Like Tree2Likes
Old 10-29-2009, 09:29 PM   #541 (permalink)
Originally Posted by joeyhatch11 View Post
Gotta problem guys. I got my clone kit today put everything together and it's all working fine but the heli likes to spin out of controll when Im spooling up. Either hard left or hard right. I thought maybe I had the belt twisted in the boom wrong so I took it out and redid it, no changes. Help!!!
Usually that means the gyro is reversed.
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 10-30-2009, 06:41 AM   #542 (permalink)
In my experience with the few helis I've had, the tail blades, when viewed from the right side of the heli, always spun in a count clockwise direction. When following the build process in the Trex 250 manual it would also appear that the tail blades would spin in a counter clockwise manner. But after my post I went and flipped the belt and blades and the heli seems fine now. Just have to do some fine tunning of the gyro delay and gains on my Futaba. I turned everything in my swash menu down to 40% untill I get the hang of this smaller heli. At first it was set to 65% and that was WAY too touchy. 40-45 seems good for now. But how do I slow down the tail? It piero's super fast. Can I just raise the "limit" on the gyro? Or is there a setting to adjust in my Tx? Thanks guys
joeyhatch11 is offline        Reply With Quote Quick reply to this message
Old 10-30-2009, 01:32 PM   #543 (permalink)
NO, on the Trex 250 it's the same as most - the tail comes up in the front and down in the back. When you view this from the right side, it appears counter-clockwise. If you have it going the wrong way you won't get the same tail authority - I'm not sure why, it just doesn't work right that way. Like I said, probably you have your gyro reversed.
To reduce the piro rate, once you have your limit and gain and everything set up right, if the piro is too fast, you can reduce the rudder travel. You can do this in your dual rate settings, or in your travel adjust. On mine, the piro rate isn't fast enough, and I increased the rate to 125% - it still isn't as fast as some.
If you need to go look at my videos, they do show the correct orientation of everything, and how to set up the gyro properly.
https://www.helifreak.com/showthread.php?t=106883
Old 11-02-2009, 11:48 PM   #544 (permalink)
hey everyone his a pic of my little bird sorry about the other two
bigboie is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 07:34 PM   #545 (permalink)
Couldn't pass it up. A quick pic of a new canopy for the 250. Alf_flash does good work.
Cheers
Bob C.
RChristopher is offline        Reply With Quote Quick reply to this message
Old 11-13-2009, 04:59 PM   #546 (permalink)
One of the nicest looking 250's I've seen. So how do I get a canopy like that
Very nice Bob.
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote Quick reply to this message
Old 11-14-2009, 01:12 AM   #547 (permalink)
Thanks,
Check with Alf
https://www.helifreak.com/member.php?u=50776
He does 500E's as well
Cheers
Bob C.
Old 11-14-2009, 05:56 AM   #548 (permalink)
Thanks buddy
Craig.
Cheers, OD.
Old 11-20-2009, 08:37 PM   #549 (permalink)
the little fella with the Greenline Canomod Canopy
still reeling from the damage to my Phantom Canomod.....he's just not been the same since.
and the carnage.......
TREX 450 PRO DFC - 2221-8 V2 (3S), ICE50, AR7200BX, HS65MG, DS3500G, KBDD Tail Blades
RAVE 450 - 2221-10 (4S), ICE50 Lite, Quark, DS285, DS3500G, 6100E, KBDD
brentonasmith is offline        Reply With Quote Quick reply to this message
Old 11-20-2009, 09:03 PM   #550 (permalink)
You will like the visibility of your canopy. I love mine, it is very obvious which orientation the heli is in.
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 11-21-2009, 03:36 PM   #551 (permalink)
Mick
yeah, visibility is definitely key. Whilst waiting for the Greenline I switched back to the Align lightening bolt and had an OMFG experience; just guessed right and got it back, admittedly it was overcast day but re-enforced the notion that the Canmods can pay for themselves.
Cheers mate.
Old 11-21-2009, 09:28 PM   #552 (permalink)
Just another Trex 250...nothing special.
Align Trex 700 V3 DFC HV Vbar Pro
Align Trex 500 EFL Pro Mini Vbar Pro
Outrage Fusion 50 6s Vbar Pro
Raydee is offline        Reply With Quote Quick reply to this message
Old 11-25-2009, 10:30 PM   #553 (permalink)
Here are some photos of my trex 250 from chile!!!
The last one in flight
Saludos
Trex 450 pro/ BLS257
Futaba 6EX
martinnavarro is offline        Reply With Quote Quick reply to this message
Old 11-26-2009, 01:13 AM   #554 (permalink)
Make sure you cut off the unnecessary portion of the elevator servo arm - it can run into the tail drive.
Old 11-26-2009, 01:46 AM   #555 (permalink)
Not
vertol BV107II is offline        Reply With Quote Quick reply to this message
Old 11-26-2009, 01:53 AM   #556 (permalink)
It is shown very clearly in the Finless video. The front servos rub on the canopy too.
Old 11-26-2009, 07:35 AM   #557 (permalink)
OK! thanks for the help! did you lke the heli???
Futaba 6EX
Old 11-26-2009, 01:38 PM   #558 (permalink)
Yeah I love it. Doesn't fly as good as the 500, but it's a lot of fun, convenient to fit in the car, and crashes don't cost much.
Old 11-27-2009, 07:58 AM   #559 (permalink)
what are those metal skids you have there? they look great!
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 11-27-2009, 09:06 AM   #560 (permalink)
Although directed at brentonasmith, I can answer your question zeeflyboy.
They are Zero-G Alu skids: http://www.helihobby.com/html/trex_250.html scroll down about 1/4 page.
IMO I found the total lack of flex compared to the plastic ones a bit of a concern, it meant that any hard landing transferred the shock directly to the frame, the skids absorb nothing. Plus I would rather they were skewed like the stock, I personally prefer the skewed skid look.
That being said, they are beautifully crafted & kudos to the manufacturer for making them, they're just not for me.
How has your experience been with them Brenton?
Trex 500 ESP 3G - DS510M - Jive 80+HV - BLS251 - I2 + KDE + Edge
Trex 250 - GY520 - s9257 - ds410M - Medusa 5V/2A BEC - Scorpion 3900/15T
4G6 - HP08s - XP-07A MIA 4#3B - HP06s - XP-07A
Ntrospect is offline        Reply With Quote Quick reply to this message
