Like Tree1Likes
Old 11-02-2008, 05:05 PM   #1 (permalink)
Default T-Rex 250 Build Thread
The original thread is here. I was able to add captions on the photos there.
http://www.rcgroups.com/forums/showthread.php?t=947539
steph280 is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 05:07 PM   #2 (permalink)
Well here it is, Align's first venture into the micro helicopter market, the T-Rex 250. I have built a few micro helis in the past years, but having flown just about every T-Rex Align has put out, I am very anxious to get my hands on this little guy. So between trick-r-treating and entertaining guests at the house, I managed to put this little heli together and document as much as possible. Hope this will be of some help for those who are interested in this heli, or just seeing what is available in the micro heli market.
When UPS delivered the box, I was surprised at how small it is. It looked almost like one of those box that T-Rex 450 canopy comes in. Take a look at the size relative to the T-Rex 500 box in the photos below.
There are three type of T-Rex 250 kits:
Standard - kit with motor and ESC.
Combo - standard kit plus three DS410 digital servos for cyclic.
Super Combo - combo kit plus GP-750 heading lock gyro and DS420 rudder servo.
Opening the box revealed parts neatly packaged in number plastic bags. Main frame is already pre-assembled and sealed in a plastic bag, as well as the head and tail assembly. The nicely painted fiberglass canopy is wrapped in thin layer of protective foam, and then covered in plastic. Following the tradition of all T-Rex kits, Align included tools which have proved to be very helpful in building and repair of their helis. In the case of 250, they included a pair of micro hex and philips drivers with nicely anodized aluminum handles. The size 0.9 micro hex driver is a very important tool, since I don't have one this small in my tool box, and 90% of the T-Rex 250 build depends on it.
Two sets of main blades and tail blades are included for different flight characteristics. There is a pair of 205mm tapered blades, and 200mm straight blades. According to Alan Szabo Jr. test reports (courtery of Align forum), while both blades poses good flight characteristics, the 205mm tapered blades are more suitable for high head speed, high power 3D flights with increase agility and responsiveness. Similar increase in flight responsiveness can be noticed from the 40mm tapered tail blades. I will report back with some actual field tests of both sets of blades later on.
For those familiar with the T-Rex line, this little heli would be no stranger. Almost everything from head to tail is a shrink down copy of its larger siblings. Just like the more recent T-Rex kits, most of the pieces come pre-assembled in 3 major component groups: head, frame, and tail assembly. The pre-assembled pieces reduced the assembly time considerably. However, as with any pre-assemble pieces, I always disassemble and check for the presence of thread locking material. Other than the obvious places where dis-assembly is required for parts fitting (tail boom clamp, fly bar cage, etc), I'm glad to report thread lock was observed in all places.
ID:	67615   Click image for larger version
ID:	67616   Click image for larger version
ID:	67617   Click image for larger version
ID:	67618   Click image for larger version
ID:	67620   Click image for larger version
ID:	67621   Click image for larger version
ID:	67622   Click image for larger version
ID:	67623   Click image for larger version
Old 11-02-2008, 05:09 PM   #3 (permalink)
More photos
ID:	67625   Click image for larger version
ID:	67626   Click image for larger version
ID:	67627   Click image for larger version
ID:	67628   Click image for larger version
ID:	67631   Click image for larger version
ID:	67632   Click image for larger version
Old 11-02-2008, 05:11 PM   #4 (permalink)
The head comes sealed in a plactis bag already assembled as shown in the photo below. All you have to do is build the flybar cage (don't forget to pop on the link) and assemble it onto the head with flybar attached. Then comes the painful part: threading on those tiny ball links. Just clamp the link rod with a plier, and then thread them on with your hand. Do not crimp the plastic links with plier during assembly, as it could cause damages to the link. The head assembly took no more than 15 minutes, with most time spent on those links.
ID:	67634   Click image for larger version
ID:	67635   Click image for larger version
ID:	67636   Click image for larger version
ID:	67637   Click image for larger version
ID:	67639   Click image for larger version
ID:	67640   Click image for larger version
ID:	67641   Click image for larger version
Old 11-02-2008, 05:12 PM   #5 (permalink)
Just like the head assembly, the carbon main frame came pre-assembled out of the bag as shown in the photos below. The frame is the typical double stacker carbon plate design found in T-Rex 450's. Combined with machined aluminum standoff, the frame forms a very rigid structure to withstand the force exerted by aggressive 3D flights.
Not much needs to be done with the main frame. The assembly starts by mounting the 3 cyclic servos with the included screws and plastic threading nuts. It's a little tricky to hold the plastic nuts inside the frame due to space restraints. Make sure you work on a towel or area where a lost screw is easily locatable, since they are extremely small.
Then the head is inserted into the frame's main bearing block through main gear. Unlike the traditional through the shaft bolt method of fixing the main gear, a tiny screw is threaded from the end of the shaft at bottom to hold the assembly together. The access hole on the bottom frame plate allows this to be done with ease.
The typical proven T-Rex landing gear design is utilized in the 250 kit, but in a much smaller scale. Nevertheless Align has included the same end caps and rubber stops with this kit. The skids are held in the plastic bows with drops of glue.
ID:	67645   Click image for larger version
ID:	67646   Click image for larger version
ID:	67647   Click image for larger version
ID:	67648   Click image for larger version
ID:	67650   Click image for larger version
ID:	67651   Click image for larger version
ID:	67652   Click image for larger version
ID:	67653   Click image for larger version
Old 11-02-2008, 05:14 PM   #6 (permalink)
Next comes the tail. Again the tail assembly is pre-done at the factory. Thread the belt through the tailboom, and install the tail assembly onto the boom. There is a small plastic piece on the tail assembly clamp area which needs to be removed during assembly so the tailboom can slide in. The notch on this plastic piece prevents the assembly from rotating on the tailboom. Once fitted, the horizontal fin mount, pushrod guide, and rudder servo mounts will be fitted onto the tailboom. I don't know how many time I forget this step and had to remove the tailboom.
