View Poll Results: What is the weight of your 250?
less than 320g 58 18.13%
320g to 340g 105 32.81%
340g to 360g 92 28.75%
More than 360g 67 20.94%
Multiple Choice Poll. Voters: 320. You may not vote on this poll
Old 11-22-2013, 01:09 AM   #181 (permalink)
Mine came in at 312g, and I need to clean up the wires yet.
HK 250GT with Align main gear and hub, DFC head, swash, main shaft, and the new tail hub and grips.
Align 205D blades
Align 250SP motor
Talon 25
Hyperion DS09 GMD's on cyclic
Logictech 3100G tail servo
ZYX-S with orange sat
Nanotech 850
I only have about 6 flights on it so far but I'm pretty happy with how it's flying, I think it can be better with some more fine tuning.
Compass 6hv & 7hv. MSH Protos. RCer Dragonus Pro & Elite. MS Hornet Custom. Robbe Eolo. MCPX.
buzzsaw 46 is offline        Reply With Quote Quick reply to this message
Old 08-05-2014, 03:44 PM   #182 (permalink)
Default What's your 250's weight?
By chance, Anyone have the weight of a 250 airframe with blades? I'll try to work it out from some of these setups
If possible belted with dfc head
"I fly because it releases my mind from the tyranny of petty things."
Jay Helifreak number: 189,781
Soccerjay is offline        Reply With Quote Quick reply to this message
Old 08-29-2014, 05:52 AM   #183 (permalink)
341 grams with iKon. I do sports/scale flying, so a few grams more is not a worry for me at all.
mSR, mSRX, Mini CP, mCPX, V120D02S, T-Rex250/iKon, Forza450EX/iKon
Helicrush is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 01:06 PM   #184 (permalink)
Here is my 250SE converted to the older "3g" FBL head.
Talon 15 ESC
Vortex VX1N FBL Controller
Futaba 6203SB receiver
Scorpion 2206-3900Kv motor
Spectrum DS76 servos cyclic, DS76T for tail
Heimjoint Chinese Weights with two bb+spacer upgrade on tail.
Thunderpower Prolite 730mAHr pack
Original servo & ESC wire lengths
Total weight is 292.5g.
ahahn is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 04:23 AM   #185 (permalink)
292.5!! Very nice Ahahn!
I'm happy for the moment, mine is at 308g so far.... the weight loss program has been working well the last few weeks. And with a 16t pinion it flies like a monster.
It looks pretty much bone stock, but there are a few little tweaks to get the weight down:
  • Trex 250SE frame, with belted tail
  • DFC head and Spartan VX1e FBL unit and Spektrum DSM2 satellite
  • Turnigy Nano-tech 850mAh 3S pack, EC2 plug
  • CC Talon 15 ESC, with shortened wires and soldered motor
  • 16t pinion - 4500 RPM - WOOOO
  • Align metal main shaft bearing blocks
  • HELM JOINT chinese weights with Align plastic tail blades
  • Stock Align DS410 cyclic servos
  • Logitech LTS-3100G tail servo + boom mount
  • Hobbyking KH-250 skids + baseplate
  • Align carbon tail boom
  • Custom carbon tube turnbuckle for tail
My favourite bit is that I've still got two major pieces of weight saving still to go. I'm using the heavy fibreglass canopy, and heavy servos. There's plenty of room to get under 300g here, but I'm holding out for some Lynx servos.
If they do manage to bring out lightweight servos and canopy I think 275g might just about be possible.... o_0
Electronics: Spartan Vortex, MSH Brain, Jeti DS-14
Sims: RealFlight & AccuRC
Other: Team rep for Lynx/Oxy, working on NightWave Systems
Old 10-04-2014, 05:15 PM   #186 (permalink)
..<snip>.....
Just keep in mind you still need to balance the hell. I am just making balance now. I can't go to a lighter canopy and keep the light pack and still balance pretty close as it does now.
But the bird is flying pretty nice as is. Before the weight reduction (old fb with Phoenix 25ESC, Quark gyro, with stock Align DS410 and 420 servos, with a Rhino 750 pack (rest same) it was at 350g. So about a 60g reduction, or ~17% weight reduction.
Tail is much better now with the DS76T over the DS420. I assume the Spartan Quark Gyro and the Spartan Vortex fbl are equivalent when comparing the tail response.
