooth red gears will fit or do you have to use the 23 tooth. I honestly cannot go down to a lower tail ratio cause even at 2200 rpm and higher gear ratio i have to use really high gains to lock my tail in. I think im going to use the longer boom so i can use 115mm tail blades
dbirds2 is offline        Reply With Quote
Old 03-24-2017, 03:28 PM   #211
Grumpy_Old_Man
The old black 22t gears fit with a 5 minute modifiaction... so worst case the 22t red gears will need the same. i'd expect that gears being made now will be 'pre-modified' to suit the new tail box.. makes no sense to not do that.
Old 03-24-2017, 06:53 PM   #212
Locktite
Red 22t tail gear drops right into the new case.. no mods needs
Synergy 766 12s/ 766 14s /Align 700X/700N DFC
Black Thunder 700 x 2/ Black Nitro 650/ Black Thunder 700 T
Black Nitro 700
Locktite is offline        Reply With Quote
Old 03-24-2017, 09:44 PM   #213
dbirds2
Okay thats what i want to hear. Does the 22 tooth w new tail box set a better backlash.
Old 03-25-2017, 01:22 AM   #214
Locktite
Mesh was perfect.. no need for any shims..
Black Nitro 700
Old 04-02-2017, 12:36 AM   #215
cbrkhan
So I am staying with the 22t gears. I modded mine like grumpy did. I also have red 22ts but I did not want to sell old supply of gears that I have from my 700dfc v3 days
I tried fit and feel of both. Red need no shimming at all. Black needs 0.01 mm shim to be lash free
Old 04-02-2017, 12:04 PM   #216
dbirds2
I would have so much tail authority issues with the 23 tooth tail gear. Even with the 4.73 tail ratio i have to really up my gains and pre comp to lock in my tail at 2150
