Trex 700 Electric conversions - Page 4 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Electric Conversions
700 Electric Conversions Align T-REX 700 Electric Conversions
Old 05-31-2009, 11:56 AM   #61 (permalink)
OK chaps, I need a bit of help with gears and pinions. I've noticed that some of you appear to be running 1.0 mod gears in your conversions. Could someone please tell me where you get the main gear and pinions from? I found some 1.0 mod pinions on the Tower Hobbies website, but they are only 5mm bore - I need 6mm. Any help much appreciated.
Gtarling is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 01:51 PM   #62 (permalink)
Anybody know this conversion ?
http://www.xperience3d.com/core/page.php?12
~Roei~
TooLy is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 02:45 PM   #63 (permalink)
Looks interesting. Very much like the Heli-Chris.de conversion (elevator servo moved back and moved outside the frames) but the shorter battery tunnel isn't going to fit two big Zippy or Outrage 5000mAh packs.
Have laser, will travel.
cbdane is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 02:49 PM   #64 (permalink)
The M1.0 maingear comes from MicroHeli. I noticed that GrandRC is now selling them without the nitro pinion. I'm using a 11T M1.0 6mm steel pinion from Century. Both Heli-World.com and RREModels.com carries them but the last time I looked, they were both out of stock.
Old 05-31-2009, 03:50 PM   #65 (permalink)
Hey Freaks, have a 700 on order, and have a question:
Could those off you running the CC HV110 post your setup ? (ive got the USB setup option).
I am using Align serovs, Scorpion 560KV and Zippy batterys with a 14 pinion.
I am mostly gonna fly sport flying, what THR curves should i run for this setup for
flying.( flips, loops, rolls etc).
Thanks in forward, Sören
Dufniall is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 08:42 PM   #66 (permalink)
Here is something i pieced together. Used a aftermarket "Stock" frame just to test the idea. My goal was to get all the weight as close to the tail boom as possible..
chuck
ID:	99637   Click image for larger version
ID:	99638   Click image for larger version
ID:	99639   Click image for larger version
ID:	99640   Click image for larger version
ID:	99642   Click image for larger version
ID:	99643   Click image for larger version
Chuck Bole is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 11:09 PM   #67 (permalink)
I got in a couple flights today. Rolls and flips like it's on a wire.
chuck
ID:	99673   Click image for larger version
ID:	99674   Click image for larger version
ID:	99675   Click image for larger version
Old 06-01-2009, 07:44 AM   #68 (permalink)
Thanks for that - seems they're hard to get in the US as well as the UK. Guess I'll keep looking.
Old 06-01-2009, 01:18 PM   #69 (permalink)
heli direct has the pinions you need there made by rhino hope that helps
700enewby is offline        Reply With Quote Quick reply to this message
Old 06-01-2009, 01:57 PM   #70 (permalink)
Humm, I looked through all the pinions at HeliDirect. I only found 3 for 6mm shafts and they were all 0.7M; not 1.0M. Please let us know if I missed a product. Thanks!
Old 06-01-2009, 04:54 PM   #71 (permalink)
Thanks to VijayV for this link in Australia for the Scorpion 11T 6mm pinions. They also have the 10 and the 12T.
http://www.arkinnovations.com/shop/i...roducts_id=889
Hope that this is helpful.
Old 06-01-2009, 05:58 PM   #72 (permalink)
what is the tooth count on the mod 1 gear?
thanks
chuck
Old 06-01-2009, 07:30 PM   #73 (permalink)
thanks
chuck
115.
Old 06-01-2009, 09:11 PM   #74 (permalink)
Humm. 10T pinion 11.9 :1 ratio. That was the "Holy Grail" i was looking for when i did the E Stratus..The biggest main gear M/A had was 100T (at the time) . A Actro 32-3 on 12s was a bit too much at 10:1. I can put the X Era in it with a 10T M/A pinion and should be golden...
chuck
Old 06-01-2009, 11:21 PM   #75 (permalink)
chuck
Yep. And the 11T is perfect for the lower rpm/V motors, i.e. Scorpion 4035/500 and Pyro 30-12.
Old 06-02-2009, 06:07 PM   #76 (permalink)
Default Battery Tray
Here is the finished tray made from 1/2" alum. angle and CF.
ID:	99964   Click image for larger version
ID:	99965   Click image for larger version
John Hall
Tallahassee, FL
flyanything is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 08:25 PM   #77 (permalink)
Which pinions do I use with the stock gear?
I just ordered the motor and esc(500kv/castle 85hv)
aswell as the conversion.
Any suggestions on pinion size?
atreeinmygarage1 is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 08:57 PM   #78 (permalink)
First suggestion would be to get ride of the 85 and get the 110.
mu300pilot is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 09:22 PM   #79 (permalink)
Tried to find the 110 but couldnt find it in stock eveywhere.So far they seem to be fine for everyone I know that is running them.
Old 06-03-2009, 12:22 AM   #80 (permalink)
Based on my data logs, HV85 should be fine. Running 12S with the Scorpion 4035 or Pyro 30-12, the average current is around 35A with spikes up to 70-80A. See data logs here: https://www.helifreak.com/showthread.php?t=140870
Human Verification
