Old 04-01-2012, 08:07 PM   #181 (permalink)
Originally Posted by Mercuriell View Post
My last video should cover that
I've done with the servo type/direction and limits. Now into setting the gain. At the moment no flying yet so I just set the recommended initial gain which is 30. In tx gyro setup, I key in the value which is 30 but its not in HH but in rate mode. How do I set the 30 value wt the T8FG?....is it <50 (rate) and > 50 (HH) on the T8FG?
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 03:35 AM   #182 (permalink)
Originally Posted by OverTemp View Post
Mine warns me when I turn it on if the flight mode is other than normal... Doesn't yours? Are you ignoring it?
Of course it warns me, that's not the problem
The problem is when I fly in idle 1 or 2, then hit throttle hold and land (practicing autorotations, tuning engine, etc.). It could be possible that I forget to switch it to normal before flipping out from throttle hold, that bothers me.
robi1kenobi is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 07:39 PM   #183 (permalink)
Ahhh....
Don't know about that one. You can program a slow ramp-up when you turn off throttle hold.. like have it ramp up over 2 seconds, or whatever you choose, to try to take some of the impact off. Otherwise I think you just need to be the brains of the operation, not your radio
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote Quick reply to this message
Old 04-03-2012, 02:39 AM   #184 (permalink)
OK, I'll just try to be really careful then
Old 04-05-2012, 10:29 PM   #185 (permalink)
Default Gyro type
Can I choose "GY" type gyro although Im not using a Futaba gyro (mine is Spartan Quark)?
Next project:
Old 04-05-2012, 10:32 PM   #186 (permalink)
Yes, GY just means you are in heading hold...
Old 04-05-2012, 10:55 PM   #187 (permalink)
Originally Posted by guitarherowanab View Post
i have switch a setup as my gain switch. it is pretty confusing figuring it out and the instructions are no help, but once you get it figured out its pretty easy. go to the gyro then change from "cond" to "sw". then go over and assign it to sa(or whatever switch you want)
now with the switch in the position you want to be hh mode, select "gy" and "avcs".
now the tricky part. flip the switch to where you want it for normal mode. change the "#1" to "#2". now change "avcs" to "norm"
that sounds more complex than it is, but if mecuriell can get a video up im sure a picture would be worth a thousand words....lol
can we choose "gy" although its not a futaba gyro?
Next project:
Old 04-05-2012, 11:00 PM   #188 (permalink)
Yes...
Old 04-05-2012, 11:01 PM   #189 (permalink)
isnt GY stand for Futaba Gyro?...and it can be both in rate (normal) and HH (AVCS) mode also.
Next project:
Old 04-05-2012, 11:02 PM   #190 (permalink)
Yes...
o..ok.....will test it later....thx
Next project:
Old 04-06-2012, 01:09 AM   #191 (permalink)
Default why wouldnt I tried it that way before?....
Thanks Christ,
I set it already, all this while I was thinking that the "GY" type will not work for other gyros.
Next project:
Old 04-06-2012, 01:22 AM   #192 (permalink)
Thanks Christ,
FWIW unless it is explicitly stated, I haven't seen a tail gyro that WON'T work with a specific radio.
Glad you got it all figured out
Old 04-06-2012, 04:45 AM   #193 (permalink)
well...its in the manual...GY for Futaba gyros, NORMAL for other gyros.
Next project:
Old 04-06-2012, 06:42 PM   #194 (permalink)
I've always used GY with HH tail gyros ... no problems.
Old 04-06-2012, 07:11 PM   #195 (permalink)
thx again Chris....flew it yesterday, just a low hovering and it flew smooth and nice.
Next project:
Old 04-10-2012, 01:31 AM   #196 (permalink)
When I used a telebee head holding gyro I could never get it to work. No matter if it's set on normal or gy. Anybody have a telebee head holding gyro to test it out?
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 05:25 AM   #197 (permalink)
Ok people this 8fg pitch curve is confusing me, please help!!!
I want to set the normal pitch curve to TT raptor 30 recommended settings for a newbie.
Which is 18 38 55 75 94
Now with the 8fg its negative from centre downwards,so do I just take +18 from -100 to get -82 and so on or do I have to go positive with a plus 18 and so on.
And to add to the confusion the Raptor has 2 mechanical setups for collective so should I set up for intermediates/3d and let the pitch curve do the taming down or do I setup for a newbie in which case the the collective is controlled mechanically (to a point) and I dont think a pitch curve will make much difference.
I hope some one can help,
cheers,
Paul
PKNEC is offline        Reply With Quote Quick reply to this message
Old 07-12-2012, 02:56 PM   #198 (permalink)
You don't have to make your pitch curve exactly as it is in the manual.
Take pitch gauge, make sure you have 0° at mid stick (you're mostly gonna fly in Idle Up later, so get used to 0° pitch at midstick), about -3° at full negative (in normal mode) and if you want it to be tame, let's say about 8-9° at full positive, and make your pitch curve from 0 (midstick) to full positive linear.
I'd do it that way.
Old 07-12-2012, 07:30 PM   #199 (permalink)
Hey guys let me show off my radio. Of my bling.
Old 07-16-2012, 04:01 AM   #200 (permalink)
Looks good mate!!
Align 700L TOP Spartan Vortex VX1n
Align 550DFC V3 Spartan Vortex VX1n (the dogs nuts!)
Blade 180CFX
Futaba 8FG
JAG1 is offline        Reply With Quote Quick reply to this message
