Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 12-10-2012, 02:46 AM   #81 (permalink)
Its an old Lipo from Outrage NRG 3600mAh, the LHS was clearing stock I grab the last one. I havent found an alt so far. This Lipo is great even programing with the LCD backlights of the 14MZ last for hrs. Normal Operation even longer
jffry7 is offline        Reply With Quote Quick reply to this message
Old 04-22-2013, 06:09 PM   #82 (permalink)
Default Is anyone still on the hunt for a solution for this battery issue?
Since I like my 14MZ and 12Z radios, I've been hunting down a possible lipo solution. Thunderpower RC has a pack that I'm looking to get and try out... more to come.
TP3800-2SPPRX
junkiePilot is offline        Reply With Quote Quick reply to this message
Old 06-18-2013, 06:30 AM   #83 (permalink)
This was my solution
I needed some way to mount my dragon link to the radio and since it needed external power on the 14mz to function I figured why not power the radio also so I went to my trusty cad software whipped up a mount that plugged into the 14mz's module port to hold it in place and this is what I got
it holds a 3600mah pack and both my RF modules
Name:	2013-06-18 07.26.52.jpg
ID:	429229   Click image for larger version
Name:	2013-06-18 07.27.06.jpg
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 06-19-2013, 05:49 AM   #84 (permalink)
What I did was purchase the best charger I could find which will charge two packs. I really like this charger:
https://www.helifreak.com/showthread.php?t=540685
Old 06-19-2013, 05:55 AM   #85 (permalink)
yea I heard that
I have that same charger for my camera batteries
charges my cam-corder and my slr batteries both
so I had plenty of batteries I just couldnt live with the run time from one on the 14mz
Old 09-17-2013, 02:50 AM   #86 (permalink)
Default Alternative charging system for 14MZ
I too was frustrated with the poor battery performance with the 14MZ, having tried many other Sony type clone replacements.
I have gone with the system from Secraft/Singapore Hobby for my 14MZ, see :-
http://shop.singahobby.com/?q=node/30544
I bought the charging lead shown from them, but they were out of stock of the silver Secraft holders, so I got one of those direct from Secraft here :-
http://secraft.net/shop/step1.php?number=1253
I found a cheap suitable 2S lipo from HobbyKing here :-
http://www.hobbyking.com/hobbyking/s...dProduct=21000
Now I expect to enjoy much longer use times between charges !
Cheers
Viv
New Zealand
vivwiniata is offline        Reply With Quote Quick reply to this message
Old 08-16-2015, 08:10 PM   #87 (permalink)
Alright. I know this thread is a little old but the battery issue with my 14MZ only gets worse the older it gets.
I've decide to buy the Seacraft battery holder and make a charge cord adapter.
My question is, can I simply plug a 2S LiPo into the charge port on the back of the TX? The port that everyone seems to plugging a LiPo into was designed for the Futaba CR-2500 charger. Is there some intelligence in the transmitter that allows the input of a non-standard voltage from an 8.4 volt battery? Is the intelligence for charging in the transmitter? Does the CR2500 simply supply a voltage to that port and the TX does the rest?
I'm concerned we are simply supplying a voltage to a port that was designed for an intelligent charger.
Also, I assume you still have to have a Futaba battery pack installed - right? We are in effect using the external battery to keep the internal battery at 100%.?.?
Bill
"Well, nothing bad can happen now."
wjvail is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 02:41 PM   #88 (permalink)
I loved this transmitter. Here's your solution. http://www.singahobby.com/?q=node/32112
Yes you can plug a 2S right in piggy backing the original battery with an adaptor. This link shows an extra lower cage to mount the battery.
Yes that's a carbon MCPX!
MCPx BL, 180cfx, 400 FBL-6S, 450x, Mostro 700, 18MZ Spectrum Module wired through training port.
DemonHeli is offline        Reply With Quote Quick reply to this message
Old 11-25-2016, 02:21 PM   #89 (permalink)
Default Follow up.
Cheers
Viv
New Zealand
I just purchased one of the Secraft Battery Holders for a second hand 14MZ I picked up. Now that you have some time using the device how would you rate it overall? Do you find that the connector to the charging port comes loose over time? I originally purchased it with the idea of using a Nickle metal 7.2v 5000maH battery because I have limited LiPo experience and I am fearful of the fire hazard. Any thoughts on the LiPo Vs. Nickle Metal. The opening slot on the bottom plate is a concern form me. Do you find that dust and dirt enters the radio through it? How have you addressed this issue?
Thanks for your thoughts!!
Luis
Miami, Florida
mef4ud is offline        Reply With Quote Quick reply to this message
Old 11-25-2016, 02:25 PM   #90 (permalink)
Default Follow up.
Cheers
Viv
New Zealand
Luis
Miami, Florida
