Like Tree2Likes
Old 02-02-2009, 10:45 PM   #221 (permalink)
She is all done.Did a quick test flight in my room and so far it is flying nice..Very smooth..I hope to get more flights in tomorrow..Here is my setup
Align DS410 Digital cyclic servos
Futaba S9257 Tail servo
CY Mini-G gyro
Outrage 25C 860mah batteries
AR6100e RX
Stock motor and ESC
Align 205D Carbon Fiber Blades
Aluminum tail servo mounts
I am running the 37mm tail blades and may shorten them down a little more..I am using a carbon tail linkage rod from a Beam E4 cut down to length..Here are some pics..
Synergy 766 12s/ 766 14s / 696/ Synergy 556/556 nitro Align 700X/700XN
Black Thunder 700T / Black Nitro 700x3 / SAB 500 Sport/ SAB Kraken x3/XL Power 700/ Gaui NX7/ GUAI X7FZ/ X7F
GUAI X5 V2/ Vcontrol/Neo
Locktite is online now        Reply With Quote Quick reply to this message
Old 02-03-2009, 12:00 AM   #222 (permalink)
VERY cool Lock, please let us know how the mini G works out for you!
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
Old 02-03-2009, 12:07 AM   #223 (permalink)
Will do..The Mini-G size is perfect for this heli, plus the shorter wires make wiring much easier..The little time I already have on it, it seems rock solid..If it is anything like the Solid-G which I am sure it is, the Mini-G is a spartan killer...
Old 02-03-2009, 05:09 AM   #224 (permalink)
Justin,
Looks good,Ive cut my tail blades down to 30 mm,center of bolt hole to edge,still plenty of authority.Are you using a 16 tooth pinion? Also,the align batteries seem to be equal to the outrage 860,s.When you get it outside,and start whipping it around,keep an eye on your belt tension,and look for fraying.Im on my third belt.Also the metal pulleys,both front and rear are a good upgrade.Ive spun the plastic tail pulley on its shaft .Jeff
gixxerjeff is offline        Reply With Quote Quick reply to this message
Old 02-03-2009, 08:11 AM   #225 (permalink)
Hey Jeff, Thanks for the info..The newer kits all come with metal tail pulleys, upgraded hardware and new tail hub..I am running 15T pinion..
Old 02-03-2009, 11:34 AM   #226 (permalink)
Default trex 250
"If it is anything like the Solid-G which I am sure it is, the Mini-G is a spartan killer..."
There is nothing out there that is going to be a Spartan Killer.....I have several Solid G's and Spartans....and I think they both perform VERY well.....if the Mini G performs as well as the spartan that will be good enough....
The Spartan/solid g's are by far the MOST consistent piro move gyros out there...
BTW...16T is almost a MANDATORY upgrade...definitely worth doing it...smooths the machine out quite abit and will bog a LOT less....
Jag72 is offline        Reply With Quote Quick reply to this message
Old 02-03-2009, 11:46 AM   #227 (permalink)
I am only joking when I say Spartan killer..I also fly Spartan Gyros as well..Both Great gyro's..I cant wait to try the new futaba 520 out as well..
I may try a 16T down the road but so far the 15t feels fine..I know a few others that are liking the 15T as well..
Old 02-04-2009, 11:24 PM   #228 (permalink)
Ok finally got my little canopy and fins all done up. Canopy and fins were painted by Scott Milton of "Ace Helis"
Setup as follows:
Stock cyclic servos
JR 3500G TR Servo
Spartan DS760 Gyro
AR6100E RX
Stock motor w/16T pinion, Stock ESC
DIY CF tube for tr pushrod
Mikado Heli
Scorpion Motors
Old 02-04-2009, 11:31 PM   #229 (permalink)
Thumbs up
very, very nice!
brianr058 is offline        Reply With Quote Quick reply to this message
Old 02-05-2009, 07:36 AM   #230 (permalink)
DVS
I like that canopy,
DVS is offline        Reply With Quote Quick reply to this message
Old 02-06-2009, 12:39 AM   #231 (permalink)
Sweet! A Rave 200!
Shockwave 3K is offline        Reply With Quote Quick reply to this message
Old 02-09-2009, 10:27 AM   #232 (permalink)
Originally Posted by swishman6 View Post
Here is my T250. I was looking at everyones pics and did'nt see one like it so I thought I would.
Did you buy those frames after you bought the kit? Those are FG, right? You can't get the CF frames in silver as a kit, can you?
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G
Shef is offline        Reply With Quote Quick reply to this message
Old 02-09-2009, 08:40 PM   #233 (permalink)
You have to buy them seperatly.
Old 02-10-2009, 12:02 PM   #234 (permalink)
ID:	81468   Click image for larger version
krayziek04 is offline        Reply With Quote Quick reply to this message
Old 02-11-2009, 01:22 PM   #235 (permalink)
DVS
Here's mine.
Name:	T-Rex 500 012=.jpg
ID:	81703   Click image for larger version
Name:	T-Rex 500 014=.jpg
Old 02-11-2009, 01:30 PM   #236 (permalink)
Hey DVS what skids are you using? They look much better than the stock ones.
docjr is offline        Reply With Quote Quick reply to this message
Old 02-11-2009, 03:21 PM   #237 (permalink)
DVS
I modified a set of low profile Grollia Gear.
Old 02-12-2009, 05:39 AM   #238 (permalink)
are these for 450?
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 02-12-2009, 08:28 AM   #239 (permalink)
DVS
Originally Posted by MaSt0RaS View Post
are these for 450?
Yes they're an old set that came off of my T-Rex 450.
Old 02-12-2009, 01:13 PM   #240 (permalink)
and what is your modification the drills and you cut the tubes? something else? i ilike them and when mine comes i wanna put them on!
