Go Back   HeliFreak > R/C Helicopter Support > Electric Helicopters
Electric Helicopters Dedicated to larger than Micro/Mini Electric Helicopters of any Brand
Old 11-16-2008, 06:24 PM   #1 (permalink)
Default Can't get my throttle and pitch curves right
I was out in my yard messing around and I went into idle up mode and for some reason the pitch is not equal up or down. When I punch it up it doesn't have much but down or negative pitch it has all kinds of power. So why is it more when I go negative pitch then when I go full positive pitch?
Idle up mode:
Throttle curve
100
90
80
90
100
Pitch curve
0
40
80
90
100
Normal mode:
Throttle curve
0
45
65
85
100
Pitch curve
40
45
55
75
100
Is that good for idle up mode and normal? By the way I am using a Futaba 6EX 2.4 radio. If someone has a better setup let me know please!
Blade 450 X
UAV_PILOT is offline        Reply With Quote Quick reply to this message
Old 11-17-2008, 08:27 AM   #2 (permalink)
GRAVITY
dbatman is offline        Reply With Quote Quick reply to this message
Old 11-17-2008, 09:20 AM   #3 (permalink)
It's because of your pitch curve. In idle up, your pitch curve should usually be 0-25-50-75-100. Yours (0-40-80-90-100) only gives you a 20% pitch range between middle stick and high stick (80-..-100) but you have 80% pitch range between middle stick and low stick.
widower is offline        Reply With Quote Quick reply to this message
Old 12-10-2008, 10:59 PM   #4 (permalink)
Try seting the pitch with a pitch gauge dont worrie about the pitch numbers in the tranmitter. Adjust transmitter to give the pitch you want on the gauge once you set the pitch with a gauge its set for good dont mess with it. Now you only have to mess with throttle numbers. I usually set mine with a strait line of 90 across in idle up. Just make sure to match everything a mid stick so when you flip the switch to idle up the heli will not jump and motor doesnt surge on you. My pitch is usualy -11, 0 at mid, +11
Try this throttle curve
Nomal 0,inh,85,85,85
Idle up 85,85,85,85,85
If 85 is to low or to high of a head speed adjust to your likking.
The point being electric motors run there best in the power band which is around 85 to 100%. Unlike nitro motors which need a more fine tuned throttle curve like 90,75,65,75,90 and 0,45,65,75,90 for example.
US Army 1995-2007 Iraq 1st tour 2003-2004 2nd tour 2005-2006
Kiowa Warrior Crewchief 15s20
Reinlisted Army 30 Dec 2008
Signal Company Team Chief
smoothb10 is offline        Reply With Quote Quick reply to this message
Old 12-18-2008, 04:05 AM   #5 (permalink)
A flat throttle curve will mean that the headspeed changes as the pitch changes. Unless you are running a governor. It is like trying to drive up a hlill without adding throttle to you car, you will slow down. With an electric, this also increases the amp draw and heat in the motor, ESC, and pack.
Normal:
Pitch: 40 - 45 - 50- 75 - 100 (fine tune the 40 and 45 to get -2 to -3 degrees at full low stick)
Throttle: 0 - 65 - 80 - 90 - 100 You want to get the headspeed up into a reasonable range. Electrics need to be run over 80 throtlte for bst effciency.
Idle Up:
Pitch: 0 - 25 - 50- 75 - 100
Throttle: 100- 95 - 90 - 95 - 100
Terry
AMA#47402, IRCHA # 3395
Old 12-29-2008, 12:21 AM   #6 (permalink)
Default Hmmmm
UAV, what heli is this on?
The purpose of the dip in the idle-up throttle curve is to completely remove the possibility of an overspeed. Most hotshots will tell you to just go linear on your throttle in idle-up (100% straight across). The idea is that you're not going to be flat pitch for more than a split second any way (pitch decreases headspeed). The odds of overspeeding are minimal on most stock helicopters and it keeps your headspeed from bogging down if you make a quick collective input. I ran my helis with the stock throttle curve and definitely noticed the headspeed lag when pulling out of any type of high-G maneuver. At 100% the power is there when I need it.
Widower is right, another problem is your pitch curve. In idle-up it in most helis I am familiar with go: 0-25-50-75-100. ( my CP Pro, Blade 400s and T-Rex 500)
From there, your linkage and your swash mix should be set to give you flat pitch at 50 and + - settings that give you the correct amount of pitch for the heli you are flying.
Hope this helps.
Basic Flying Rules: "Try to stay in the middle of the air. Do not go near the edges of it. The edges of the air can be recognized by the appearance of ground, buildings, sea, trees, and interstellar space. It is much more difficult to fly there."
RotorJockey is offline        Reply With Quote Quick reply to this message