Old 01-27-2015, 10:52 AM   #187 (permalink)
I made a mistake on the polling, didn't read the instructions first. Mine weighs 311 g without the battery, I thought I was doing great, until I realized it's supposed to be with the battery. With a Pulse 850 I am at 376. Mine has a Bavarian Demon FLB, MKS servos and Talon 15 ESC.
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA
guyguerra is offline        Reply With Quote Quick reply to this message
Old 02-03-2015, 08:23 AM   #188 (permalink)
Mine is 334 gram with a 6S 370mah.
I forgot to take the weight out of my Robird G31 before sticking it down. I noticed tonight that it is tail heavy by about 10mm. When I move everything forward a bit, I may remove it then.
First flight with its new motor tomorrow! (Scorpion 2206 1900kv rewind). If the motor/heli survives, then I might think about replacing the servos as I have hxt900's and a corona 919 at the moment (with slightly too short leads). So hopefully there is a few more grams to save.
Are there any conversion kits to put the tail servo underneath? Is it worth doing? It started out as a HK 250 kit. Now it has bits of Align and Copter X in it. I am starting to like this bird more and more.
TracesOfNut is offline        Reply With Quote Quick reply to this message
Old 02-04-2015, 06:42 AM   #189 (permalink)
Weighed mine again after installing the Hughes 500E fuselage by Align, which I did about 6 mo. ago. Total flying weight = 584.8 grams or 1.28 lbs. One thing I did for more power, alot more power actually was change the stock esc to an Eflite 25amp and stock motor to an Eflite 320h, both of which came out of my 300x which was changed to a 35 amp esc and Lynx motor. The 320 fit nicely on the stock motor mount and only needed two spacers, one on either side, between the motor and mount to line up the pinion to the main gear. Definitely made a big difference dealing with the extra weight of the scale fuselage. Oh, and I just had to reverse the motor since the t-rex has the motor pinion facing up, while Blade helis have the motor oriented down.
Flyin' keeps me grounded!
bobbygz is offline        Reply With Quote Quick reply to this message
Old 02-04-2015, 11:36 AM   #190 (permalink)
With a zippy compact 25C pack I'm at 289g flying weight :-D I'm usually 10g heavier than that though, my normal weight is around 299g.
Still using the stock Align cyclic servos, might have to replace those one day, there's potential to drop this under 275g if I did
Old 10-14-2015, 01:12 PM   #191 (permalink)
263 g Vbar Neo pulse 860 Phonix 25 cc sorpion 3900 430 aligns on cyclic s and hitec hsg5084mg om the tail. Also it is se belt drive. Im surprized it way's that and not more.
Jim Hansen is offline        Reply With Quote Quick reply to this message
Old 04-11-2016, 08:57 AM   #192 (permalink)
Figured I'd chime in now that I've got my 250 the way I want it.
Align Trex 250 SE w/ DFC Head
Spektrum H3050 Cyclic
Spektrum H3060 Tail
Align 250MX
Talon 15
KBDD EE 40mm Tail Blades (not pictured)
Align 205D Main Blades
Glacier 800mAh 3s 25C
Mini *Bar (will try to get genuine Vbar ASAP)
LemonRX Satellite
Upgrades:
Infinity Hobby Kevlar Belt
HK250 CF/Aluminium AR Guide
Lightweight Vbar Mount
Lynx 250DFC Ultra Dampers
Aluminium Tail Boom Clamp (may or may not be considered an 'upgrade')
XT30 Connectors
I don't fly with a canopy.
All up weight comes in at 291g. I'd like it to be a little lighter, but I'm okay with this, because now I know I won't strip servo gears in a minor crash like I did with the DS76's.
Keith - MSH Brain2 Beta Test Team - KST Heli Division Team Pilot
Specter 700 | GAUI NX5 | Protos 380
FrSky Help Click Here
https://kc3dprint.com - 3D Printing on Demand and Printed RC Helicopter Upgrades
Number is online now        Reply With Quote Quick reply to this message
Old 05-05-2016, 09:07 AM   #193 (permalink)
Putting mine on a major diet. I've come to realize disk loading is crap on this heli, built like a 450, but with blades much shorter. If all goes well I might get mine down to 326g AUW. Smaller lighter servos, plastic canopy. Found the AR7200BX I'm using carries 10g in the chassis. Going to figure a way to run without it mounting only the circuit board. That's with a larger motor too, Turnigy 2632 rewound to 4000Kv running 8:1 and 4500 rpm head speed governed. The motor adds 10g, but I want that motor.
