Like Tree1Likes
Old 08-01-2011, 07:31 PM   #2141 (permalink)
Team Taco VP
Originally Posted by AlexTheRC View Post
can those video use for trex 450 sport combo
i am a newb, sorry for asking stupid question
Some can like the head. All the rest use my Trex450 SE and SEV2 videos. The sport basically has the frames and tail of the 450 SE.
Bob
Old 08-03-2011, 09:19 AM   #2142 (permalink)
Bob
hi there bob can a 450 pro head works on trex 450 v2 heli
astrecord is offline        Reply With Quote Quick reply to this message
Old 08-03-2011, 11:15 AM   #2143 (permalink)
Team Taco VP
It probably can if you include the swash, washout, etc from the Pro. The ball spacing I believe is different from the swash up so to keep the same mix ratios you need probably need the swash and all parts on up.
Bob
Old 08-03-2011, 09:25 PM   #2144 (permalink)
hi bob sorry , i mean to say the hold complete pro head
Old 08-03-2011, 09:45 PM   #2145 (permalink)
Team Taco VP
I am sorry you need to elaborate. I am unclear what your asking? I thought I gave the answer I thought you were asking but I am now unclear. Sorry.....
Bob
Old 08-03-2011, 09:58 PM   #2146 (permalink)
OK , here i have a complete trex 450 pro head , i want to put it on a 450 v2 trex heli, can it work ?
Old 08-04-2011, 08:44 AM   #2147 (permalink)
Team Taco VP
It should work. I have not tried it myself but I do not see why it would not. You will need a V2 main shaft as I do not think the collar-less Pro main shaft will work.
Bob
Old 08-24-2011, 09:17 AM   #2148 (permalink)
Smile
jjjkkkk
lucaer is offline        Reply With Quote Quick reply to this message
Old 09-08-2011, 09:34 PM   #2149 (permalink)
Default Thank you.
Thank you so very much - you have made my introduction to flying 100 times easier than going at it alone. You have most likely saved me $100's in parts and hours in time. Owe you a cold one. Thanks again.
jst1970 is offline        Reply With Quote Quick reply to this message
Old 09-11-2011, 07:16 PM   #2150 (permalink)
Smile thanks
you videos have been really helpful
manateemark is offline        Reply With Quote Quick reply to this message
Old 09-29-2011, 03:10 PM   #2151 (permalink)
Great power tool video can't stop laughing
Jeddie is offline        Reply With Quote Quick reply to this message
Old 01-16-2012, 08:31 PM   #2152 (permalink)
I just built a $30.00 HK clone using the align manual for pitch and throttle curves. It worked ok. Then I set it up using all of Bob's videos and this bird is 110% better now. Bob you are fantastic and if any one ever has any duobts about there set up they really need to watch these videos. Thank you so much for your time and effort put into each one oof these build videos.
XXXN-T Chuck is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 08:19 PM   #2153 (permalink)
ok so on the 401 setup video ... how do you set a gyro in normal mode?
t-rex 600 n pro
added a new chopper to the fleet...
hk 450
razer t-rex is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 04:06 PM   #2154 (permalink)
Team Taco VP
What radio? Bottom line gain controls when it is in HH or rate mode.
Spektrum radios anything below 50 in the gyro menu put it in rate mode. Futaba gain with a negative number is rate more (or if gyro menu is set AVCS)
Old 03-08-2012, 06:11 PM   #2155 (permalink)
what i mean is how do you set up revo mixing? and what is it, and do you just set the gain like you would for hh mode?
oh btw i got a funny gyro its a 401 and when i fly at 62 gain in the dx7 it wags like crazzzzy and i have to drop it to like 57 to get it to stop but when i do a punchout it dosent hold and i have no idea what is causing this
t-rex 600 n pro
hk 450
Old 03-09-2012, 12:00 PM   #2156 (permalink)
Revo mixing is not used when using a gyro - disable it.
Low quality servos can cause the problem you describe, as can any other problem with the tail system like bendy pushrods, loose mounts, loose belts, etc. Low head speed contributes to the issue. Also aggressive throttle curves can cause the gyro to lose it on a punchout, especially the 401. If it is a Futaba 401, it needs to be paired with a quality servo - if it's a knock-off 401, that becomes even more important. Post your settings and information about your setup - maybe we will see something.
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 03-09-2012, 07:25 PM   #2157 (permalink)
ok to start its a hk 401 and im using a hextronik htx900 servo which is analog so that might cause a problem other than that its a good quality hk450 heli
t-rex 600 n pro
hk 450
Old 03-12-2012, 12:05 PM   #2158 (permalink)
Hey Gang,
Been awhile since I've flown my helis, but getting back to it a bit...Have a Trex450 SE, and I have some parts, but I needed a tail shaft to rebuild the tail, and I go to my LHS who had everything 450 2 years ago, and now they don't have hardly anything...No main blades, no tail parts, nothing....Everybody has gone to 500's the clerk said....Did Align stop making parts for the 450SE? Am I chasing something that I can't find? Do I need to pack the other Trex450SE kit away and save it for a few more years to sell on Ebay as an "antique out-of-date" kit? Where does evrybody get tail parts for their 450's? After reading Bob's Ramblings rant, I got the itch to fly the 450 again, and now finding parts has become an issue...Does this mean the big brown truck is going to become my best friend?
Any ideas would help...
Thanks!
The Helifreak formerly known as Charliedontsurf
Goblin 500Mini Vbar DX8 TRex500 Ikon DX8 Warp360 Ikon/Brain DX8
Blade m350QX DX8 Blade mCPX BL DX8
Assistant to the assistant manure spreader at Middle Creek Stables, LLC
VonRecktofen is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 07:14 PM   #2159 (permalink)
After a 3 year hiatus, I got my trusty old, battered but rebuilt Trex450SE into the air this afternoon....Hovered 4 packs out with no crashes....Been doing lots with the sim and the CX2 and Mcpx in the house...Question....Why when doing my first ever piros with the 450, did the bird climb about 3-4 feet, and then when I made it snap to the left, it lost about 2-3 feet of altitude? Is there something I'm missing in the set-up, or was it nervous fingers on the collective increasing it or decreasing it? Got a 401 gyro and a mild normal pitch curve programmed (-3 -1.5 0 +5 +10 ) with a Finless Bob throttle curve in normal mode as well...
Any ideas?
Thanks!
Old 03-12-2012, 11:30 PM   #2160 (permalink)
hello bob
do you have info on converting trex 450sev2 to flybarless?
thank you
timengel is offline        Reply With Quote Quick reply to this message
