Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 11-11-2012, 05:29 AM   #61 (permalink)
No, Achim, I am quite sure I did.
Right com-port, right BL Heli file, ...
Connecting Robbe-Box to computer, opening BL Heli, connecting Robbe box to ESC, connecting ESC to battery, trying to connect to BL Heli:
"Check ESC connection, power, signal" (this error message).
Disconnecting ESC from Robbe box, connecting battery to ESC, connecting (powered) ESC to Robbe box: everything is fine.
Checked this procedure several times.
What did I do wrong?
Walter
donaldsneffe is offline        Reply With Quote Quick reply to this message
Old 11-11-2012, 05:32 AM   #62 (permalink)
Sorry Walter, the last post was for pgleesonuk.
Robbe Box and Arduino are different.
For the most recent Revision of BlHeli Setup see my blog.
4712 is offline        Reply With Quote Quick reply to this message
Old 11-11-2012, 05:33 AM   #63 (permalink)
this is the file I used
please can you confirm which pins I need to connect
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 11-11-2012, 05:34 AM   #64 (permalink)
@pgleesonuk: Yes I will look.
Meanwhile: Please try to NOT connect the BESC and try Read!
Old 11-11-2012, 05:42 AM   #65 (permalink)
Here is the log file
Old 11-11-2012, 05:47 AM   #66 (permalink)
Here is, how the C2 Connection should be:
Edit: Your wiring is wrong
https://www.helifreak.com/attachment...7&d=1352583842
https://www.helifreak.com/attachment...8&d=1352583842
Old 11-11-2012, 05:50 AM   #67 (permalink)
OK, this is how I have it wired. I've tried changing red and white and this does not work either
My ESC works fine, and I can follow the TX programming for BLHeli V8. So I don't think I have broken anything.
My ESC is an Oversky (origin) 10A V3.
What order to I need to connect the Arduino board, the ESC and power to the ESC?
Old 11-11-2012, 05:52 AM   #68 (permalink)
Please look at Your wiring and my picture: it is very different!
The log shows: Connection to Interface is ok, but not connection to BESC.
Old 11-11-2012, 05:54 AM   #69 (permalink)
I have fixed my wiring now. I realise it was wrong. It is now like your picture.
If I can't connect to the BESC what might be the problem? Do you know which way wrong the connector should go on this ESC?
Old 11-11-2012, 06:02 AM   #70 (permalink)
Did You power up the heli? You have to...
Old 11-11-2012, 06:04 AM   #71 (permalink)
Yes I power up the hell, with the radio on, so it's ready to fly. Then the USB interface, then connect the interface to the hell
Old 11-11-2012, 06:11 AM   #72 (permalink)
The connection seems to be the way it should as shown here:
http://www.overskyrc.com/index.php?m...roducts_id=328
But re-check the connections at the Arduino and please post a new picture. I cannot see what You did...
Old 11-11-2012, 06:25 AM   #73 (permalink)
Here is my wiring now.
I used servo connectors so I can change it if required
thanks for all your help
Old 11-11-2012, 06:37 AM   #74 (permalink)
Seems to be OK, I have no further Idea for now...
EDIT: May be, You recheck all the connections to the ESC. Check all with a Multimeter, if they make really contact.
Old 11-11-2012, 07:25 AM   #75 (permalink)
Originally Posted by donaldsneffe View Post
The ESC has to be powered BEFORE being connected to the Robbe box...
Stupid me - now I know.... sure somewhere in the manuals or here in the thread, but me and manuals...
Walter
Mmmhh, Walter, I cannot confirm this!?
I get a connection to the box with plugged in the BESC and without powering up the BESC...
Of course, I get no connection to the BESC itself...
Old 11-11-2012, 08:12 AM   #76 (permalink)
Yes, of course, but when powering the BESC afterwards and disconnecting, reconnecting, I still had those "no connection to ESC, check data and power connections".
But when powering the BESC before connecting to Robbe Box, everything was fine.
Walter
Old 11-11-2012, 12:57 PM   #77 (permalink)
Do You mean: "but when powering the BESC afterwards, Reading and disconnecting, reconnecting"?
That would make sense...
You should click "Restart" or "Disconnect" before You remove the plug from the BESC.
I will do a more comfortable reconnection in the next update.
Old 11-11-2012, 05:24 PM   #78 (permalink)
Hi Achim,
I apologize - checked everything again now with a big ESC and everything worked fine with the BL heli box, no matter if I connected the battery to the ESC before or after connecting the ESC to the box.
Donno what the reason was, but I had quite a lot of troubles with the tiny ESCs.
Especially in Supermicro 3.5 A the soldering pads for the signal wires are extremely weak and break out of the ESC easily (you can this do very easy when pulling or whatever a little bit on wire/plug).
Destroyed some of those tiny ESCs
Anyway, everything is ok now, flew right now my first 5 batteries with my double brushless Nano CPX and am quite happy.
But it was a hard way - for me especially the micro ESCs, those stupid soldering pads...
Now I am using epoxy on the soldering joints to secure the pads, seems to work.
Thanks, anyway, unbelievably cool stuff
Walter
Thanks Walter, I will answer here, because I guess Your last post should have gone here.
There is nothing to apologize, I'm happy for every hint, feature request and even more any bug message. It helps me a lot to find any issues in the application and to make improvements.
I've done already a fix up for the check of BESC connection - for next revision.
Old 11-12-2012, 02:06 PM   #79 (permalink)
This was my problem. I had a short in my JST-SH connector.
Everything works fine now, Flashed to 9.2
Many thanks
Old 11-12-2012, 02:12 PM   #80 (permalink)
Nice to read
Thanks for the info!
Tags
blheli, blheli-setup
