Old 11-14-2008, 08:46 AM   #1 (permalink)
Default T-Rex 250 Fly's :)
Hi all,
thought you might like to see what i have been upto the last few days,
been testing and playing with pack sizes.
I have moved my canopy forwards a littel "its easy see pics" although the packs fit without this there very tight, so i opted for this simple solution.
its early days but i have tryed two packs so far >
revo 750 @ 69g's with deans & velcro 65x34x17 "fine if you mount esp up front and want it very lite.
revo 950 @ 98g's with deans & velcro 70x34x20 "think this is gona be my choice for the extra power and flight times, esc needs to be on the side to get the balance very close, "very slightly nose heavy"
ideal weight would be around 80/85g's
anyway heres some pics im gona go fly it
oh i forgot to say, i friking love this modle so much fun, money well spent !!
arky is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 11:04 AM   #2 (permalink)
Congrats, nice little one indeed!
Can't wait for mine!
JR 11X | Powerlab V2 | Phoenix RC Sim
LOGO 400 VBar | LOGO 500SE VBar | Trex 600N LE VBar
Primus is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 11:07 AM   #3 (permalink)
Where did you find the lipo pack, and what is the brand/specs?
Thanks!
Old 11-14-2008, 11:35 AM   #4 (permalink)
Great photos thanks for sharing.
Never Underestimate The Power Of Stupid People In Large Groups
jurassic5 is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 12:45 PM   #5 (permalink)
Thxs
The batteries are from Aurorra > http://www.aurorra.info/aurv2/productDetails.php?id=61
Jason www.photobucket.com/albums/t230/ark748
T-Rex 500cf, Mikado Flybarles "take two", BLS251, 3x9650-9257gears, Kontronik Jive 80hv, Aurorra 5s4200mha, Z-Power z20a 1700kv/15t, KDE Alloy Base Plate & Battery Tray.
T-Rex 250, Spartan/s3154, 3xDS410, Revo 950's.
Old 11-14-2008, 01:59 PM   #6 (permalink)
What are your flight times?
ndoren is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 02:43 PM   #7 (permalink)
I have only been flying around in my garden atm but im flying 5mins and there is average 20% left in the pack, on the 10s cellpro charger, no 3d yet but im thinking 5mins
Old 11-14-2008, 03:34 PM   #8 (permalink)
Thanks for the post and info on the Revolectix packs! I had been wondering if either of these two packs would be suitable, Revo rocks!
Team Synergy / Rail Blades / Morgan Fuel
beeflyer2 is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 03:48 PM   #9 (permalink)
Hobbycity has 1000mah 3s1p 87g batts for $13.50.
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons
--T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons
-- DX7, Hyperion Duo, flight leader case
rockjock3 is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 03:55 PM   #10 (permalink)
Are you saying that the cellpro 10S shows 20% when you hit start to charge or is it saying 0%?
If it is showing 20% when you hit start to charge then you should be able to squeeze another min or so out of that pack. The 20% represents what you have left in the pack before you hit the 80% mark, so essentially you had 40% left in your pack. Look at your final mah in the end to calculate this better and verify what the charger is showing. For example I fly my Trex 500 packs (6s 2500mah) to about 7% left (as read on a cellpro 10S) and put back in 1800 mah. This yield 1800/2500 = 72% used. According to the cellpro 10S I had 7% left to fly plus the 20% standard to give around 27% left. My final mah showed I had 28% left in the pack. Pretty good for what I need.
Smiley
Smiley is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 03:58 PM   #11 (permalink)
Wow. That's a very clean install. Either you have very small fingers or you're very patient. Great job.
widower is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 04:11 PM   #12 (permalink)
Smiley
yup its 20% left when i hit start, hence i think 5mins of 3d will be able
Old 11-14-2008, 04:14 PM   #13 (permalink)
Thanks, i like things neat
Old 11-14-2008, 05:07 PM   #14 (permalink)
Very nice build, arky! Very clean and well done.
I'm building my own with exactly the same components (except for the lipos, I'll be using the Align 3s 850mahs).
Since you're using the same tail servo / gyro combo that I'm using, can you tell me what the measurement is on your tail servo between the ball and the pivot point (linkage screw)? I'm not sure where to put mine for optimum effect.
Thanks.
TREXes: 250, 550, 700N; Velocity 50 - definitely too many, but so hard to part with them!
jeffsw is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 05:19 PM   #15 (permalink)
You shouldn't use the % as indicators. Use the final mah count to get the amount of time you can fly. The % is determinted from a look up table based on how the pack reacts to the charge. New lipo tech or different brands of lipo changed the curve, so the table is not accurate.
The low cost of repair is really tempting. I was all set to get back in the game with a 500, now I can't decide.
rcboosted is offline        Reply With Quote Quick reply to this message
Old 11-14-2008, 05:36 PM   #16 (permalink)
Arky,
Did you use all the default settings in the ESC? Or did you modify any of them?
Thanks! Nice work.
Old 11-15-2008, 01:47 PM   #17 (permalink)
After a 7 hour build I got my first flight in. Head is still a little to tight. Its windy here (15 gust 30) so I only hovered and FF in my yard. I'll wait untill I can get spare parts or at least better wind to 3d it.
Battery -TP 1320 (yes it does fit and c.g. is right on)
Flight time-10min (about half normal and half idle 1)
Temps-air:62f
bat:95f
motor:82f(wow!!!)
Charge-892ma back in
ITS A KEEPER!!!
Trashley is offline        Reply With Quote Quick reply to this message
Old 11-15-2008, 01:55 PM   #18 (permalink)
wow, 1320 is a great mAh if cog is good. you might see 15 minute flight times if you take it easy.
rotorhead58d is offline        Reply With Quote Quick reply to this message
Old 11-15-2008, 02:02 PM   #19 (permalink)
I'll go for 15min this afternoon. My head speed is set very low in normal mode(good for in doors). I'll try to get a RPM reading.
Old 11-15-2008, 03:03 PM   #20 (permalink)
Hi jeffsw
I have tryed all the options as i have been chasing a bounce on fast left stops i have it much bettet now but not fixed yet will report back i have a few more things to try.
but i have the gyro end points set at 100 - 100 and the servo ball at its innermost position as this seem to give best resauts atm the gain is adjusted via the gear channel atv's -30 for hh and +30 for rate any higher and it wags, In the Spartan Program i have reduced the deceleration profile to slow & counter clockwisestop stop gain to 50, its improved but the bounce has not stopped fully, will try reducing the accleration profile see what that dose tommorow can't hurt
