Go Back   HeliFreak > R/C Helicopter Support > 250 Class Electric Helicopters > 250 Aftermarket Upgrades
250 Aftermarket Upgrades 250 Aftermarket Upgrades
Old 02-08-2010, 06:18 PM   #181 (permalink)
HEIM,
are the production versions available yet? If so let me know how I can get a set. If not, add me to the waiting list.
tracker640 is offline        Reply With Quote Quick reply to this message
Old 02-08-2010, 09:27 PM   #182 (permalink)
Heim:
Count me in as well for the Chinese weights and the spacer upgrade!
ross_badger is offline        Reply With Quote Quick reply to this message
Old 04-10-2010, 10:40 AM   #183 (permalink)
Is HeimJoint still around? I PM'd him and also sent him an email but got no response. I'm looking to buy one of his Trex 250 t/r sets.
Avant RC
Scorpion Power Systems
ThunderPower RC
Kontronik Drives
Justin Stuart is offline        Reply With Quote Quick reply to this message
Old 04-10-2010, 12:53 PM   #184 (permalink)
I just got a couple 250 sets from him about 3 weeks ago.
Very much worrth the short time to install. My blade grips are slop free now.
Tail is working perfect.
Trex 500 ESP GY520, DX7
Trex 450 SE and Pro,
Raptor 50 O.S. 50 SX-H 401,
XL 60 Custom Graphite O.S. .61 SX-H 401
XL 60 Bergen Frame YS .61, 401
rsmheli is offline        Reply With Quote Quick reply to this message
Old 04-10-2010, 02:18 PM   #185 (permalink)
I hope he will PM me or email me. I'd like to pick up a few sets as well from him.
Avant RC
ThunderPower RC
Kontronik Drives
Old 04-11-2010, 08:21 AM   #186 (permalink)
The easiest way to contact Heim is by e-mail: [email protected]
TRex 450SEV2 FBL w/ Microbeast, TRex 250SE FBL w/ Microbeast
Old 04-11-2010, 09:48 AM   #187 (permalink)
Thanks for the info, but I already emailed him at that address. Maybe he's busy?
Avant RC
ThunderPower RC
Kontronik Drives
Old 04-15-2010, 10:38 AM   #188 (permalink)
Sorry guys, I have been super busy with real work. I have not been on for weeks, I will catch up.
HEIM JOINT is offline        Reply With Quote Quick reply to this message
Old 04-15-2010, 10:45 AM   #189 (permalink)
Heim is back. Alright!!
Avant RC
ThunderPower RC
Kontronik Drives
Old 04-20-2010, 08:41 PM   #190 (permalink)
Default not sure if you got my pm
not sure if you got my pms but i sent you pm for order and i get a reply of the order list right away please let me know if you got my request
Paulieb1979 is offline        Reply With Quote Quick reply to this message
Old 04-20-2010, 10:02 PM   #191 (permalink)
I put the Heim Joint tail spacer set in my Trex 250SE today and flew it. The tail is MUCH better now.
Avant RC
ThunderPower RC
Kontronik Drives
Old 05-09-2010, 01:05 AM   #192 (permalink)
how much is the set ?
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote Quick reply to this message
Old 05-14-2010, 01:56 AM   #193 (permalink)
Where did you get those from?
EDIT: What a stupid question... by yours truly
hga77 is offline        Reply With Quote Quick reply to this message
Old 05-15-2010, 07:51 AM   #194 (permalink)
Chinese weights are $16.50 a set
The T250 tail blade grip bearing preload spacer set is $5.99
The Torx T5 wrench for the screws in the preload spacer set only is $3.29
PM me to order
Old 05-26-2010, 03:11 AM   #195 (permalink)
Default Boca Bearings
Does anyone know if it's better to use the Boca bearings or the Gaui bearings for this mod? A few pages back in this thread someone mentioned that the Align 681 tail bearings are somewhat lower quality - I wonder if these are made by Boca??? Strange how Align's part number is close to the Boca bearing part number.
stevenpph is offline        Reply With Quote Quick reply to this message
Old 05-26-2010, 01:57 PM   #196 (permalink)
The numer is the same because it is the industry standard number for that bearing size. The only reason I suggested the Gaui bearings initialy was because a lot of the tail stickyness went away when I used them instead of the Align bearings. I dont think Boca actualy makes any bearings they are just a very good distributor who has many bearings made to thier specs. Just keep in mind that you can get that bearing for anywhere from $0.89 to $12.95 and the quality varies accordingly.
Old 05-26-2010, 04:25 PM   #197 (permalink)
as it stands my 250 stock se tails holds perfect with the larger innolab servo on it..
Zero zero issues
Old 05-26-2010, 08:50 PM   #198 (permalink)
I am in the process of getting new weights for my 250, the old ones needed replacing after lots of crash repairs.
The heli flies terribly with out the weights on a stock V1 tail set with 2 bearings and Heim Joints bearing spacer adjusting system. Servo HSG-5084MG, I may have to put my 9257 back on in the interim
Hopefully I wont have to put up with the tail as it is now for much longer.
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 07-06-2010, 01:21 AM   #199 (permalink)
Default 250SE -
I understand that the newer Align "weighted" grips that come with the 250SE (H25095A) do not reduce pushrod force very much and that the older grips with the chinese weights are preferred.
My question is do I have to buy the old grips to use HJ's chinese weights or is there a special set that is designed for the new grips? What is the effect of using the weights with the new grips?
-John
T-Rex 500 CF / Hyperion HS3026-1600 / ICE75 / JR Z3650 / JR 3500G / JR 770D / AR7000
T-Rex 250 SE / DS410 / DS09GMD / GP750 / AR6110 / Hyperion G3 850
T-Rex 700E F3C - Under Construction
precV is offline        Reply With Quote Quick reply to this message
Old 07-06-2010, 01:45 AM   #200 (permalink)
I'm not sure if HJ's Chinese weights will fit the new grips since they already have weights on them?
Avant RC
ThunderPower RC
Kontronik Drives
