Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Old 01-06-2017, 12:09 PM   #21 (permalink)
Thanks for your hint BgSkyFlyr...
Very useful to me. I was short before becoming crazy...
Graupner MC-28 - HELIKOPTER: Protos 500 (MSH Brain2 BT & GR-12L) - Goblin 500 (MSH Brain2 BT & GR-16) - Goblin 700 (MSH Brain2 BT & GR-16)
Tragl is offline        Reply With Quote Quick reply to this message
Old 01-12-2017, 11:19 PM   #22 (permalink)
Smile
Originally Posted by Nickvangray View Post
So I got the firmware updated. Caleb over at hh walked me through it. I had to use the spektrum programmer instead of the spektrum updater and it took no problem.
Thanks for this. Surprised the updater does not work, but the programmer worked fine. Would have struggled longer if not for this thread
deonjams is offline        Reply With Quote Quick reply to this message
Old 01-13-2017, 10:54 AM   #23 (permalink)
Hi,
I ordered the programming cable for my 230s Night. It's flying well, but the cyclic rates are somewhat slow. Bumped the DR's with not much changes.
Is it advisable to flash the latest firmware although it's flying well?
Thanks,
David
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote Quick reply to this message
Old 01-13-2017, 12:13 PM   #24 (permalink)
Thanks,
David
Personally, if it ain't broke, don't fix it!
But, some have to have the latest just because it's there...... to each their own!
Bill_Van is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 11:19 AM   #25 (permalink)
Thank you people
I was also struggling to get a "new to me" 230s updated from v4.1rc0 to 4.36rc0 using the updater.
The programmer worked like a charm, thank you fellow Helifreaks!!
MB
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 02:21 PM   #26 (permalink)
Good to hear, is your swash level at zero throttle (stability/normal mode) out of curiosity?
AndyO is offline        Reply With Quote Quick reply to this message
Old 02-15-2017, 04:42 PM   #27 (permalink)
Hi Andy,
Yes, I 90'd the servo arms and then adjusted the swash links to get the swash level and the grips at 0° pitch before I updated the FW.
I have flown it, and it flew o.k., but it wanted to roll left all the time when not in stability mode, hence the desire to update the FW as I couldn't get it to go into calibration mode, I think the 4.1 FW version didn't have that option.
On the bench, it now wants to roll right as soon as I switch out of stability mode, but I think that's probably normal as it will lean a little to the right when in the air.
Next chance I get, I'll give it another flight and see how it goes!!
MB
Old 02-23-2017, 05:26 PM   #28 (permalink)
When I try and update the firmware in the 230s it says "Erasing and programming device...
The SAX file version is not supported."
Wth does that mean? It says I am currently on 4.1rc0.
Any help is appreciated.
R/ Nick
I had the same problem with my 230s. Blade support says don't update the firmware.
rjabend is offline        Reply With Quote Quick reply to this message
Old 06-23-2017, 11:18 PM   #29 (permalink)
I just updated my FW to 4.36 (12/2016). I had to use Spektrum Programmer from BgSkyFlyr's post (Thanks for that!) but wasn't getting the Program to recognize the receiver. I tried BgSkyFlyr's steps and still no go. What I did to finally get it to work:
1. Disconnect everything (USB and batts)
2. Launch the Spektrum Programmer
3. Connect USB (SPMA 3065) to computer
4. Connect SPMA 3065 to bind port of AR636
5. Connect the flight battery to ESC.
After that, Programmer recognized the AR636 and updated to latest version. Thanks to all!
Smiling while flying, praying when landing.
Dune 600/Logo 400SE/Armattan 355
Clipped Wings is offline        Reply With Quote Quick reply to this message
Old 07-17-2017, 09:55 PM   #30 (permalink)
I am receiving the exact same error message and have been using the Spektrum updater..( I followed the JJ inverted youtube video ) ....can someone please tell me how find the Spektrum " programer " so I can give that a try.....thanks
garyv440 is offline        Reply With Quote Quick reply to this message
Old 07-18-2017, 03:02 PM   #31 (permalink)
Not sure if you have registered on the SpektrumRC website, but if you have, and you have registered your AR636 then you can go to the firmware updates section and a link is in the update instructions text, I'll paste it below but I am not sure if it will work for you
http://spektrumrc.cachefly.net/apps/...rogrammer.html
If it doesn't, you are welcome to pull the .exe files from my dropbox link below, if that helps
https://www.dropbox.com/sh/i8b9apora...d5VSkrWca?dl=0
(hope that works)
Old 07-18-2017, 03:05 PM   #32 (permalink)
PS: I haven't messed around with the FW update process for a good while, but I think I found it worked best if you connect the USB cable to the PC/notebook before opening the software, then check that the "cable connected" status is shown before plugging into the AR636. I'm sure there's more than one way to get it to run smoothly though.
Old 07-18-2017, 03:20 PM   #33 (permalink)
Andy...I followed your advise and finally got it....FYI to all interested...I was unable to use the Spektrum " updater" because I kept getting error messages.... but found the Spektrum " programmer " software to install the updated firmware nicely....I then did a trim flight and now my 230S seems very stable....thanks again....Gary
Old 07-18-2017, 03:27 PM   #34 (permalink)
:thumbup
