Old 04-01-2009, 12:55 AM   #1 (permalink)
Team Taco VP
Default G-Force Trex 700 Clutch Block setup
OK G-force sent me their new replacement clutch block setup for the Trex700. This allows adjustment of the pinion to main gear backlash thus helping reduce the possibility of stripping your main gear.
Not much else to say other then this thing is really designed well and a thing of beauty!
On with the vids:
Video Link ->Overview of the clutch block and motor mount system (35 Megs)
Video Link ->AAARGH! Got a stripped screw? Here is how get get one out! (19 Megs)
Video Link ->Assembly and Installation of the clutch block (60 Megs)
Video Link ->Installing and adjusting the motor mount (49 Megs)
Thats it! Hope this was helpful....
Bob
Old 04-01-2009, 05:46 AM   #2 (permalink)
Thumbs up
Thank you Bob!
Excellent, as usual
Oli.
Oli 69 is offline        Reply With Quote Quick reply to this message
Old 04-01-2009, 09:20 AM   #3 (permalink)
Great job Bob!!!
ADK
TREX 450 SE, HS65MG, 9650, GY401, Align 3K CF main Blade.
DRAGONUS II PRO, FUT S3153 DIGITAL SERVOS, GY401, Align 450XL .
TREX 600CF, 9255'S, GY401 9254, Fut 138 DP RX.
TREX 500CF, 4x9257 on 6 volt, GY401, 6S 2500's EVOLITE'S, 13T, 2700HS.
Antony Konnarides is offline        Reply With Quote Quick reply to this message
Old 04-01-2009, 02:24 PM   #4 (permalink)
nice product but hope ill never need it... (knock on wood)
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 09:06 AM   #5 (permalink)
This is very nice the way you can adjust the clutch and motor.
One thing about the bottom plate, can't they have the same ideal in adjusting it also, instead of having to file the bottom plate? and the nuts on the clutch can't it be captured like the nuts on the motor mounts?
Robert
<<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>>
<<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>>
Bobbyk is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 12:22 PM   #6 (permalink)
Team Taco VP
I suppose they could.... suggest it to Garf at G-Force... Maybe it's a space issue though as there may not be enough room in the motor mount bottom for a slotted hole and a nut?
Bob
Old 04-02-2009, 09:30 PM   #7 (permalink)
Awesome Bob, had not had a chance to view it yet . also still wanting for mine to show up.
Thanks again Jim
vertol BV107II is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 11:10 PM   #8 (permalink)
Bob,
You are correct. There is not enough room in the bottom area of the engine mounts to capture a locknut.
Regards,
Garf
Bob
G-Force Heli is offline        Reply With Quote Quick reply to this message
Old 04-05-2009, 10:52 PM   #9 (permalink)
Great as usual Bob! thanks for the videos! Especially in adjusting the clutch and motor. This really helped a lot!
Jill75 is offline        Reply With Quote Quick reply to this message
Old 04-06-2009, 12:02 PM   #10 (permalink)
Bob,
I noticed that your main gear showed noticeable backlash before the clutch block was installed. Was it like that when you built the 700N?
Garf
Old 04-09-2009, 11:56 PM   #11 (permalink)
Team Taco VP
No it was not and that developed over time since the build.
Bob
Old 04-14-2009, 11:28 PM   #12 (permalink)
Hey bob hows that clutch block holding up? Still waiting for mine and it has been almost a mouth
Old 04-14-2009, 11:35 PM   #13 (permalink)
Team Taco VP
Doing good! Only a few flights so far though..... Waiting a month? I thought they were shipping now? I would call Garf and ask...
Bob
Old 04-14-2009, 11:44 PM   #14 (permalink)
I talk to them today and they said it was sent 2 weeks ago must be held up in custom or coming by sled teem.
Jim
Old 04-14-2009, 11:53 PM   #15 (permalink)
Team Taco VP
Yes it did take over 2 weeks to get mine through customs.....
Bob
Old 04-15-2009, 12:12 AM   #16 (permalink)
Cool thanks Bob!!!!!!!!!
Also check out Beam E4 Looks Awesome
Old 04-15-2009, 06:49 AM   #17 (permalink)
Is there?
jim e h is offline        Reply With Quote Quick reply to this message
Old 04-15-2009, 11:11 PM   #18 (permalink)
looks good but I personally think that all of these fixes fall short of the real issue. Align should have designed the heli with 3 main shaft bearing blocks. The 600 has one at the bottom of the shaft to prevent movement, the 700 should have the same thing. The metal clutch block is a necessary part on most heli's, plastic is just too weak for this application. Unfortunatly the design of the frames does not allow for adding of a lower main shaft block. I would be interested in seing just how much movement there is at the bottom of the shaft durning flight.
jadams is offline        Reply With Quote Quick reply to this message
Old 04-25-2009, 10:16 PM   #19 (permalink)
finless, how the heck do you dremel a slot that is not rounded out so the screwdriver doesn't just jump out. I am down here working on my 700 with a soldering iron a dremel and a flathead screwdriver and I can not dremel a slot, just a rounded out useless slot.
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote Quick reply to this message
Old 04-25-2009, 11:06 PM   #20 (permalink)
By using a cut off wheel with the dremel tool
