250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
View Poll Results: What is the weight of your 250? | |||
less than 320g |
58 | 18.13% |
320g to 340g |
105 | 32.81% |
340g to 360g |
92 | 28.75% |
More than 360g |
67 | 20.94% |
Multiple Choice Poll. Voters: 320. You may not vote on this poll |
#1 (permalink) |
![]() Mine weighs in @ 325g with batt!
![]() TP Pro Lite V2 910 mAH GP750 + DS420 Align CF Main Blades Stock everything else
RC Heli's are flying moneypits! |
#2 (permalink) |
![]() 323g. Many upgrades (all of 'em, I think). KP850 batts.
Almost 1/3 AUW of a 450! |
#3 (permalink) |
![]() Join Date: Feb 2008
![]() I'm surprised we haven't had more responses.
#5 (permalink) |
![]() My older version comes in at 312g and the newer version is 309g. This was using the same Outrage 25C 860 mAh battery. I hesitate to post this values because since it was not on the most accurate scale (I used a post office letter scale), and this is converted number from oz to g. The 12 or so grams I am lighter than the others is roughly 0.4oz. You can take my numbers for what they are worth.
Both helis have plastic 205 blades and ds410 servos on the cyclic. The lighter heli uses the GP750 and JR290, with the weighted tail and metal control arm. The heavier one uses a gy401 and futaba 3154. Oddly the lighter one has the new thicker frame.
TRex 500 CF HS5245MG GP750 w/JR3500G TRex 450 SE V2 HS65HB, GY401 w/9650 TRex 250 DS410, [#1]GY401 w/Futaba 3154, [#2] GP750 w/JR290G AMA#117323 |
#6 (permalink) |
![]() 325gm with a looongmax 800mah and a porky 345gm with a TP prolite 1320mah. 258gm empty all stock except for carbon blades. HAV
MSH Protos 500, SK-540, 4s, Halo 450s, 1400-1800HS MSH Protos 500, SK-540, 4s, Zeal 480s, 1400-1700 HS |
#7 (permalink) |
![]() Mine weigh's in at a fat 372g complete with lipo
TP Pro Lite V2 910 mAH Carbon blades Spartan DS760 Align DS520 on tail Futaba 146ip 35Mhz RX All the rest is stock Anthony
Mcpx BL ,Blade 180 , Trex 470LP ,Invertix 400 4S , DX8 |
#8 (permalink) |
![]() Mine weighs 332 grams with:
FRP blades (I broke my carbons last weekend) Outrage 860mAh 30C batt Hitec HS-45HB (x3) Hitec HG-5000/HSG-5083MG AR6100 Gorilla Gear 450 skids ...everything else stock |
#9 (permalink) |
![]() scorpion 2208 3600, 16T, CC25ESC, R617FS with case, GY520, JR290G, sleeving, pro power, all the upgrades and then some.
346 grams ![]() Bone stock, NO MODS AT ALL, stock electronics, stock plastic mains, R617FS with case, wire sleeving, pro power 342 grams ![]() As you can see in the first pic, I removed the blade holders for the weigh in. Battery straps are under the canopies. These are AUW RTF measurements. I believe accuracy is +-2 grams but not positive. |
#10 (permalink) |
![]() 288g all up
I'm using: hs-45hb servos, which weigh 7.25g w/ shortened wires and no arm (stock aligns weigh 12.75 on the same scale) Logitec 2100 combo, w/ shortened wires. Don't have the align gyro/servo to compare. I'm pretty sure its a bit heavier than what I have. Stock motor and ESC with shortened wires and no bullets between the motor and ESC Kong Power battery No bling ![]() |
#11 (permalink) |
![]() Wow.
Mine comes in at 334g 205D carbon mains 37mm batwings on the tail Ar6100 CC25 ESC RCE-600 gyro + Hitec HSG-5084MG Metal main bearing blocks Metal tail drive pulley Metal tail rotor control arm Outrage 860mah 25c
Trex250 Phoenix25, DS410 GP750 5084 AR6110 Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100 Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000 |
#12 (permalink) |
![]() I'm guessing the major weight savings to be had are:
* stock plastic bearing blocks, battery tray bracket and tail block (anybody care to weigh them up and post results? I don't have any of the aluminum upgrades to compare) * shortened wires * lighter servos * CF blades Lighter batts will also help, but with a significant reduction in run times, so I won't count downgrading mAh. |
#13 (permalink) |
![]() stock plastic parts I have in my parts stash:
tail boom block: 2.03g main shaft bearing blocks w/o bearings: .40g input pulley bearing block: 1.41g lower horizontail frame plate: 2.68 |
#14 (permalink) | |
![]() Quote:
Dude... that's impressive. Makes me want to go and start cutting my wires down now. ![]()
#15 (permalink) |
![]() Shortening wires only gets you a few grams, and most of that is the mile long wires they always put on gyros. It does make your heli much neater.
#16 (permalink) |
![]() 318 grams here. I thought it might be lighter since I have a really ugly flimsy plastic canopy on it, spartan, ino-lab tail servo, stock swash servos, gaui stock motor and gaui 200 V2 metal tail assembly 205 align blades.
#18 (permalink) |
![]() I only have a low-tech mechanical weigher that measures in ounces. It comes in at 11.8, when multiplied by 32 it is 377. Whether or not that is correct I
T-rex 250 Super Combo w/ hs-65mg's Blade cp pro: spectrum receiver, BL main, DD tail, Gyro www.bladecpupgrades.co.nr Blade cx2 E-flite 4-site |
#19 (permalink) |
![]() 315 grams for me, i have some futaba 3114 servos that would get me down to 300 if i wanted too.
On a side note, if anyone wants to see a hilarious video, watch finless Bob's don't taco video in his signature ![]() |
#20 (permalink) |
![]() 382.4 Wow mine is super heavy I thought it might be 25 or 30 grams heavy... but I'm toting and extra 60g more than the norm?
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too ![]() |
