Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Old 04-17-2017, 04:17 PM   #1 (permalink)
Default Tail upgrade
Hello,
I want to upgrade the tail assembly of the 270cfx.
I read somewhere that I can use a 450 tail assembly. Or was it the 360cfx that can use the 450 tail?
Please comment.
tomasito is offline        Reply With Quote Quick reply to this message
Old 04-17-2017, 06:16 PM   #2 (permalink)
Yes, and it works great.
https://www.amainhobbies.com/lynx-he...yx0788/p292261
And some more info....
https://www.helifreak.com/showthread.php?t=760061
Tom
Blade 150s. mCPs, MA Whiplash Gasser V2,
Kraken 580,MA 1005 Gasser, Concept 30,60 and iX14
Nytro97 is offline        Reply With Quote Quick reply to this message
Old 04-17-2017, 11:24 PM   #3 (permalink)
@nytro97,
Thank you very much... this is great info
Old 04-18-2017, 09:12 PM   #4 (permalink)
Originally Posted by tomasito View Post
@nytro97,
The 270 & 360 both use the 450 tail assembly same size boom different length
vronny is offline        Reply With Quote Quick reply to this message
Old 04-24-2017, 04:29 PM   #5 (permalink)
what´s the Magic of the metal housing ?
Installed it, but - to be honest - I see no really change to the polymer one.
best
Markus
schimaiw is offline        Reply With Quote Quick reply to this message
Old 04-25-2017, 05:59 AM   #6 (permalink)
My guess, better made as far as tolerances, less vibes, more durable. Looks?
-Ben
Old 04-25-2017, 07:32 AM   #7 (permalink)
best
Markus
Did you buy the lynx or blade? Most of the guys have problems with the blade tail it causes vibe but the Lynx is smooth as butter. I have the Lynx tail with metal tail grips on mine.
Old 04-25-2017, 12:38 PM   #8 (permalink)
bought the Lynx. Kept the plastic grips.
Found no significant improvement. It works o.k., but so did the stock tail too.
Small vibrations.
For me its not clear, what of the tuning stuff really helps.
best
Markus
Old 04-25-2017, 12:47 PM   #9 (permalink)
The "magic" of the Lynx case is that it made my tail robust against vibes.
With the stock case, the smallest ridiculous mismatch of tail blade balancing produced high levels of vibes and resonances, making the fin end oscillating about +/- 5mm and significantly disturbing the FBL's sensors (inconsistent bailout out).
That is now all gone and made flying much easier.
If your 270 tail has been problem free, there is no reason to switch. Be happy and fly!
Blade Nano CPS, 180 CFX, 270 CFX, Nano QX 3D, Spektrum DX6, DX9
Lupo99 is offline        Reply With Quote Quick reply to this message
Old 04-25-2017, 03:48 PM   #10 (permalink)
Well, the tail has vibrations. Not 5, but maybe +- 2mm.
On the bench without main rotor, touching the boom you feel what you don`t want to have...
Removing the tail-rotor (blades and grips) COMPLETELY REMOVES ALL VIBRATIONS.
Seems to be not a balancing problem (no change with different cm² of thin tape on the blades).
So what is left over, maybe a tail blade tracking issue..... ?
Old 04-25-2017, 04:10 PM   #11 (permalink)
Sounds like the tail boss spigots could be bent. Take the blades/grip/boss assembly off as a unit and holding one blade turn the hub using an allan key to turn the screw in the grip you are holding. If the other blade scribes an arc the spigot is bent, repeat on the other. You can straighten these with the blades attached by hand until they spin perfectly around the spigot. Either that or buy some more tail rotor hubs - they are cheap. Also bearings may need replacing.
crsorrell0653 is offline        Reply With Quote Quick reply to this message
Old 04-26-2017, 02:49 PM   #12 (permalink)
Spigots are perfect.
The only issue found is, that friction of one grip under load seems to be noticeably higher.
On disassembly, no defects found, bearings o.k.
By the way: The pressure bearing halfs (top / bottom) seem to be not identical !!?? In one half, the ball track is broader/deeper than in the other one....
To be honest, most guys most likely would not care about my Problem. The heli works, and all those throwing around the 270 care about other phenomena than vibes...
Seems as I need a "tail rotor whisperer", glas bowl, or an expert in heliopathy...
best
Markus
Old 04-26-2017, 03:51 PM   #13 (permalink)
I had bad vibration on a new heli's tail and put on a different new set of blades and it all but disappeared. One can only try these things. I think tail vibrations are very obvious only because they are amplified by the length of the boom and are easy to see. Like you said, some may not worry about it. Chris
