Old 12-10-2008, 11:08 AM   #21 (permalink)
Team Taco VP
Jasmine, I was wondering where your vids were and found them.
Sticking this thread!
BTW would you like them hosted here on Helifreak? PM me if so and we can figure out how to transfer them.
Bob
Old 12-10-2008, 07:19 PM   #22 (permalink)
Originally Posted by Jasmine2501 View Post
I use the "Gear" switch for throttle hold, and set it to -5%
Can you get to that switch in a hurry? You using the airplane model DX7 with that switch way down low on the left side? Because, on the Heli model DX7, that switch is on the face of the radio and a pain to get to if you REALLY need it. Probably hard to fly with a finger on it, too.
DesertClimber is offline        Reply With Quote Quick reply to this message
Old 12-10-2008, 07:24 PM   #23 (permalink)
i have my TH on my 9303 set bottom right.....my ring finger is resting against it and i can flick very fast.......
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote Quick reply to this message
Old 12-10-2008, 07:28 PM   #24 (permalink)
Exactly. When I was first learning, I was told to put it there, because it was the most common... When I used to get buddy-boxed, the instructor knew my radio was set up with the same throttle hold as everyone else and there were no surprises.
Old 12-10-2008, 07:58 PM   #25 (permalink)
Yes, airplane radio - converted throttle stick for better helicopter usage. As I said though, this is largely a matter of personal preference. I am used to using the right-hand shoulder switch for dual rates, which I don't use on helicopters, but that way I don't get confused, because on some of my planes I have been able to program the gear switch to be a throttle kill switch by using programmable mixes. So things are consistent for me...
I don't consider throttle hold one of the more important switches. I hardly ever use switches at all during flight. If I want to auto or something bad happens, it's easy enough to reach with the grip style I use. I use a shoulder strap for the transmitter and pinch grip on the sticks, so it's tricky to reach any of the switches regardless of where they are, and the left-hand switches are a bit easier.
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 12-11-2008, 02:13 AM   #26 (permalink)
Really? Wow.
Old 12-11-2008, 02:26 AM   #27 (permalink)
I am kind of hard core - I never give up. I do not use the throttle hold in a crash as I probably should. If I make a mistake, I try to fly out of the situation until it's all over. Granted, this has only happened once... and I was able to get to the throttle hold in time to prevent a lot of damage. I can get to it quick if I need to.
I do consider it important as far as safety goes. If I need to mess with the heli or carry it while it's alive, I put the throttle hold on, set normal flight mode, and hold my thumb on the throttle to keep it down - habit from planes. And I always have it activated when I plug in... the DX7 doesn't activate if throttle hold is on, which is a little weird... so every time I turn it on, I flip the switch twice, so the radio will activate and the TH is also active. Force of habit
Old 12-11-2008, 07:06 AM   #28 (permalink)
nice video Jasmine I like the magnet trick. I'll be building mine after Christmas. Man! are those parts small
ICHItheKILLER is offline        Reply With Quote Quick reply to this message
Old 12-12-2008, 01:32 AM   #29 (permalink)
I finally got everything all wired up tonight and will be posting the last videos as soon as I can. It is amazingly smooth and powerful, but I haven't had a chance to really fly it yet. Will be sure to get video when I do, but the first flight will probably just be hovering and stuff - with training balls! I always like to use those on a new heli or after a major repair, just in case it wants to crash right away or something
I didn't get the wiring clean at all, because my little wrench is rounded off, and I can't find another one, and I need to take the frame apart to get the wiring the way I want it, but it's all working nicely and everything is tied down the way I like it. Balance is perfect with an 800mAh E-flite battery. The heli itself hit my wallet too hard to get the Thunder Power batteries I want to use with it
Old 12-12-2008, 05:02 AM   #30 (permalink)
Jasmine,
will you video include setting up the
GP-750 gyro in T-Rex 250 kit ?
This is still confusion after reading it.
thx
Gravity Works...
steves is offline        Reply With Quote Quick reply to this message
Old 12-12-2008, 10:23 AM   #31 (permalink)
Yeah I'll be doing that one tonight. It was a little weird the first time I went through it. I had to reverse both the gyro sensing and my rudder stick, because I put the thing on there backwards
Old 12-12-2008, 10:55 AM   #32 (permalink)
I'm having PROBLEMS:
Thanks...looking fwd to it...
I'm having problems,I have everythign set up properly...
but when I go to spin up, the tail spins hard right, when it gets up to headspeed
or the HEAD will tilt hard to the right, just before lift off?
Also, what should the Gyro be set to in the DX7 radio? 60-70% or 30-40%
I get confused ...
Gravity Works...
Old 12-12-2008, 11:13 AM   #33 (permalink)
...with training balls! I always like to use those on a new heli or after a major repair, just in case it wants to crash right away or something.
Hey, that's not hardcore!
Old 12-12-2008, 12:02 PM   #34 (permalink)
Hard core doesn't have to include stupid too
I pay for my own stuff, so I don't like to crash it.
On the gyro - 51% seems to be "Off" and above that is heading hold, while 50% and below seems to be rate mode. I do not know and can not recommend specific values for the gain for anyone, because it's different for everyone depending on many factors, but I will show you how to figure it out.
Old 12-12-2008, 12:16 PM   #35 (permalink)
Sorry.
Old 12-13-2008, 05:27 PM   #36 (permalink)
Great stuff Jasmine - looking forward to the last videos - I like that you do a lot of detail - I know not everyone wants it, but I find it really helpful. Thanks for all your work.
Regards, A
AlasdairM is offline        Reply With Quote Quick reply to this message
Old 12-14-2008, 09:47 PM   #37 (permalink)
OK I put the tail video and the gyro setup, and I think that will be it! Enjoy
Old 12-17-2008, 06:11 AM   #38 (permalink)
pqr
Default Thanks Jasmine
Your time and efforts are much appreciated
Phil
All the Gear - No idea!
Trex 700N, 600N, 600E, 500E, 450 Pro, 450GF, 250
HK 250, 450, 500 for Spares
Blade MSR
pqr is offline        Reply With Quote Quick reply to this message
Old 12-20-2008, 04:49 AM   #39 (permalink)
where is the blade balancing video
I am a total noob lol
mrd09 is offline        Reply With Quote Quick reply to this message
Old 12-20-2008, 11:42 AM   #40 (permalink)
Blade 400 Rebuild - Part 7 - Blade Balancing (13 min 32 sec)
I found this method to be nearly useless on the little 250 blades. For those, I just screwed them together and held them on my finger - they were already perfect.
