Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 05-25-2006, 06:30 AM   #21 (permalink)
Hi All,
I just found that i had inadvertently installed the outer gasket (between insulator and carb) backwards.
If installed this way, it actually looks correct but the small hole doesn't line up fully.
My symptoms were that the motor would start fine but required a higher than normal butterfly opening to idle properly. The motor would also quit easily.
As much as i'm embarrassed to admit my error, i thought i would post it here in case someone else made this simple mistake and is experiencing the same symptoms.
CustomPC is offline        Reply With Quote Quick reply to this message
Old 05-25-2006, 06:43 AM   #22 (permalink)
I stuck mine in yesterday! Even remember to record it!
Does seem smoother.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote Quick reply to this message
Old 05-26-2006, 05:05 AM   #23 (permalink)
Hi All,
Hi Custom PC,
Please dont be embarrassed as I too installed the gasket between the carb and insulator backwards once. What got my attention was that the edge of the teflon was not perfectly flush with the edge of the aluminum insulator. I disassembled the assy. and made the same discovery you did.
There are two ways to make sure this does not happen,one, once assembled, make sure the teflon is perfectly flush around the entire edge of the aluminum insulator. A second way is to pre fit the teflon on the insulator to make sure it is oriented properly. With the carb out of the way, the small radius next to the pulse hole is a good indication of proper orientation. Mark the edge of the teflon gasket and aluminum with a sharpie, then once assembled you can double check to make sure the marks line up. If you all deem it necessary, Ill see about updating the installation insructions to make sure this is not over looked.
Thanks for sharing Custom PC.
regards, Johan
Z-rc
Z-RC is offline        Reply With Quote Quick reply to this message
Old 08-09-2006, 12:16 PM   #24 (permalink)
I just ordered one and the instructons are really nice in the PDF above. I wish everyone would pay this much attention to detail.
Ron Keith
Keith Ranch Santo, TX
AMA CD # 8305, Turbine Waiver 505, IRCHA 2367
Bergen R/C Helicopters -
rkeith2 is offline        Reply With Quote Quick reply to this message
Old 01-09-2007, 09:24 PM   #25 (permalink)
Ordered mine yesterday, sounds like a winner
Bill G.
"Never Give Up"
Hagar7 is offline        Reply With Quote Quick reply to this message
Old 02-01-2007, 01:07 PM   #26 (permalink)
got mine in red
eyeflyhelis is offline        Reply With Quote Quick reply to this message
Old 03-08-2007, 06:11 AM   #27 (permalink)
Now I'm a owner to !!
Ordered mine in red and they have shipped in the same day of order !!
Very nice service.
FUTABA 14MZ
http://www.villalariano.it
giopapy is offline        Reply With Quote Quick reply to this message
Old 05-27-2007, 05:43 PM   #28 (permalink)
Default New Gasket
Hey Guys, I've been relucantant to use this insulator, because in its std form, it prevents the use of the deflector/spacer (which comes with the Spectra-G kit) without using some sort of sealer. There has been a lot of back and forth on these boards about using this. Personally I won't fly a model in hot weather without one. So to bridge the gap I asked Johan if he could make an optional spacer like the deflector.
So here's what he came up with. The only difference in installation is that you replace the gasket that goes between the insulator and the carburetor with this new larger one.
I don't know when he's going to have these done but if you're interested contact Z-RC about it.
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is offline        Reply With Quote Quick reply to this message
Old 09-26-2007, 07:29 AM   #29 (permalink)
If the aluminum insulator is used is the carburator still spaced the same distance from the cylinder?
Thanks.....Dave
AMA 6679
IRCHA 675
VHA 11
Dave Willis is offline        Reply With Quote Quick reply to this message
Old 10-10-2007, 03:57 AM   #30 (permalink)
Yep , it's the same height ,,, BTW , I use Permatex Aviation form-a-gasket #3 on all the mating inlet surfaces , without paper gaskets; it seals the carby/carbon plate/insulator perfectly....
Peter .... Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: TSA 700N & G; TSA 600N Pro & Platinum ; All BeastX ; guided by XPS .
Peter is offline        Reply With Quote Quick reply to this message
Old 12-17-2007, 08:54 PM   #31 (permalink)
Default Zenoah Isulator
Please explain why Glass Filled Teflon (GTFE) is not used for the material. Glass filled teflon (GTFE) was developed because Virgin Teflon (TFE) flowed anytime it was sandwiched in compression and was subjected to heat.
The other new more stable plastic that is replacing Teflon is "PEEK tm". It wont cold/hot flow can also be made with glass filled. High temprature properties, insulating properties and hard as wood pecker lips.
Thanks, IREXDATREX
COURAGE, IS FEAR THAT HAS SAID ITS PRAYERS...NOBOBY SAID COURAGE HAD TO FEEL GOOD...
IREXDATREX is offline        Reply With Quote Quick reply to this message
Old 04-13-2009, 06:03 AM   #32 (permalink)
Hi , how can i order that carb isoltor for my zenoha g 26?
thanks
shaft ( shaft100@gmail.com)
SHAFT500 is offline        Reply With Quote Quick reply to this message
Old 04-13-2009, 06:49 AM   #33 (permalink)
Hanson has their own aluminum spacer block. Or Google Z-RC and find retailers.
As for why not telfon for the block itself, machining teflonm based products adds a lot of health issues into the workplace.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 09-14-2010, 07:16 PM   #34 (permalink)
Where can I purchase a better insulator block for my zenoah 20, i have tryed the links and they are dead now.
Craig Teffeteller
Teffe is offline        Reply With Quote Quick reply to this message
Old 10-04-2010, 01:44 PM   #35 (permalink)
I use the ones from Gizmo Motors on my motors and they work great. These fit most all the motors but not sure on the 20.
Jimmy
http://www.gizmomotors.com/index.php...mart&Itemid=56
Predator Gasser and a DX7
PGSigns is offline        Reply With Quote Quick reply to this message
Old 01-26-2011, 05:03 PM   #36 (permalink)
Does anyone know where I can get a Z-Rc Insulator from please?
The link is dead on the first page.
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 01-27-2011, 12:22 AM   #37 (permalink)
Here is one
http://www.bergenrc.com/SearchResult...-Rc&Submit2=Go
bdbrown4764 is offline        Reply With Quote Quick reply to this message
Old 02-09-2011, 10:09 PM   #38 (permalink)
http://www.davesmotors.com/s.nl/c.88...egory.62926/.f
Mega325 is offline        Reply With Quote Quick reply to this message
Human Verification
