Old 01-18-2009, 09:26 PM   #1 (permalink)
Default Most expensive pitch gauge lol (iphone users)
Got an iphone???? USE IT!!!! Also there are digital levels out there that sell for 40 bucks but I would never spend that when I can use my 10 dollar eflite Pitch Gauge, but since I have an iPhone why not get exact measurements
Heres what you got to do:
1) download the free level tool in the apps store
2) using the blade holder cut a slit under the two blade slots so you can slide it tightly onto one of the main blades. (the original slots are too loose to use but I found they are perfect for my SAB 425 blades, so I use the stock slots for the 425's and a newly cut slot for the 325's)
3) place the iphone flat on the tail boom and hit the calibration button to zero out the level.
4) place the newly calibrated level and secure it to the blade holder (rubber band) and slide it onto one main blade. Now make sure that the base of the iphone which was zero'ed out on the boom is now flat to the blade.
5) go ahead with you pitch measuring and read the degrees on the phone.
I own a pitch gauge but this is nice because I'm not straining my eyes trying to level it with the flybar and also I can eyeball it damn close but why not have exact degree measurements when I have the iphone sitting there.
Food for thought.
ID:	77654   Click image for larger version
ID:	77655   Click image for larger version
Blade 400 3x DS285MG, DS290G Tail, G2703D Gyro, Trex 500 skids, motor-none, ESC-none, estimated finish date-unsure
Trex 250 aka the crash test dummy
Bradley Jones is offline        Reply With Quote Quick reply to this message
Old 01-18-2009, 09:54 PM   #2 (permalink)
technology!!! Unreal!!
BladeMadMan is offline        Reply With Quote Quick reply to this message
Old 01-18-2009, 10:21 PM   #3 (permalink)
L M A O
MSH Protos CF - DS3517MG Cyclic, S9257 Tail, Spartan DS760
Blade 400 - DS285MG Cyclic, DS290 tail, Align GP750, HobbyWing UBEC, aluminum upgrades.
Honeybee CP2 with SuperSkids (RIP)
Blade MSR
Atomsk is offline        Reply With Quote Quick reply to this message
Old 01-18-2009, 11:07 PM   #4 (permalink)
Dayem man...a B400 & an Iphone! Sheesh, some have it all!
Seriously though, that is pretty cool app for it!
Blade mCX / mCPx / 130X / B400 HS-65MGs FBL CopterX w/3400g CCBEC 440H
B400 HG-5000 w/5083, CNC Head, HS-65HBs / B400 GY401 w/3400g, JR285s / B450X
T-Rex 600E / 600N Pro / Vortex 250 Pro
mr2mkii is offline        Reply With Quote Quick reply to this message
Old 01-19-2009, 12:36 AM   #5 (permalink)
This is awesome!!!! just downloaded app to my iPhone,will definitely try this !!
CrashBandicoot is offline        Reply With Quote Quick reply to this message
Old 01-19-2009, 07:20 AM   #6 (permalink)
Interesting idea. I'm just wondering how accurate it is though?
J-S-Q is offline        Reply With Quote Quick reply to this message
Old 01-19-2009, 07:46 AM   #7 (permalink)
Awesome
JCB287 is offline        Reply With Quote Quick reply to this message
Old 01-19-2009, 07:56 AM   #8 (permalink)
Even if the phone is accuarate the fudge between the phone and the blade foamy thingmabob is there its only rubber banded then eyeballed and the rubber band has play. If i know Bradley like I think I do hes screwing around and sharing in his fun.
Brett
B400 (01/03/09 First Barrel Roll!!)
Lama V4 (chasing the dogs around the house)
bobyjimmie is online now        Reply With Quote Quick reply to this message
Old 01-19-2009, 09:04 AM   #9 (permalink)
Thats cool. I now have a reason to get an iphone!!
