Go Back   HeliFreak > R/C Helicopter Support > HD-Helicopters - CELL 500 and HD750
HD-Helicopters - CELL 500 and HD750 HD Helicopters CELL 500 Factory Sponsored Support Forum
Old 12-13-2015, 07:18 PM   #1 (permalink)
Default BATTERY TRAY QUICK DISCONNECT
Looking for idea's for battery tray quick disconnect system.
Please tell me what your using and add a few pictures for a Cell 500
Thank you
Protos Max V2 Evoluzione770 yellow
Protos Max V2 770 Red.
MNaumer is offline        Reply With Quote Quick reply to this message
Old 12-14-2015, 01:06 PM   #2 (permalink)
my mod
https://www.helifreak.com/showpost.p...37&postcount=8
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 12-14-2015, 04:00 PM   #3 (permalink)
Great Thank you, Ordered it up
Old 12-15-2015, 09:32 AM   #4 (permalink)
Is this Battery Tray anywhere otehr listed? It's out of stock on MD Heli...
btw: It's a bit expensive... :/
freakystylez is offline        Reply With Quote Quick reply to this message
Old 12-15-2015, 12:39 PM   #5 (permalink)
if you are looking for it in Germany than go to HD-Helicopters directly http://www.hd-helicopters.com/ersatz...stigungsplatte
in the US - at SuperstisionHobbies they have it here http://superstitionhobbies.com/colle...tery-mnt-plate
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 12-15-2015, 01:18 PM   #6 (permalink)
MD tray you are looking for
https://www.rc-batteri.no/helikopter...md5-6qrbt.html
Old 12-15-2015, 01:56 PM   #7 (permalink)
Found it at MD helicopter usa, just under 40 bucks.
Thank you
Old 12-27-2015, 01:48 AM   #8 (permalink)
That md tray idea is cool but with all the batteries I have it would be a couple hundred in battery trays alone .... unless you unstrap the solo one everytime which kinda defeats the purpose. If you had a bunch that would be a sweet setup . They are just pricey.
ChrisCradit is offline        Reply With Quote Quick reply to this message
Old 12-28-2015, 09:13 AM   #9 (permalink)
Yep I hear you, but the way you have to force velcro thru the slots to hold the tray in place is a pain, much faster, easier to strap a battery to a tray and click in place. I wish HD would make a tray to solve this.
Old 12-29-2015, 10:49 AM   #10 (permalink)
Plus the straps only last so long before you need to replace them .
Old 12-29-2015, 11:10 AM   #11 (permalink)
Here's a somewhat cheaper modification which worked well for me all year.
1. Drill a hole (2mm in my case) just before the inner tray blocks on each side of the frame.
2. Cut and bend a welding rod long enough to pass through both holes and to keep both inner tray blocks in place.
I played around with different shapes for the rod and ended up with a slightly different solution than what the picture shows but the idea is still the same.
Futaba T14SG
T-Rex 150 & T-Rex 450L & HD500 Cell & Diabolo L
tz02 is offline        Reply With Quote Quick reply to this message
Old 12-30-2015, 01:43 PM   #12 (permalink)
Neat! I was planning on trying to make a latch over the current blocks, but that wins for simplicity.
mgrennie is offline        Reply With Quote Quick reply to this message
Old 12-31-2015, 03:22 AM   #13 (permalink)
So here's the pin shape I ended up with.
Reason to move away from the original design was that I was a bit paranoid about the pin to come out in air so I added the angled piece which goes between chassis and batterie once the pin is in. Probably sounds more complicated than it is
The second picture shows the pin installed.
Name:	2015-12-31 10.08.23.jpg
ID:	627132   Click image for larger version
Name:	2015-12-31 10.08.02.jpg
Futaba T14SG
Old 12-31-2015, 04:29 AM   #14 (permalink)
I just have one MD modd battery tray as I share my packs with G700 , its quite easy just stap the battery on the tray and click it in place
really hoped HD would have come with its own quick release tray so ppl won't have to do modd for there helis
hope Jens is listening
Old 01-03-2016, 07:34 PM   #15 (permalink)
I spent a little time with the micro mill this weekend and wanted to share the results of my battery tray mod. Mod consists of the rails made from aluminum angle (1.5mm thick), opening one mounting hole on each of the two latches, milling the face of the latches flat and drilling and threading a hole for a screw which serves as a locking bolt. Only mod to airframe requires one hole on each side to be drilled into the front frames to attach the latches. Also needs 4 1.5mm thick shims, 2 inside front gear mounts, and 2 outside rear gear mounts.
Easy to use, smooth and very positive lock with that satisfying "click" with no perceptible rattle. As I was making the mod I realized there are several ways of securing the tray to a set of simple rails including pins and custom made latch bars. If the need arises (hope never!) and I need to make a new set, I may explore these other options, but this worked out very nicely.
ID:	627831   Click image for larger version
ID:	627832   Click image for larger version
ID:	627833   Click image for larger version
ID:	627834   Click image for larger version
flyer09 is offline        Reply With Quote Quick reply to this message
Old 01-03-2016, 08:20 PM   #16 (permalink)
Here is my quick disconnect, modified the stock tray with the md quick release, had to shim the release to get the height right, but works great, no more feeding the strap thru the 2 slots. .
Please guys make a quick release from HD helicopters, it's such a great helicopter to have such a bad way to secure the battery
ID:	627849   Click image for larger version
ID:	627850   Click image for larger version
ID:	627851   Click image for larger version
ID:	627852   Click image for larger version
Old 01-03-2016, 09:19 PM   #17 (permalink)
Oh I hope you can take orders. I would totally buy one if you are willing to make them for others.
dgunawan is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 03:23 PM   #18 (permalink)
Hi,
yes if there is a quick exchange it would be fine, but I use
soft rubber to protect sliding the lipo.
With well adjusted straps the exchange is also possible in 15 sec.
See the vid.
I will change the lipo very quick and will only use one tray, also
If they will develop a quick exchange.
17. Januar 2016 (0 min 21 sec)
Cheers
Marco
marco@lottacustoms is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 03:35 PM   #19 (permalink)
my MD modd works very nicely but I'm very curious of what they have done with HD750
Old 01-17-2016, 04:57 PM   #20 (permalink)
Me too !
