Old 03-15-2009, 08:13 PM   #1 (permalink)
Default Mixing arm bearings
I was checking over the 250 this evening and I noticed the upper mixing arms were pretty hard to move. I took one side off, put it back and it was 100% better. I tried the other side and the inner bearing was already in pieces. The outer ring is still stuck in the arm. This is about 30 flights no crashes. Can I buy the bearings or do I have to buy the arms as a set? Has anyone else had this problem.
ckoelliker is offline        Reply With Quote Quick reply to this message
Old 03-15-2009, 08:42 PM   #2 (permalink)
Just changed my mixing arm bearings,align 681X ,4 to a pack.Mine had so much slop I couldnt track the blades anymore.I had the bearings from 2 original tail grips (same bearing).You need 4 bearings total for the 2 mixing arms.I think there like 5 bucks.The mixing arms are like 12 bucks,dont know if they include the bearings with the arms?
gixxerjeff is offline        Reply With Quote Quick reply to this message
Old 03-15-2009, 09:06 PM   #3 (permalink)
Thanks, I will look into it. How many flights before you switched them out?
Old 03-15-2009, 09:17 PM   #4 (permalink)
I'm with you on slop in the bearings (as everyone else is too)...can't get the blades to track right on. still having fun though.
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G
Shef is offline        Reply With Quote Quick reply to this message
Old 03-15-2009, 09:36 PM   #5 (permalink)
I just rebuilt mine with the Gaui bearings, it has helped with the slop, I am on my third set of bearings, 100 flights a set...
snjbird is offline        Reply With Quote Quick reply to this message
Old 03-15-2009, 10:00 PM   #6 (permalink)
SNJ - do you have a link to the Gaui bearings you used? It really peeves me to see the wobble in the mixing arms. Did you replace the bearings for both upper and lower mixing arms?
Old 03-16-2009, 12:25 AM   #7 (permalink)
My mixer arm bearings only last 25 flights before getting loose. I might buy some boca ceramics.
cbrian4 is offline        Reply With Quote Quick reply to this message
Old 03-16-2009, 12:39 AM   #8 (permalink)
sanding down the washer that sits between the 2 bearings will help. this puts a pre-load on the bearings, and tightens the whole assembly.
the washer doesn't require alot of sanding. it only takes about 5 minutes. you can tell by putting it back together and feeling the slop. once you get the slop out, the bearings last alot longer
just don't sand them down to the point that it puts the bearings in a bind
to put this into perspective, we're talking about 1/1000... maybe 1.5/1000. I used an emery board....
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote Quick reply to this message
Old 03-16-2009, 03:47 AM   #9 (permalink)
I already did the sanding washers but the bearings still loosened up, they're just cheap, crappy bearings.
Old 03-16-2009, 09:44 AM   #10 (permalink)
Ready heli had the ones I used... they only had 2 sets and I have not been fast enough to get more every time they are back in stock, I miss them... I just did the uppers the lowers do not have nearly as much play! I'll look and see if I can get the number for ya Shef.
Old 03-16-2009, 12:53 PM   #11 (permalink)
yeah,I think the upper mixing arms get the workout stress from pitching the main blades.The lower (washout) arms kinda take care of the flybar and cage = less torque,so the bearings last longer.
Old 03-17-2009, 01:04 PM   #12 (permalink)
I notice that when I grab the longer pitch links (not the short ones that go to the blade grips) and pull, the upper mixing arm moves back and forth. is this what you guys are talking about? I dont have any problem with them being hard to move tho..
specialk is offline        Reply With Quote Quick reply to this message
Old 03-17-2009, 03:33 PM   #13 (permalink)
The mixing arms should just pivot on there screws,like a seesaw,I had an actual wobble like the screw was coming out,but it wasnt.It was the bearing being worn out.
Old 03-17-2009, 03:53 PM   #14 (permalink)
all my mixing arms wobble like crazy...hopefully the Gaui bearings will arrive at my doorstep tomorrow
Old 03-17-2009, 05:16 PM   #15 (permalink)
can someone please post gaui bearing part numbers?
Old 03-17-2009, 05:21 PM   #16 (permalink)
I hope it's these b/c I ordered 4 sets of them:
http://www.readyheli.com/203250_Bear...0_p/203250.htm
Old 03-17-2009, 06:33 PM   #17 (permalink)
they are out of stock
T-rex 250 Super Combo w/ hs-65mg's
Blade cp pro: spectrum receiver, BL main, DD tail, Gyro
www.bladecpupgrades.co.nr
Blade cx2
E-flite 4-site
helidude3 is offline        Reply With Quote Quick reply to this message
Old 03-17-2009, 07:22 PM   #18 (permalink)
Damm,they dont even give you the actual size?the OEM align bearing is 1.5 x4 x1.2 mm.
Old 03-17-2009, 07:27 PM   #19 (permalink)
Terrible bearings for these arms....
I ask Eyal from ReadyHeli to deliver BOCA's (non ceramic). He could deliver them for 16dollars 4pieces.
(thats what he told me....):
quote:
you will pay $15.99 for (4) bearings?
if so i can order you as many as you want.
Thank you for allowing us to serve your heli needs.
Afterwards I ask to put them on their site....no reaction till now.
Z
| mCPX [email protected] | [email protected] | [email protected] || FunJet [email protected] | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote Quick reply to this message
Old 03-17-2009, 07:45 PM   #20 (permalink)
helidirect has them in stock.
