Old 12-23-2008, 06:19 PM   #21 (permalink)
Team Taco VP
Lower or upper part? Mine seems OK but which part separated from the bearing?
Bob
Old 12-23-2008, 06:26 PM   #22 (permalink)
The lower cup part, here's a pic
1 Raptor 50sev2...perfect
1 Gaui 200SEV2...frantic
1 ELY-Q Vision 50....Few QUK parts
R8driver is offline        Reply With Quote Quick reply to this message
Old 12-23-2008, 06:33 PM   #23 (permalink)
Team Taco VP
hmmmm.... intersting... that means the design relies only on locktite to secure the bearings. That is usually OK (Align got BEAT up on this approach though) until you crash and stress the locktite. Had you crashed previously? Did this happen in the air?
I will triple check mine THANKS!
Bob
Old 12-23-2008, 06:43 PM   #24 (permalink)
No crash prior to this, but as I said, since I've put Locktite(green) on it I've had no bother. Maybe it just hadn't been done on assembly? One of those times where you'll try and pull it apart to see if it's loose, and if it won'r budge, you'll start to worry about it later
Also see in the pic, the flybar ball link tube came out, maybe because of the swash problem?
I CA'd that back in, and it's been fine since. Welcome to microworld
Stewart.
Yes it happened just lifting to a hover above the Persian rug
Old 12-23-2008, 11:00 PM   #25 (permalink)
ohh god, now i want one of these guys!
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote Quick reply to this message
Old 12-24-2008, 03:56 AM   #26 (permalink)
Sadist Nah, I love mine to bits, kinda like an annoying little brother!
Old 12-26-2008, 07:15 PM   #27 (permalink)
Team Taco VP
OK NEW videos posted! The links are in the first post but here they are as well...
OK, since this is a pre-built heli I thought I would go over some stuff and review the airframe. So these 3 segments are about the airfame Head, frames, belt, pinion, and tail!
Video Link ->Head and main shaft assembly (50 Megs)
Video Link ->Main frame overview and Pinion setup (45 Megs)
Video Link ->Tail Assembly check out (35 Megs)
Enjoy!
Bob
Old 12-26-2008, 07:41 PM   #28 (permalink)
Talking
that a boy Bob, keep it coming!
Old 12-26-2008, 08:05 PM   #29 (permalink)
Why are the fingers sooo big and the screws sooo small!!!!
Man do I have that problem!
C R Mudgeon is offline        Reply With Quote Quick reply to this message
Old 12-26-2008, 10:25 PM   #30 (permalink)
Default Thanks Finless!
I ahve been checking everyday for the next build videos! Thank you Bob
Adam
adam crosby is offline        Reply With Quote Quick reply to this message
Old 12-27-2008, 02:41 PM   #31 (permalink)
Thanks bob, I have been looking forward to these also!
Happy holidays fellow freaks
VengeanceCP is offline        Reply With Quote Quick reply to this message
Old 12-28-2008, 03:47 AM   #32 (permalink)
Team Taco VP
OK so let me ask... Based on what I have shown so far... Is this what you all are looking for or is there more you would like to see me cover?
Bob
Old 12-28-2008, 05:27 AM   #33 (permalink)
Hover in you're front room
Old 12-28-2008, 08:55 AM   #34 (permalink)
Bob,
Excellent work as usual... Thanks heaps for your hard work..
Servo wiring and general electronics placement on these small helis is a nightmare...
I have the V1 and had very little place to put anything.. so I think some good advice on
how to route the wiring and where to place everything for good CG and easy repair would be a godsend for future owners.
Also - maybe in the end you could do a review on the gaui blades vs the align 205 CF and platic blades...
I've tried the align 20f tapered plastic and they really dull the cyclic down on my ep200 vs the std gaui 200 plastic blades due to the added weight of the aligns.. this may be a good thing for beginners... definitely not good for 3D..
I would be interested in your comparison of the gaui bldes vs the align CF as the align are supposed to be quite good and light.... and relativly cheap compared to the FRP blades for the ep200.
AND...... if you get really bored and want another chapter - a vid on beefing up the motor (maybe a 5150 or scorpian) and issues/requirements associated with that... The reason I ask is that I have the V1 and find it just that little bit lacking for nice inverted - so a little (maybe 20-30%) more power would make this heli a masterpiece.. I run 2S so if there is a motor that could use 2S 800mah batteries and give that little extra punch would be fantastic...
DX7 Mode-1 | 450 pro 6s | 450 pro | Schweizer 300C Gasser Scale | T-Rex550e | Aeolus 50 | HeliX T-Rex700 fbl Gasser | HWC600 Gasser | Henseleit MPXLe | Henseleit 3DNT | Suzi-Janis 700 | Gaui NX4 | Gaui X5 | Blade 350QX
jockstrap is offline        Reply With Quote Quick reply to this message
Old 12-28-2008, 09:33 AM   #35 (permalink)
BTW RDLohr has a nice tray that mounts above the lower tray to hold the Rx.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-28-2008, 08:44 PM   #36 (permalink)
Bob
Hey Bob,
I'd like to see frame alignment. I've had trouble with the main shaft alignment with the frame being off a little bit.
Setting the motor mesh. I'm not sure the paper method works here does it?
Head setup. With stuff this small the setup really has to be correct.
After you get the basic bird in the air I would love for you to cover the 2 blade FES system with the GU-365.
Love all the videos! Where do you find time to do all of them!
Old 12-30-2008, 06:27 PM   #37 (permalink)
Team Taco VP
3 new videos added. They are on the first post but here are the new links as well.
Video Link ->Servo Installation (33 Megs)
Video Link ->Servo Setup (57 Megs)
Video Link ->Head Setup (60 Megs)
Bob
Old 12-30-2008, 06:57 PM   #38 (permalink)
It probably too late, but if you want one Bob I will slip it in the mail for ya. Just back from sunny FL.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 12-30-2008, 08:04 PM   #39 (permalink)
lookin good bob
unklebuck is offline        Reply With Quote Quick reply to this message
Old 12-30-2008, 09:57 PM   #40 (permalink)
Thumbs up Bob! The Videos are great!
