View Poll Results: What is the weight of your 250?
less than 320g 58 18.07%
320g to 340g 106 33.02%
340g to 360g 92 28.66%
More than 360g 67 20.87%
Multiple Choice Poll. Voters: 321. You may not vote on this poll
Old 09-27-2009, 04:58 AM   #41 (permalink)
Hyperion servos 2100t gyro align esc 6100rx and all of the metal upgrades 205d cf blades.But I have to digress,I have just added the KDE alu bottom plate and the infinityhobby cf gear legs modified to take the align skid pipes and my weight is now a whopping 306 grams
ID:	117201   Click image for larger version
Gohbee Stinger 50 (yes I love it)
4 trex450's
Blade400 Blade cpp
2HDX300's
3 gaui200's
aristo is offline        Reply With Quote Quick reply to this message
Old 09-27-2009, 05:05 AM   #42 (permalink)
My outrage 800's weigh in at 61 grams.
4 trex450's
Blade400 Blade cpp
2HDX300's
3 gaui200's
Old 10-04-2009, 03:21 PM   #43 (permalink)
I just completed mine and I am temporarily using an AR7000 receiver while waiting for my long overdue AR6100e. DS410s, GP750 w/ DS420, stock plastic blades, motor and ESC. Using an Outrage 860 which weighs 73g, my AUW is a very porky 375g. Not sure why it is so heavy as the receiver can't be adding that much.
rablett is offline        Reply With Quote Quick reply to this message
Old 10-06-2009, 07:05 AM   #44 (permalink)
Mine weighs 325gr,
stock super combo
with Graupner 3s850mah 30c
and spektrum AR6110e reciever.
bd87 is offline        Reply With Quote Quick reply to this message
Old 10-11-2009, 04:12 PM   #45 (permalink)
Mine is 354 gr. with training gear on
Michel
Michel63 is offline        Reply With Quote Quick reply to this message
Old 10-15-2009, 07:09 AM   #46 (permalink)
305g
1050mAh 7.4v
3xds410
1xds420
align gyro ABS blades
yoyoek1 is offline        Reply With Quote Quick reply to this message
Old 10-15-2009, 12:14 PM   #47 (permalink)
327 grams
All Align up grades.
290g tail servo
Hyperion 850mah 25c
Airtronics 92824 receiver (without case)
HeliHoverAP is offline        Reply With Quote Quick reply to this message
Old 10-17-2009, 04:01 PM   #48 (permalink)
Mine comes in spot on 300g. All stock (V1) except King 2 skids. Extreme 850 mah lipo. Oh and Align carbon blades.
Can't believe it's as light my HoneyBee!!
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote Quick reply to this message
Old 10-18-2009, 02:50 AM   #49 (permalink)
My heli is 336 grams.
No name cf blades.
KBDD tail blades
Non original16t pinion with lock screw
Metal tail rotor control arm
Metal main bering block holders
Metal tail boom holder
Metal tail servo holder
3x DS420 Align servos
DS290G tail servo
Home made CF tail pushrod
980 mAh 30C battery
Spektrum AR6100 reciever
Align GP750 gyro
T-Rex 450SE V2 mini V-bar, T-Rex 500ESP V-bar, HB CP2, Blade mSR
Spektrum DX8 radio + Raydiowarm
Hyperion EOS 0615i Duo III + 400W 24V 16,7A power supply
Stolpe is offline        Reply With Quote Quick reply to this message
Old 10-19-2009, 03:29 AM   #50 (permalink)
Originally Posted by fwilly View Post
288g all up
I'm using:
hs-45hb servos, which weigh 7.25g w/ shortened wires and no arm (stock aligns weigh 12.75 on the same scale)
Logitec 2100 combo, w/ shortened wires. Don't have the align gyro/servo to compare. I'm pretty sure its a bit heavier than what I have.
Stock motor and ESC with shortened wires and no bullets between the motor and ESC
Kong Power battery
No bling , just functional upgrades (205D carbons, chinese weights ect..)
I find this heli very hard to believe. Do you have pictures of this heli, canopy less. and which Kong Power battery are you using. This is just too good to be true. Sorry I hope I'm not offending you, But I am looking for places for my heli to lose weight, and Jenny Craig has denied it's membership.
walkera4g3 is offline        Reply With Quote Quick reply to this message
Old 10-23-2009, 10:02 AM   #51 (permalink)
ok I have update
less then 300 gram
it whose my target
299 gram and 45Amps 3f regler on board
Old 10-23-2009, 03:05 PM   #52 (permalink)
BUT!!! where's the canopy Sorry your flying weight must still be over 300g
Cheers, OD.
Old 10-24-2009, 03:17 AM   #53 (permalink)
canopy is on the top of main rotor it is there to show the battery
weight is less then 300 gram
Old 10-24-2009, 05:14 AM   #54 (permalink)
nice
Old 10-24-2009, 05:24 PM   #55 (permalink)
I "sit" corrected. Nice
I did wonder what that was at the top of the pic. I can see the grommets now
Cheers, OD.
Old 10-24-2009, 11:34 PM   #56 (permalink)
Does anyone know of a good cheap gram scale that I could buy at a local home depot or some place like that? I am running on a mechanical 14 ounce scale and would like to step up to the 21 century.
T-rex 250 Super Combo w/ hs-65mg's
Blade cp pro: spectrum receiver, BL main, DD tail, Gyro
www.bladecpupgrades.co.nr
Blade cx2
E-flite 4-site
helidude3 is offline        Reply With Quote Quick reply to this message
Old 10-28-2009, 09:41 PM   #57 (permalink)
Ahhhh. I love this thread.
RC Heli's are flying moneypits!
wannaflyguy is offline        Reply With Quote Quick reply to this message
Old 10-29-2009, 07:15 AM   #58 (permalink)
Whats the biggest size lipo we can fit on these things without killing performance or CG? I ordered some 900mah but I'm also seeing some awsome prices on 1050mah. You think that would be too much? Thanks, Joe
joeyhatch11 is offline        Reply With Quote Quick reply to this message
Old 10-30-2009, 11:21 PM   #59 (permalink)
910 for me. I think above this might be pushing it.
Old 11-01-2009, 03:30 PM   #60 (permalink)
295g AUW
Align 205 CF blades
Align CF boom
Align CNC tail pulley + shaft
Align BL250SP motor
Gaui 18A ESC
Spektrum AR6100
Logictech 2100T gyro
1 x Hyperion DS11GCD tail
3 x Hyperion DS09SCD cyclic
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