Then the boom is fitted onto the main frame. Loosen up the 8 screws on the frame's boom clamps to facilitate the boom installation. Twist the belt 90 degrees counterclockwise and loop over the drive pulley. Pull tight and tighten the 8 screws to clamp the boom in place.
The rest of the steps includes the installation of boom supports and tail fins. I choose to install the tapered blades for initial flight test.
ID:	67655   Click image for larger version
ID:	67656   Click image for larger version
ID:	67657   Click image for larger version
ID:	67658   Click image for larger version
ID:	67660   Click image for larger version
ID:	67661   Click image for larger version
ID:	67662   Click image for larger version
Old 11-02-2008, 05:18 PM   #7 (permalink)
At this stage, the T-Rex 250 is about completed. Mount the ESC and clean up all the wires to ensure nothing gets caught up in rotating parts. The manual also suggests installing the receiver as far away from ESC as possible, which may not be needed with the modern 2.4Ghz receivers.
For those who has a couple of T-Rex kits under their belt, this build will feel right at home. The kit can literally be build in an evening or two, provided you didn't have to search for lost screws in thick carpet like I did. Did I mention the parts and screws are really tiny? I didn't realize I need reading glasses until I started building this heli. Luckily Align has provided a bag of spare screws/washers in the kit, just like they do with all their other kits.
ID:	67675   Click image for larger version
ID:	67676   Click image for larger version
ID:	67677   Click image for larger version
ID:	67678   Click image for larger version
ID:	67680   Click image for larger version
ID:	67681   Click image for larger version
ID:	67682   Click image for larger version
Old 11-02-2008, 05:18 PM   #8 (permalink)
The thoughtful people at Align also included a spacer for use with their optional pitch gauge to facilitate measurement of pitch on those tiny blades. If you don't have Align's latest pitch gauge, I strongly suggest you take a closer look at one. Unlike other pitch gauges, this one has a fine adjustment knob to adjust the measurement in small increments. One of those "why didn't they think of that before" kind of thing.
Not knowing what to expect with this little guy, I followed the instruction manual and set the pitch range at 11 degrees +/-. I fly only in idle-up-1, so I set it with full 22 degrees and V shaped throttle curve as 100-95-90-95-100. If the linkage length suggestions were followed during the construction process, -11 to +11 pitch range would not be a problem. Align did warn that exceeding the maximum 11 degrees of pitch may result in loss of tail control effectiveness, since the startup torque may exceed the tail compensating power, causing heli to
ID:	67684   Click image for larger version
Old 11-02-2008, 05:20 PM   #9 (permalink)
Couple more photos...
ID:	67686   Click image for larger version
ID:	67687   Click image for larger version
ID:	67688   Click image for larger version
Old 11-02-2008, 05:25 PM   #10 (permalink)
Killer build thread! Nice helis.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 05:29 PM   #11 (permalink)
great................! Video next? and flying comments
450 GF Blinged 65hb/401/9650-DX7
500 CF 5245/401/9257 -DX7.
MH150
CX2
mk1spitfire is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 06:07 PM   #12 (permalink)
yes, i would like to know how it flies?
comparison to a 400 or 450.
please share.
Timdoggydizzle05 is offline        Reply With Quote Quick reply to this message
Old 11-02-2008, 09:42 PM   #13 (permalink)
Unfortunately my kit has a missing bearing that I couldn't locate at any of the LHS. Maiden flight will have to wait for its arrival.
Old 11-02-2008, 09:45 PM   #14 (permalink)
if you vacuum the floor, you will hear it go clickity click up the hose and into the bag. then, sift through the dust, clean it, lube it, and fly. for guys that are buying a 200 class heli for the first time...lay a white sheet on the floor where you are working. you won't believe how small the bits are on this thing.
rotorhead58d is offline        Reply With Quote Quick reply to this message
Old 11-03-2008, 03:11 AM   #15 (permalink)
great report!!!
Mini Protos FBL BeastX
T-rex 7ooN Spartan
bartjuuuhhh is offline        Reply With Quote Quick reply to this message
Old 11-03-2008, 06:14 AM   #16 (permalink)
Did you have eyestrain or headaches working on model?
MH150
CX2
Old 11-03-2008, 06:29 AM   #17 (permalink)
Did you collect from Finless for having the first pics posted or were you not the first?
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons
--T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons
-- DX7, Hyperion Duo, flight leader case
rockjock3 is offline        Reply With Quote Quick reply to this message
Old 11-03-2008, 06:42 AM   #18 (permalink)
Needs a pic with his screen name next to it to collect.
BTW, how did you get the first one?
S
ShooShoo is offline        Reply With Quote Quick reply to this message
Old 11-03-2008, 10:14 AM   #19 (permalink)
Wot? Finless will pay for the first review? In that case...
These kits are available in Taiwan if you put in a pre-order with one of the local shops. I think all distributors will get them any day now.
Old 11-03-2008, 11:22 AM   #20 (permalink)
Hi Steph,
Thanks for the detailed build report. I hope you have your spare part soon.
Question:
Do you think a Futaba FASST R608FS receiver will fit in this little baby?
Dimensions are: 45 x 22 x 13.5 mm
Thanks.
Palmboom is offline        Reply With Quote Quick reply to this message
