Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 10-04-2009, 05:36 AM   #401 (permalink)
I like this idea VERY much !
anrikahn is offline        Reply With Quote Quick reply to this message
Old 10-04-2009, 05:38 AM   #402 (permalink)
yeah yeah
Old 10-04-2009, 10:57 AM   #403 (permalink)
You mean the new Frame set from Ben???
Otherwise I didnt get the "idea"?
FlyawayClyde is offline        Reply With Quote Quick reply to this message
Old 10-04-2009, 11:49 AM   #404 (permalink)
It supposed to be comment for those CF landing gera/skids here from Wazzer...but this whole thread..I mean this frame is AWESOME . i love IT ! ...like also that : i2rc fbl head ...niceee I can imagine an ULTIMATE Gaui HeadHunter 550 Heli ..build from these parts...it will be a wonderful helicopter... OK that is all from me, for now, thanks guys...
Old 10-05-2009, 08:47 PM   #405 (permalink)
Yep it sure would be
Old 10-11-2009, 07:38 AM   #406 (permalink)
Could this frame be used as an upgrade on the
new Hurri 425EP IRCHA 2009 plastic version?
ronnieb is offline        Reply With Quote Quick reply to this message
Old 10-11-2009, 08:09 AM   #407 (permalink)
dont see why not, just have to buy the spacer kit and some extra bearings (anything i'm forgetting?)
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 10-11-2009, 10:05 AM   #408 (permalink)
You will need in addition to the plastic frame;
CNC boom clamps
CNC CF Frame spacer 4pcs
CNC Mainshaft bearing block
2pcs Mainshaft bearings
Assorted hardware to fasten all the parts together.
Old 10-12-2009, 01:40 AM   #409 (permalink)
Dont forget the Upper Tail drive shaft bearing block!!
Yes the head hunter frame can be run as a 425 if you wish as Erik stated above you do need a few extra parts from teh CF version.
Hope this helps
Ben
Borneoben is offline        Reply With Quote Quick reply to this message
Old 10-13-2009, 02:03 AM   #410 (permalink)
Default Pro's and cons
Thanks guys, I'll sort it.
Could somebody capture all the advantages in this frame,
I got a little lost in the whole thread during the animal part...................
Old 10-13-2009, 02:43 AM   #411 (permalink)
Hey Ronnie
There are a fair few pros and in my mind not many cons!!
(although i am a little bias!)
The main frame is much stiffer than the original Gaui Carbon Frame
It is made from 2mm carbon.
It has direct to swash 120degree servo mounting which eleiminates the bell cranks for the servos its a more simple design and easier to set up.
Reduced interactions during swash movement.
The full frame set includes the big Balls Bearing Blocks which allows for much larger bearings on te OWB shaft.
The full kit also includes the Easy Mesh Motor Mount that allows much easier meshing of the pinion and gears. It also allows quick removal of motor. It also inlcudes an additional frame brace.
Its design from the strat to mount 6s Packs in one location and it is very secure with up to three velco straps.
And best of all its WAY COOL!! (subjective I know)
Cons could be its a little tricky to mount a separate flight pack on the frame. It was designed around a system using a BEC.
The servos are no longer push pull they are direct to swash so there is more loading on the servo output shaft although I believe most modern servos on a heli this size can cope no problem.
Its not the cheapest frame set around due to the low numbers its manufactured in. But i am looking into revising the prices very soon.
Hope this helps
Ben
Head Hunter Heli's
Old 10-13-2009, 02:48 AM   #412 (permalink)
OK Guys
I have been talking to my Courrier and have strucka deal with him.
I am now able to offer you guys Free WORLDWIDE shipping on all Head Hunter Heli Upgrades.
Its a good service through DHL and its total trackable. Most items should take about 4 working days to the USA.
I need to shift some more kits to recoupe some money for the next batch and for other developments.
Cheers all
Ben
Old 10-13-2009, 03:13 AM   #413 (permalink)
Man trust me, I'm saving up for one LoL! It's gonna be a while though, since it's now almost the season for my other love...snowboarding!
See my artwork: http://martins819.deviantart.com
MartinS819 is offline        Reply With Quote Quick reply to this message
Old 10-13-2009, 11:18 PM   #414 (permalink)
Ben,
Order is coming this morning.
Scott
Team Rage-RC USA--Team Pilot
KBDD Team Pilot ):>
Old 10-14-2009, 03:23 AM   #415 (permalink)
Let me know ASAP as i am off to the UK for 10days on the 19th
and i will need to book the shipping
Thanks very much
Ben
Old 10-14-2009, 05:22 AM   #416 (permalink)
You're welcome,
PM Sent... Thanks, Ben!
Scott
KBDD Team Pilot ):>
Old 10-14-2009, 06:17 AM   #417 (permalink)
I have replied to you PM Scott
Thanks very much for the order most appreciated
Ben
Head Hunter Heli's
Old 10-14-2009, 09:08 AM   #418 (permalink)
You're very welcome, Ben!
Truth be told, I can't wait to show this off! It's gonna be a couple of weeks, though... but that's cool, it gives me something to do besides crash!
Scott
KBDD Team Pilot ):>
Old 10-14-2009, 01:23 PM   #419 (permalink)
Originally Posted by Wazzer View Post
Hey Ronnie
Hope this helps
Ben
Head Hunter Heli's
Thanks for the info Ben,
really great disign!
One pro, or con, I'm missing is something about the weight?
Although I'm planning on upgrading my std 425 to
handle some longer blades, 463 or 475mm, and a
torque tube, I was wondering if the Head Hunter carbon
frame was any lighter than the plastic or other carbon frames
on the market?
Old 10-14-2009, 02:39 PM   #420 (permalink)
on the market?
let me get this straight... you want longer blades AND the torque tube tail... hate to be the one to tell ya... but.... the TT is only for the 425 boom.. to use 463 or 475 blades you'll be the short 550 boom (part# 204192) and the TT won't work on that boom.
of course you are more than welcome to run the 425 boom and TT and 475 blades.. just make sure ya get it on video so everyone can see how fast you can disassemble a hurri in flight
Hurricane 550- mCX- DX7-
AMA# 901271-
Gaui Headspeed Calc
mysticmead is offline        Reply With Quote Quick reply to this message