BennyTRD is offline        Reply With Quote Quick reply to this message
Old 01-19-2009, 09:19 AM   #10 (permalink)
If you wanted to level something for construction purposes you would have to calibrate it to something that is guaranteed level. However since you level off the boom then you calibrate it to that and it don't matter if your work bench is on a 45 degree angle while you set up the head. I have digital levels that I use while I inspect (I'm a machine shop inspector) and they work just as good as this. Even with those I don't go by it 100% but it gets me close and I can get further into an inspection knowing I'm at least close. Since most people use a hand pitch gauge which you use by eye this is far more accurate, excessively accurate for blade pitching but it never hurts to be even closer.
Actually there is no play as the rubber band it real tight, If I wanted I could even get a real thick rubber band to ensure that but trust me there's no movement. It just sits there while you pitch from 10 pos to 10 neg so it's not like it has to be sturdy enough for me to spool it up to 100% throttle The bottom of the phone has a flat spot where you plug the charger and thats what I use to zero off the boom and then I make sure it's flat to the blade. Trust me it works, When I was at work the other day (Yeah I'm laid off but I go hang out ) I calibrated it off my precision granite surface plate which is accurate within .0002 of an inch and then I put it up to a precision 45 degree angle block and the it read 45.1 degrees.......... CAN"T BEAT THAT FOR A FREE iPhone APP
heres a link to one you can buy off Readyheli for 40 bucks and if you peep the specs you'll see that theirs is accurate within .1 degrees
http://www.readyheli.com/Wixey_Digit..._p/c019003.htm
Sorry bobyjimmie I'm serious
Old 01-19-2009, 09:42 AM   #11 (permalink)
there are a few levels to choose from but I recommend this one is has better features and the screen is more clear than the other one. Some of the levels don't have the degrees in a digital mode just the bubble mode. I downloaded three and erased 2 when I found this one.
Old 01-19-2009, 07:37 PM   #12 (permalink)
Even if the rubberband is really tight you need a second level to level your iphone to the blade mount. OK FINE I GIVE UP!! Im a blackberry user and refuse to admit Iphones are cool, fine you caught me.
Brett
Old 01-19-2009, 07:47 PM   #13 (permalink)
What???
Old 01-20-2009, 07:24 PM   #14 (permalink)
Your using your rubber blade holder as the attachment point for your Iphone level right? Your Iphone level is rubber banded to that blade holder. How do you know that the Iphone and the blade holder are sync'd up perfectly without a second level or a square to check it. You could have rubber banded your Iphone on crooked!
Brett
Old 01-20-2009, 07:30 PM   #15 (permalink)
I don't think you understand. You place the flat of the phone on the boom and hit calibrate, this calls the boom 0 pitch and it is coming off the flat of the phone now. Then when it is rigged up you keep the flat of the phone on the flat of the blade and at zero pitch it should read zero. If the level has been calibrated then why would I need another level. The level isn't supposed to be "level" it's supposed to be zero pitched to the boom. trust me, ready heli sells digital pitch gauges that function just like this actually exactly like this and you don't level a level. man that sounds confusing written out.
Old 01-20-2009, 07:48 PM   #16 (permalink)
heres the instruction for this digi pitch gauge
Just turn it on, set on the boom and zero it, stick it on the blades and read the pitch, it is that simple.
Old 01-20-2009, 09:28 PM   #17 (permalink)
Brett
Old 01-26-2009, 10:46 AM   #18 (permalink)
Default Cheaper alternative
Here's a cheaper alternative than rushing out and purchasing a iPhone.
http://www.wixey.com/anglegauge/index.html
It's even magnetic.
cd_edwards is offline        Reply With Quote Quick reply to this message
Old 01-26-2009, 02:49 PM   #19 (permalink)
It's even magnetic.
Thats a cool gadget right there, I wish I thought of it first. Ohh BTW check out post 10 and post 16
Old 01-26-2009, 03:33 PM   #20 (permalink)
Yep.Noticed those posts after I posted. go figure.