Krager is offline        Reply With Quote Quick reply to this message
Old 05-05-2016, 02:25 PM   #194 (permalink)
I'm just finishing my build up now and I'm coming in at 281g with the canopy and battery. Hopefully I will get to do the maiden this weekend.
The heli is an se with belted tail and dfc head. I am running the elite ds76 servos on it, talon esc, decased kbar with a dcased sat soldered right to the board.
I'm going to fly it like this for a bit and see if I like it. If I want to go lighter I can switch up canopies, trim servo wires, carbon boom and maybe a different motor, lynx 180 servos and a few other measures to get under 150 if I really fell like pushing it.
I can't wait to fly this weekend if the weather cooperates for me. I think it's going to rip.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 600N, 700N
HeliLust is offline        Reply With Quote Quick reply to this message
Old 05-05-2016, 03:25 PM   #195 (permalink)
Yeah a couple easy ways to shed a lot of weight, plastic canopy and lighter servos. I've got a set of Lynx 180 servos coming. That's a huge weight savings going from servos that weigh 15g each to 6g each. The specs on those show 2/3 the stall torque of the stock servos. Since the stock servos on the 250 are also used on the 450 at pretty much twice the rotor size the lighter servos should work. Hoping all goes well with it.
I was actually thinking about the KST DS245S servos which are also a lot lighter and they have a higher stall torque. Problem with those is there are simply no spare gear sets available. The Lynx 180 servos come with servo saver horns and gear sets are readily available if that doesn't work. The Lynx servos are three grams lighter than the KST servos, but the KST servos have a lot more torque. Better to have too much than not enough.
I was thinking about the belted tail. I understand it's lighter, but I don't know by how much. Mine's torque tube. If there's some good weight savings might be worth it to go with the belt.
Old 05-05-2016, 07:46 PM   #196 (permalink)
I was wondering if the lynx 180 servos would fit the 250, I was under the impression that they wouldn't. If there the same as the ds76's but with the different connectors then maybe the lynx servos with a gy280rx would be a sweet combo without having to change connectors or deal with a sat for the spektrum guys.
I have thought about getting mine closer to 225g mark. I was thinking of using that same setup as above with the addition of the lynx 180 motor and dropping to 500 mah 3s batteries as well as shortening the boom and main blades down a bit to get more of a 200 size machine going on.
The motor would drop 10g and the battery another 20g, plastic canopy another 8g.
I think I could get sub 225 range if I really get creative with it, but I'm thinking this setup is going to be nice at the weight it is tuned in. I may end up trying the lynx servos though mainly for the weight and metal gear combo savings.
Still hoping oxy2 fills that 200 size want for me, but I may end up building one up.
Old 05-05-2016, 10:34 PM   #197 (permalink)
180 servos are way small. You'd need some serious size adapters and I'm not sure the arms would line up well. You'd have to get the Lynx ones as the Spektrum ones have way too little torque to be useful IMO.
Old 05-05-2016, 11:12 PM   #198 (permalink)
Yeah that's kind of what I was thinking as far as the servos go. Especially going through all the work that would be required, the lynx ones would be the ticket for the win.
I think I will have a winner as far as it goes regarding the 250 any way. There are a few refinements to it that I will be going through once it's flying good and getting it the way I want it. The biggest area for improvement right now is the servos, but I think they will be good for what I have going on.
Right now I'm wanting the carbon boom, Chinese weights, double bearing mod, maybe some zeals and to do some refit and repair on the canopies I already have for it.
If I do go crazy on a build it will probably be a frame similar to the one like fabians with the lynx servos, but I doubt I'm going to mess with it. I just can't wait for oxy.
Old 05-06-2016, 02:47 PM   #199 (permalink)
Whoops, ignore me :-)
Old 05-06-2016, 03:07 PM   #200 (permalink)
Default check out what myxiplx did last summer for weight savings
https://www.helifreak.com/showthread...ghlight=weight
Agile 5.5, Logo 550sx, X5, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is offline        Reply With Quote Quick reply to this message
