Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 11-10-2008, 06:43 AM   #1 (permalink)
Default Align T-Rex 250 vs. Gaui Hurricane 200SE V2
I've done a short comparison of the T-Rex 250 and the EP200SE V2. In order of pictures posted.
The Align T-Rex 250 nose-to-nose with the EP200SE V2. They're about the same size in every dimension.
A shot of the EP200SE V2 head. You can also see some of the new (lighter 17g as opposed to the 27g on the V1) green fiberglass canopy. BTW, the EP200SE V2 comes with 2 different flybar options to adjust the cyclic response to your liking.
A shot of the T-Rex 250 head with the 205mm rectangular main blades. The 250's head is basically your standard Align head shrunken down to 250 size. You can also see some of the pre-painted canopy which comes in at 15g.
A shot of the 250's airframe. Also very similar to the other T-Rex series helis from Align, though the 250 has a couple unique design features;The gyro tray located at the back of the airframe and the forward motor mounting position.
The same shot as above, but of the EP200SE V2 airframe. As you can see from this picture, the battery tray can be adjusted allow for larger electronic components like the Futaba receivers, and to better adjust the COG, as that was an issue with the V1.
A shot from the left side of the airframe of the EP200SE V2. This does a good job of showing the differences in the mounting apertures for electronics between the 250 and EP200SE V2. The EP200SE V2 servo mounting holes angled more toward the ground.
The same shot as above, but of the T-Rex 250. You can see the Futaba GY-401 mounted inverted on the gyro mounting tray, the motor mounted forward towards the battery tray, and the receiver mounted on the upside of the gyro mounting tray.
A shot of the T-Rex 250 tail rotor assembly. As with the head, the tail is basically the same design as on all of Align's other helis, just smaller.
Here's a shot of the EP200SE V2 tail rotor assembly. It's much improved over the V1 design, but isn't very similar to the T-Rex 250's tail assembly. Both are very nice tail assemblies, and are nearly slop free.
Here's the EP200SE V2 without a battery on a scale showing 268.6g. This is a completely stock, production EP200SE V2.
Here's a shot of the T-Rex 250 on a scale showing 283.7g with the exact same electronics as the EP200SE V2 above. This is also without the battery. As predicted, the T-Rex 250 comes in heavier, but is also designed around a 3s power system.
Hope this was helpful. I'll answer any questions the best I can.
J-Heli is offline        Reply With Quote Quick reply to this message
Old 11-10-2008, 05:24 PM   #2 (permalink)
Originally Posted by J-Heli View Post
Here's the EP200SE V2 ... 268.6g.
T-Rex 250 ... 283.7g with the exact same electronics as the EP200SE V2 above.
Correct me if I'm wrong, but it looks like the gyros are different. (pics on hs forum)
Mike.
mrivers is offline        Reply With Quote Quick reply to this message
Old 11-10-2008, 09:45 PM   #3 (permalink)
is the gaui 200 v2 instock?? i really want to buy one.. the trex 250 is just idono.. i like the design of the gaui and gaui 200 has cheaper parts but preforms better than the trex 250. any one no when they are coming out???? any reviews of some one building or flying them hard 3d?
Brandon3D is offline        Reply With Quote Quick reply to this message
Old 11-10-2008, 09:48 PM   #4 (permalink)
i think the gaui200 v2 are already out. i think somebody mentiond flying-hobby.com
blahblah9 is offline        Reply With Quote Quick reply to this message
Old 11-10-2008, 09:50 PM   #5 (permalink)
i thoght that to but no where els has it! im going to get one as soon as there instock!! i cant wait
Old 11-10-2008, 09:53 PM   #6 (permalink)
http://flying-hobby.com/catalog/prod...oducts_id=4050
a great shop to deal with. speed post is fast, but costs a few bucks more. fung is the owner.
rotorhead58d is offline        Reply With Quote Quick reply to this message
Old 11-10-2008, 09:54 PM   #7 (permalink)
SWEEEEEET
Old 11-10-2008, 10:54 PM   #8 (permalink)
I believe they're the same, but there could be a GU-210 on the EP200SE V2. Not sure.
Old 11-10-2008, 11:08 PM   #9 (permalink)
I think Gaui drop the ball with not having spare parts ready at release.
outerlimits is offline        Reply With Quote Quick reply to this message
Old 11-11-2008, 12:37 AM   #10 (permalink)
i'm sure they will be available shortly. if there's something you need for your V2, i'm sure there are a number of shops that could help you.
Old 11-11-2008, 02:37 AM   #11 (permalink)
am I the only one who cant view the pics in the first post?
Thanks,
G
www.MikadoUSA.com
Gorgin4325 is offline        Reply With Quote Quick reply to this message
Old 11-11-2008, 03:37 AM   #12 (permalink)
You're not the only one gorgin. You should be able to click on the "x"s and see the the pics, however.
Jeff
I do not have to be politically correct. I am not a politician.
K-50 / 500ESP /450SEv2 /H200SD / mCX / RF4.5 / 10C 2.4GHz
Ecklund1 is offline        Reply With Quote Quick reply to this message
Old 11-11-2008, 03:40 AM   #13 (permalink)
Thanks. I saw the pics on aother thread. Great comparisson.
G
www.MikadoUSA.com
Old 11-11-2008, 05:02 AM   #14 (permalink)
Excellent stuff - thanks for the pics..
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 11-11-2008, 09:38 AM   #15 (permalink)
Question.... can the v2 parts be compadible with the older gaui 200? if so please tell me i tried emailing gaui but no one emailed me back..
Old 11-11-2008, 11:54 AM   #16 (permalink)
brandon, we have our best man checking on that as we speak. he should post a response by this week some time.
Old 11-11-2008, 11:55 AM   #17 (permalink)
Great!! thank you pm me when avaliable.
Old 11-11-2008, 12:01 PM   #18 (permalink)
Brandon3d,
Just stay tuned...
You're about as close to the heat as you can get right now, as far as getting the inside scoop on Gaui.
This takes a lot of work, and I know J-Heli is swamped, so let's lighten the load as much as we can. He'll tell us what he can, when he knows.
Excellent posts BTW J-Heli!!!
Gr4yb3ard is offline        Reply With Quote Quick reply to this message
Old 11-11-2008, 12:01 PM   #19 (permalink)
Old 11-11-2008, 12:04 PM   #20 (permalink)
How come I cant see the pictures that he posted in the first post?
